bimmerpost/
BMW M2 and 2-Series Coupe
BMW M2 Forums 2023+ (G87) Issues, Repairs, Warranty, TSB, Recalls
      04-25-2024, 06:21 PM   #1
shatty
Drives: 2024 M2 6MT Alpine White
G87/RSA/Dealer warranty and parts
So my brake actuator froze. Had RSA tow car to local dealer. They said non warranty and charged me 199 diag fee. BA was physically damaged. Bought the actuator for 120 and did myself. When I picked up from dealer I smelt the clutch burning. 1 month later I still smell it. Not slipping Works fine. I bring to dealer where I bought car. Dealer #2. They said engineer has to come look. They said flywheel was overheated and discs were a little messed up. They said bmw would warranty labor but I have to pay for parts. 2000 which is for clutch kit and FW. I called CS and complained that RSA or dealer 1 did this to clutch. Bmw said they will escalate to RSA and not warranty parts. Now dealer 2 told me 2k for parts. If I buy from other dealer online it’s 1400. Dealer said they won’t install other dealers parts. Only theirs cause they warranty work. Is this true if it’s BMW oem parts? Waiting for call from CS on escalation results. I can’t prove that dealer 1 and RSA didn’t put car on roller wheels to get into svc and that’s how clutch went bad. Should I replace clutch? Can I buy from other dealer and have them install if BMW is warranting labor? Since they took the transmission apart, do I have the option of pulling it out of that dealer that wants to sell me The parts for 2000 and bring it to the other dealer that’s going to charge me 1400 and will Bmw still warranty the labor since they’re doing twice the work basically
2024 G87 M2. Alpine white. Black seats with Mcolor sides. 6M.
      04-26-2024, 07:29 AM   #2
shatty
Spoke to BMW CS last night, they said wait for the case manager to get back to you. I asked them if I can pull the car and have the work done somehwere else. They said it was escalated so wait to hear from them.Dealer #2 texted me this morning at 7:35a,m. "BMW officially denied the claim, we are putting it back together."
Total BS because I called and spoke to serv manager and he said you are getting a bargain to replace the whole assemble. I said I know but give me 24 hours to decide. He said its because they want the loaner back. So text message was a lie. BMW CS said do not let the dealer push you around and wait to hear from the case manager. I need to know what people have experienced and and ideas would help.
      04-26-2024, 05:02 PM   #3
Mr. Hankey
Christmas Poo
Mr. Hankey's Avatar
1070
Drives: an old Ford
First of all this stinks. I see you're not getting any replies so I won't be much help but seeing as there was damage to the brake actuator I think you likely have no case with warranty. Whatever happened to your clutch is pure speculation unfortunately. Could be towing or the dealer dragging it in gear, more likely there is something interfering with clutch disengaging from the flywheel. Is there damage to your transmission slave cylinder as well? Did you do the valve delete by chance? Did you hit something that might have hit the brake actuator and a hydraulic line or the transmission slave? Are you using a clutch stop that is too high?
g87
