      01-13-2021, 01:52 PM   #1079
spencers
Isle of Man
199
Drives: Sthrizzle
Originally Posted by ramman434 View Post
Sadly that's our debate now. If we're eventually just going to rent it, is it even worth that investment.
I told my wife, if we were to do it, I'm going to tear up the yard, re-do the irrigation (base of the old system is on the side of the house still), and re-sod. That seems to be the only proper way to address it.
Rent it? Don't do anything. Renters won't take care of it.
Alfisti6567.00
David701567.00
      01-13-2021, 02:11 PM   #1080
ramman434
Drives: F30 335i
Hahaha, hence why we're leaning towards living that "weed life" (for the lawn).
This is still our primary home for the next couple of years, so it's I've just got to tell myself that it's not worth the overall investment.
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21
'13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake
      01-13-2021, 03:37 PM   #1081
Alfisti
6567
Drives: 2008 Saab 9-3 Combi
Just plant clover. Bright green, blocks out al invasive weeds, looks great, tolerates a lack of and too much water easily and doesn't cost a god damn penny.
      01-13-2021, 05:35 PM   #1082
RickFLM4
RickFLM4's Avatar
Drives: M4
That’s a weed here. He doesn’t need to plant it.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
ramman434712.00
      01-14-2021, 08:23 AM   #1083
Alfisti
6567
That's my point. Seriously, becoming a trend. I like outdoors work but the money and time trying to maintain a good lawn is absolutely preposterous. Much harder here maybe as all pesticides are banned.
      01-14-2021, 09:44 AM   #1084
Ngilbe36
Ngilbe36's Avatar
Drives: 2011 E90 M3, 2019 F150
2011 BMW E90 M3  [0.00]
A good lawn is not that expensive to maintain. A perfect lawn is.
If you drop pre-emergent early spring and some bi-weekly nitrogen in the fall your lawn will look better than 95% of lawns out there.
      01-14-2021, 11:34 AM   #1085
Alfisti
6567
Right, i had about 4000 sq feet, to firstly see and fertalise and water that amount of lawn was just eye watering, again, weed killer is banned here and the dandylions just run RAMPANT if your lawn is not SUPER SUPER SUPER thick, any gap and they take root so fast it is scary. Clover blocks them out and needs about 1/100th the time and money to look after.
      01-21-2021, 01:41 PM   #1086
Mosaud1998
Mosaud1998's Avatar
Drives: 2019 BMW 540
2019 BMW 540  [0.00]
Painted my closet (it was flat white before). Builders painted the whole house flat white. The next step is probably removing all this crappy carpet the builders installed and putting in hardwood flooring on the second floor including bedrooms.
RickFLM411000.00
      01-22-2021, 01:45 AM   #1087
shimmy23
F15 daddymobile
shimmy23's Avatar
2356
Drives: GS X5
I'm refreshing our fireplace. Got the sheetrock back on and now I'm contemplating if I should go further and replace/lower the mantel and install tv above the fireplace.
What's yours guys thoughts? Do TVs belong above the mantel or keep the fireplace as its own focal point? Our fireplace is in our great room, not the formal living room.
Appreciate 4
RickFLM411000.00
jmack550.00
bosstones1163.00
      01-22-2021, 06:04 AM   #1088
RickFLM4
RickFLM4's Avatar
Drives: M4
I'd say if the TV works elsewhere I would leave it elsewhere. I think fireplaces look better without a TV above them and the TVs are too high when installed over a fireplace most of the time. But some rooms do not provide a better alternative location where the TV can be seen better so it really depends on the room.
Appreciate 4
      01-22-2021, 07:28 AM   #1089
Alfisti
6567
I would gut and replace with newer slim fireplace and place tv above it. Old fireplaces tend to hog where a tv should go imho, and the TV ends up being way too high.
      01-22-2021, 08:06 AM   #1090
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
looks pretty dope! i like it! i would leave it as a fireplace as this is a focal point in the room. don't put the TV there. here's what mine looked like when we first moved in and i ended up sealing everything up and continued the moulding work to the ceiling to make the whole thing a focal point than just the mantel and below
now i'm thinking about replacing the tile with something different?
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
jmack550.00
      01-22-2021, 08:09 AM   #1091
spazzyfry123
spazzyfry123's Avatar
4371
Drives: Here and There
Man, that better be a false door with all the jewels hidden!
Appreciate 8
bosstones1163.00
vreihen1615509.50
AmuroRay2343.50
Hawkeye2069.50
      01-22-2021, 09:26 AM   #1092
bosstones
1163
Drives: o_0
Personally, I'm not a fan of TV's above fire places when other options exist but it depends on the room layout and you use the room. Some people have no choice.
Did you run the plywood under the entirety of the trimmed area? Or just the the interior? Slicks nice!
My current projects are more pedestrian. Velcro'ing the unvelcro'd and trying out different finishes on walnut for some black pipe shelves I'm making. The latter is so damn iterative and I'm sure there are options I have left to try! Plus not all pieces finish/color the same. 4 finishes shown. The smaller board is more blond because of less heartwood. </crappy phone pix>
      01-22-2021, 10:39 AM   #1093
RickFLM4
RickFLM4's Avatar
Drives: M4
Roof, patio, driveway and sidewalk getting cleaned today. Trying soft wash for roof this time - no walking on roof. Hope it works better than guys walking on the roof, which always results in a roof leak during the Spring. Pics before cleaning.
AmuroRay2343.50
      01-22-2021, 11:23 AM   #1094
AmuroRay
AmuroRay's Avatar
2344
Drives: M235i
Just became a first time HO and this was my first purchase. Anyone else into things like this - I just think it looks neat.
Mods: Yes.
      01-22-2021, 12:49 PM   #1095
David70
Drives: 06 Z4M Coupe - 13 Cadillac ATS
Installing a new irrigation system then resodding only to turn it into a rental a few years later and watching it go back to what it is right now would have me only doing very basic work and improvement to make it look decent. Once you are headed to it being a rental it needs to be looked at as a business where things people won't pay for has you not doing them. At least for places I have lived a perfect yard and irrigation system won't increase the rent much.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
      01-25-2021, 10:27 AM   #1096
ramman434
Drives: F30 335i
That's exactly why we've opted for our lush, green weeded yard lol
      01-25-2021, 10:32 AM   #1097
ramman434
Drives: F30 335i
I did a full pressure wash on my fence, patio, & sidewalks a couple of months back. Makes a world of difference on how the house looks. Night/Day difference.
What amazes me (as a realtor) is the amount of people who will put their homes up for sale, doesn't matter if it's $300k or $1.4mil, and don't clean up there exterior better.
Pressure washing is easy and takes a few hours (can rent the equipment or buy pretty cheap), and having your pavers on your driveway clean, will really help that house show that it's worth the price you're listing at.
So many people don't bother with that and man will it make a difference. I recommend to my clients to look into it.
cmyx6go15814.00
RickFLM411000.00
      01-25-2021, 12:29 PM   #1098
RickFLM4
RickFLM4's Avatar
Drives: M4
Yeah we do the roof as infrequently as possible because it isn’t good for the life of the roof or gutters. I will definitely never have anyone walk on the roof to clean it again. The pavers and sidewalk don’t even need pressure cleaning very often if you just spray them down with chlorine every 6 mos. or so. One thing I hate about pressure cleaning is when they apply pressure between the pavers and dig out the sand between them, which then requires replenishing and leaves sand everywhere. Everyone that’s ever done it has left sand everywhere, some worse than others. I’ve gotten into the habit of moving everything off the patio / to the garage to avoid sand sprayed all over the patio furniture.
The other thing I like to keep up with that a lot of people neglect is the windows. We have a great window wash guy who does the exterior for only $110. We were getting it done 2x / year and I was using Windex outdoors with a water deionizer in between. Now I’m thinking for that price, just have him out 3-4x / year.
ramman434712.00
      01-25-2021, 02:01 PM   #1099
ramman434
Drives: F30 335i
Does your window guy do Broward, or stay in PB? I may have to get his info from you.
      01-25-2021, 03:04 PM   #1100
RickFLM4
RickFLM4's Avatar
Drives: M4
I think he’s just in Wellington.
ramman434712.00
