      01-09-2021, 11:12 AM   #1
andrewsmith335i
Drives: 2015 BMW X3, 2009 BMW M3
E46 M3 buyer help needed!
Hello all, I am currently looking at a few e46 m3s I would like to buy. I know that the post LCI cars are better in terms of rod bearings, but what about the subframe? Did BMW ever improve it over the course of M3 production?
Also if anyone has gone from E9x 335 to M3 how was the transition?
      01-12-2021, 09:44 PM   #2
eljay
1444
Drives: ///M + E91
Every S54 will need rod bearings eventually. It's a maintenance item, so count on it.
Subframe is hit or miss. Some cars have issues, some don't.
On top of that, VANOS will need to be serviced. These are the big three items. The rest is maintenance like any other car.
Is it worth it? 110%.
JayR_e92239.00
daxbox57.50
      01-29-2021, 04:23 PM   #3
WestBankM4
WestBankM4's Avatar
Palestine
248
Drives: '19 M4CS
I don't think pre or post LCI cars are exempt from rod bearing failure. It's been a problem that plagues the V10 M5's and M6's and plenty of other M production models.
Something important to note is that if/when you're doing a rod bearing replacement on a pre-facelift E46 S54, BMW doesn't sell the rod bolts (M11) separately because they're suppose to be paired with the con rod, and I'm assuming BMW wants you to shell out for new connecting rods if you were replacing the bolts, because they're meant to be together for life. I personally would re-use the rod bolts on pre-facelift M3s because they're paired to your rods, I've never heard of anyone blowing their motors because of bad rod bolts, have you?
If you're buying a facelift M3, they have the (M10) bolts and they are absolutely able to be replaced with OEM or aftermarket bolts. They're a tad bit more difficult in terms of the tightening sequence, so a lot more people go with the ARP bolts in this case. You'll definitely need a stretch gauge to do it accurately if you're going with that facelift S54 rebuild.
IG: westbankm4
2019 F82 CS
2003 E46 M3
      01-30-2021, 12:00 AM   #4
daxbox
Drives: 991.1 50th, E46 M3, F87 M2
On the rod bearings, case in point: my M3 is a 2005 with 64K miles, and just got the rod bearings done last week... check out the wear:
'14 911 50th Anniversary Edition
'05 M3
'17 M2
'12 Q5
'16 4Runner
      01-30-2021, 12:46 AM   #5
JayR_e92
JayR_e92's Avatar
239
Drives: '08 6MT e92 M3.
Don't mean to hijack this thread, but prior to doing your RB's did you do consistent oil analysis to keep an eye on them? If so what were your results like leasing up to the rod bearing job
Thanks
Jet Black E92 M3 DCT (sold)
Space grey E92 M3 6MT (sold)
Black Sap. F15 xdrive35i M Sport (Daily) current
Titanium silver E46 M3 (OEM project) current
      01-30-2021, 09:49 PM   #6
daxbox
Thanks
I just recently purchased my M3 from its first owner just last December, but previous owner did have the blackstone analysis done at every oil change; results were always normal. But, sooner or later, it'd need to be done so my thinking: As rod bearings are wear items @ every 100K, for peace of mind, I just pressed the reset button a bit earlier. And since I don't plan to add 100K on the car (at least during my ownership), I won't have to worry about it in the future, and track days will be more worry-free.
'05 M3
'17 M2
'12 Q5
'16 4Runner
JayR_e92239.00
      01-31-2021, 06:26 PM   #7
JayR_e92
JayR_e92's Avatar
239
Thanks
Nice - and there's nothin wrong with that we can never be TOO sure so it doesn't hurt to do them anyway like you did.
I was just curious if the results had started to show more contamination right before doing the rb's in the oil but it sounds like the results were clean and consistent and you decided to do them anyway just for peace of mind.
Not a bad idea 👌🏽
daxbox57.50
