Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
  E90Post
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Spacers, Rubbing, and Roundel questions.
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
Reply
      12-19-2005, 05:30 AM   #1
stratstrummer
Drives: Want a 330i soon.
Arrow Spacers, Rubbing, and Roundel questions.
If I purchase wheels from a place like TireRack, and they have a generator that lets you know what wheels can fit on your car, do they fit without any spacers, and without any rubbing whatsoever?
I see they have 19" wheels as well as 20" wheels that would look massive on a e90. If you turn a 20" wheel, it's unlikely there won't be some rubbing right?
And as for spacers, I hear it's not good to put spacers on because it's easier for damage to happen. For example, someone I know had a car with spacers, and while he was driving, the rim came off!
Lastly, is there any way to affix a BMW roundel on any rim I get?
      12-19-2005, 05:50 AM   #2
Dante
Enthusiast
Dante's Avatar
Germany
468
Drives: F87 M2 / F31 330d
As for the spacers, just make sure you get matching screws which are that longer as the spacer is thick.
(forgive my bad english skills today )
      12-19-2005, 09:02 AM   #3
eros613
Drives: 2006 325i
Tire Rack told me that they test fit all rims before the recommend them, so they should know about fitment. I also believe at least one of their employees drives a BMW so I know he a happy man with a constent supply of new wheels and tires.
If you need spacers use common sense with the thickness of the spacer, make SURE that they are hub centric and that you use a longer lug bolt. You should also check a make sure that those same spacers will work with the rims. Check that CENTER BORE configuration.
As for being concerned about the safety, many racers use them with no adverse problems.
      12-19-2005, 09:10 AM   #4
JIMD1709
JIMD1709's Avatar
31
Drives: 2007 328 Coupe Alpine White
Tirerack will not reccomend a bad set-up. Yes, they test fit, and they don't advise spacers. If you go with a set-up that needs spcers, make sure they are hub-centric like was already stated. Also they must be fitted with longer lug bolts to be safe.
Reply
e90post
