07-07-2013, 01:05 PM | #243 |
1580
Rep 8,077
Drives: 11 E90 M3 Individual
The front interior will save you another 30lbs or so. I ditched the carpet, glove box, center console, and a bunch of other panels (except for the dead pedal).
Did you remove all of the little brackets and other bolted on stuff in the back? That's good for another couple of pounds. OEM Radio harness is like another 10lbs. (I installed an aftermaket head unit and front speakers - 5lbs). I just use the quick fit harnesses on the street and removed all of the OEM seat belts. I kind of regret this because its a pain loading tires in the back seat...and not having the tires rest on the belt. I think I'm at 3100ish at this point.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
07-07-2013, 01:22 PM | #244 |
38
Rep 370
Wow all that stripping and 3200. Did you weigh the car when you got it? Means it must have weighed in the 3400 range. Less than 200 pounds of the e9x m3. Interesting
07-07-2013, 02:42 PM | #245 | |
11818
Rep 23,187
07-07-2013, 02:44 PM | #246 |
11818
Rep 23,187
I didn't weigh before. Was thinking I was starting at around 3300 but guess it was mid 3400 somewhere instead. I'm still almost 400 lbs lighter than my partially stripped e90.
07-07-2013, 02:59 PM | #247 |
1580
Rep 8,077
E46 M3 curb weight is 3406.
You can quickly get down to 3100ish. After that you start really compromising street ability.
07-07-2013, 03:13 PM | #248 |
746
Rep 1,848
My E46 M3 is at 3140 with full tank of gas. It is pretty tough to get below 3000.
Stuff removed: rear seats, all interior carpeting, sunroof cassette, center console, air bags, parking brake, all AC components, all radio components including harness, windshield wiper, fog lights. Stuff lightened: metal roof replace with CF roof, OEM exhaust replaced with BW race exhaust, OEM seats replaced with Cobra Imola Pro. Stuff added: half cage, trailer hitch mount. |
07-07-2013, 03:26 PM | #249 |
11818
Rep 23,187
And I have sun roof so I probably started at 3450. That 3100 is doable with all front carpet, door cards, center console, sunroof probably but will save that for when has full cage and rolls on a trailer I think.
07-07-2013, 03:28 PM | #250 |
DHS
222
Rep 4,038
Drives: 2023 M4, 2020 Land Rover
I love this car. I use to have a 2002 E46 M3 in this exact color with the CSL goodies as well. I miss it. It was the most problem free car I have owned since 1991.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
07-07-2013, 03:51 PM | #251 | |
1580
Rep 8,077
07-07-2013, 03:56 PM | #252 | |
1580
Rep 8,077
07-07-2013, 03:59 PM | #253 | |
1580
Rep 8,077
Still debating the 5sp swap...30lbs of weight savings! If I do that and a 3.91 then I'll have trailer.
07-07-2013, 04:14 PM | #255 |
11818
Rep 23,187
Thanks. Hopefully it is good for me as well. Wanted to find white but didn't happen. Already had several silver cars including another e46.
07-07-2013, 04:21 PM | #256 |
11818
Rep 23,187
If your going that far might as well just get BW CF blanks for the headlights. I may do sunroof, rear diff, strip down rest of interior, but I doubt it. Right now I'm working out my brakes, bbk or stick with csl. Also plan on the BW v2 clutch. Handle the vanos and rod bearings and drive it. But if my past is any indication of my future I may go overboard and do something crazy with it also.
07-07-2013, 06:03 PM | #257 |
38
Rep 370
Why not go with a used C5 zo6 as a track car? Much lighter, much more powerful and even more track ready?
Anyway is anyone else surprised at the 3450 weight of the e46? Given the e90's weigh in at 3600 that really seems close given how often you read people call the e90 a pig? Given most e92 has the carbon fiber roof vs sunroof e46 but regardless 150 pounds is really not a lot different in my book. Sounds easier to strip down the e46 thought which I know is your point |
07-07-2013, 06:55 PM | #258 | |
1580
Rep 8,077
07-07-2013, 07:18 PM | #259 |
11818
Rep 23,187
eh legal smegle. already have issues with legality if they really wanna push it.
07-07-2013, 07:21 PM | #260 | |
11818
Rep 23,187
07-07-2013, 09:23 PM | #261 | |
1580
Rep 8,077
Isn't the E92 closer to 3700lbs? Either way, the S54 block is a heavy bitch. Almost any aluminum V8 will be significantly lighter. I've never understood the complaint about weight focused on the M3 when you compare it to other cars in its time. Any competitor's car is about 4000 lbs. The only ones that are lighter are the 911 and the C6 vette...but those don't have the 4 door option.
07-08-2013, 09:14 AM | #263 |
11818
Rep 23,187
