06-17-2021, 07:29 PM | #23 |
sportscars only
3291
Rep 3,211
06-17-2021, 07:56 PM | #24 |
6644
Rep 2,329
Use a pizza screen.
Brush it with EVOO and bake it (no pizza) at 500 deg F for about 30 minutes. Let it cool. It's now seasoned. Brush it with EVOO, or not, every time you use it. Don't wash it. Ever. https://www.walmart.com/ip/6-14-Alum...B&gclsrc=aw.ds |
tranquility3290.50 |
06-17-2021, 09:51 PM | #25 |
sportscars only
3291
Rep 3,211
Not gonna win any awards at Concours but good enough for me. Cleaned, seasoned and ready to go. Tx again everyone.
BEFORE: AFTER: |
06-18-2021, 12:46 PM | #27 |
I'll get back to you
7569
Rep 2,132
You owe us each a slice of pizza now. I'll take pepperoni
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
06-18-2021, 03:12 PM | #28 |
sportscars only
3291
Rep 3,211
Homemade just now, flooded it w mozzarella, have a virtual slice, hope you like!
06-18-2021, 06:53 PM | #29 |
18125
Rep 9,384
I enjoyed bacon and Ortega pizza for lunch
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
06-18-2021, 07:38 PM | #30 | |
630
Rep 433
Olive oil's smoke point is around 405 F. Would using a high smoke point oil like avocado oil or even regular vegetable oil be a better option so the oil doesn't become toxic? |
06-18-2021, 08:55 PM | #31 |
6644
Rep 2,329
Sure, the other oils will be fine. There is so little EVOO on the screen, and it burns off so quickly, the quantity of smoke is inconsequential. Any oil will do.
paquet629.50 |
06-18-2021, 08:56 PM | #32 |
6644
Rep 2,329
tranquility3290.50 jmack550.00 |
06-18-2021, 09:09 PM | #33 |
170
Rep 1,843
I've restored a lot of cast iron cookware (as in if I find an antique in a thrift store, I will strip it, run it through the electrolytic tank, and start over as if it were new) and I just use plain ol' Crisco at about 450F for my seasoning. I also wouldn't use the parchment paper just a little bit of oil. that will improve the seasoning over time. Actually have used large CI skillets to bake deep dish pizzas, works fantastic! then you can use it to cook breakfast in the next day.
chassis6643.50 |
06-19-2021, 07:34 AM | #35 | |
6644
Rep 2,329
The cheese looks way to thick for my liking on the photo you posted. Pizza is a balance of getting what you want on it (toppings) and getting it all cooked properly. The edge of the crust often burns before the toppings are cooked. Raw and sloppy toppings are...yuck. A true pizza deck oven or wood fired oven is the gold standard. Any household oven is an approximation of the deck oven. A heavy pizza stone helps. My mitigations to avoid burning crust (I don't have a deck oven) and cooking the toppings properly: - heavy thermal mass under the pizza. I use an induction 12" sautoir, it's heavy. I have used a stone in the past with equally good results. Preheat the oven for minimum of 45 minutes with the thermal mass inside before baking. I still seek a more "done" bottom crust. I like crunchy, but not burned, crust. - thin and evenly spread layer of toppings. "Meat lovers" and similar pizzas don't really do very well in a home oven. They can become lakes of cheese and grease with uncooked veggies. - Highest oven temp possible. Mine goes to 550 deg F. - A touch of broiler at the end, if needed. My pizza builds are thin enough that everything is cooked without using the broiler. Heavier topping loads will need a touch of broiler. Summary: it's a balance. Don't load a mountain of toppings. Spread the toppings ultra-evenly. |
06-19-2021, 11:02 AM | #36 | |
sportscars only
3291
Rep 3,211
My fault w the cheese as I usually don't use that much, just that I wanted to finish my bag of mozzarella and just plunked it all down. |
06-20-2021, 08:06 AM | #37 | |
630
Rep 433
(I looked at silicone and teflon liners and the concept seems good, but the available products just seem bad - so far..) ps: MORE CHEESE. MORE CHEESE. (i'd do the same - finish the bag) |
06-20-2021, 10:08 AM | #38 | |
sportscars only
3291
Rep 3,211
I realize lots of ppl cook 'naked', put food directly on the rack and for sure it cooks better but I don't wanna deal w the mess. Even lining the bottom of the oven I'd still need to clean it due to drippings, etc+the rack itself, so I always use a pan+line w parchment paper. |
paquet629.50 |
