09-13-2023, 11:01 PM | #1 |
Rep 82
FS: 2005 E46 M3 Alpine White Non-ZCP SMG 38k Miles
Considering selling my Alpine White E46 M3. Car has 38k miles. I am 3rd owner. "Big 3" have not been done. Subframe is still crack-free. A list of maintenance / service items under my ownership (~18 months and ~6k miles); Replaced both interior C-pillar trim due to fabric sagging Replaced belts Brake fluid flush Rear differential flush Coolant flush Power steering flush New battery Replaced oil pump relief valve Replaced gasket ring and seal on differential Replaced throttle position switch and air mass sensor Replaced thermostat with O Ring Replaced spark plugs Replaced front headlight covers Two oil changes I also added the below modifications: OEM ZCP wheels (no longer have the OEM 18" wheels) Michelin Pilot Sport 4s tires Eibach Pro-Kit lowering springs w/ Koni Sport Struts and Turner Monoball rear trailing arm bushings Future Classic spacers Eventuri carbon fiber intake BlueBus audio module Exterior paint is in very good condition with usual rock chips here and there. There is a small vertical scratch on the lower passenger door. I added some touch up paint. Interior also in good condition. A pillars fabric is slightly bunched at bottom but no sagging. I replaced the center console as the plastic was scratched. Also added new OEM M3 floormats. Feel free to PM for more pictures or questions. |
