      07-09-2020, 02:15 PM   #1
jqu1ck
Drives: 2003 BMW M3, 2015 BMW M3
2003 Carbon Metallic Black e46 M3 Coupe
This garage stored 2003 BMW e46 M3 coupe is being sold by the original owner (Carfax shows “3” owners due to title being transferred to original owner’s brother for storage in California, then being transferred back to original owner). The car was sold new in New Jersey (has a current New Jersey registration), and comes with service records and factory manuals. While it has 156,500 miles on the odometer, it was driven on mostly highway miles at less than an average of 10k miles/year. It is finished in the original Carbon Metallic Black paint, with Black Nappa leather interior. The M3 is powered by a 3.2-liter inline-six (factory rated at 333 horsepower and 262 lb-ft of torque) paired with a six-speed manual transmission and a limited-slip differential, and is currently running a square set up with 18” OEM Style 67 wheels, on Michelin Pilot Super Sport tires in front (255/40ZR18) and Michelin Pilot Sport 4S tires in back (255/40ZR18).
The bad: paint chips on front bumper and hood, some clear coat peeling on the front driver and passenger doors near the window panel gasket.
Price: $15,000
Mileage: 156,500
Transmission: 6 speed manual
Engine: 3.2L S54 Inline 6 DOHC 24V
Drivetrain: Rear-wheel drive
Fuel type: Premium
Body type: 2 door coupe
Exterior color: Carbon Metallic Black
Interior color: Black Nappa Leather
Max seating: 5 seats
VIN#: WBSBL93493JR20025
Manufacturer options: Leather seats, power/heated front seats, brushed aluminum trim, automatic climate control, sunroof/moonroof, premium package, cold weather package, Harmon Kardon sound system (10 speakers with subwoofer), bi-xenon headlights.
Upgrades/enhancements: Cooling system refresh kit (water pump, expansion tank, fan switch, thermostat, sealing gaskets, upper and lower radiator hoses) installed (06/2017), short shift kit with alcantara boot and ZHP knob installed (06/2017), lower belly pan replaced (06/2017), stainless steel brake lines installed (06/2017), Status Gruppe SRS coilover kit (9kg front springs/11kg rear springs) with camber plate option installed (11/2017), Beisan Systems VANOS solenoid coil pack installed (06/2018), camshaft position sensor replaced (07/2018), clutch fan and drive belts replaced (07/2018), alternator replaced (08/2018), coil packs and spark plugs replaced (10/2018), subframe reinforced (12/2018 by Bimmerclinic in NJ), windshield cowl and quarter panel gasket replaced (06/2020)
*Note: License plate has been blacked out in the pictures. No other alterations to pictures made.
      07-09-2020, 09:39 PM   #2
Typeslice
Drives: 2018 M3 CS
Interested, but if you don't mind me asking, what's your affiliation with the seller? Are you a dealership? Hard to tell with the way the ad is written. Thanks.
      07-09-2020, 09:47 PM   #3
jqu1ck
Hi,
I'm the owner (original/current) and seller. Tried to make the post as objective as possible.
Hope you are doing well!
