bimmerpost/
BMW M2 and 2-Series Coupe
BMW M2 Forums 2023+ (G87) BMW M2 G87 General Topics
      01-12-2024, 11:27 PM   #45
1stM
1stM's Avatar
385
Drives: G87 M2
I did with the manual for M package, but now I'm staying with 36F and 40R.
M2siast5958.50
      04-23-2024, 02:17 PM   #46
Ravenseal
Ravenseal's Avatar
Drives: 2023 M2 6MT
That's for four passengers and luggage, aka the maximum load of the vehicle.
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is
      04-24-2024, 08:41 AM   #47
RockCrusher
Drives: BMW 2023 ZB M2 6-speed
Originally Posted by Carefree View Post
With the huge temperature variation during an Arizona winter I’d be adjusting pressure perhaps daily.
Rule of thumb it is.
One doesn't have to set the tire pressures daily.
Just set the tire pressures to be correct at the coldest expected temperature.
If 60F is the expected low -- even if every overnight low doesn't get that low -- set the tire pressure so it is correct (not under inflated) at 60F.
Say you check the cold tires (cold in that the car has not been driven in a sufficient amount of time) at 70F set the tire pressures 1psi higher than the desired tire pressure at 60F.
When the tires cool down to 60F the cold tire pressure would still be in spec.
Running tires under inflated is a no no. But the tires can safely tolerate pressures above the cold pressure. As the car is driven and tire pressures can climb 3, 4 or more PSI and the tires are quite ok with this increase in pressure. The hot tire pressure does not get even close to the maximum inflation pressure marked on the sidewall. (45psi IIRC.)
As an aside it is SOP for the new tires to be inflated to if not the maximum pressure to close to it when the car leaves the factory. The tires being inflated to this higher pressure prevents flat spotting.
      04-24-2024, 09:35 AM   #48
aerobod
Car Geek
aerobod's Avatar
3709
Drives: Caterham R500, M2-G87, Macan S
Here we can often get 30C swings of temperature in the winter from day to night, combining that with a 10C tyre heating change, 40C variation is normal. I set a baseline of 2.0 bar (29.4 PSI) for -30C, which would see the pressure rise to 2.5 bar (36.8 PSI) with the 40C temperature change.
      04-24-2024, 10:57 AM   #49
Carefree
Carefree's Avatar
Drives: M240i, M2
If 60F is the expected low — even if every overnight low doesn't get that low — set the tire pressure so it is correct (not under inflated) at 60F.
I never said pressure was set daily but temperature variance here is 28°-120°
Thank you.
      04-24-2024, 02:59 PM   #50
bmhewett
Drives: 3012 328i sport 6 speed MT.
Look my car, driving pleasure and sportiness
      04-24-2024, 03:41 PM   #51
m2not1LE
m2not1LE's Avatar
66
Drives: GTI, 2025 M4 Comp on order
Thank you.
Degrees F rather than degrees C...
But that has to be annual variation. Anyone who checks their tire pressure just once/year isn't going to be running anything close to recommended pressures on average.
      04-24-2024, 03:50 PM   #52
Carefree
Carefree's Avatar
Drives: M240i, M2
Never said I check it annually.
Thank you.
      04-27-2024, 09:54 AM   #53
RockCrusher
Thank you.
Ok. I misread your post.
g87
