11-08-2020, 08:47 PM | #1 |
Rep 56
2003 BMW E46 M3 Laguna Seca Blue Slicktop 38k miles
Now live on Bring a Trailer - 2003 E46 M3 Laguna Seca Blue! 2003 BMW E46 M3 LSB Slicktop 38k mile 2003 M3 38400 miles Laguna Seca Blue Black Nappa Interior Manual HK Stereo No sunroof (slicktop)! Xenon headlights Cold Weather package 19” Style 67 wheels Power memory seats 2 Owner clean Carfax Have maintenance records Located in Minnesota(car has not seen a winter) Extremely clean example overall - one small door ding and two spots on the rear bumper were touched up while in the care of the previous owner(by hand, not resprayed). Rear bumper looks to have been repainted(its been wet sanded), color match is correct as both bumpers and side skirts are all very slightly more green due to flex additive. The rest of the car looks perfect and has the correct amount of “orange peel” that BMW is known for, no overspray found between any panels nor signs of removal. All VIN stickers are in place, as well as all window branding. Very few chips in the paint, and no noticeable deep scratches. Paint has been maintained, corrected, and coated with Gtechniq CSL ceramic coating. This is a Minnesota car but has never seen winter and not much rain, underbody is very clean with all the original spray coating intact. No cracks in the rear subframe, but always something to consider getting done if you plan on driving the car spiritedly. VANOS bulletproof was just completed along with valve adjustment - its a very quiet S54 at the moment! Car was originally SMG, but I also just completed the manual swap so everything related to shifting the car is new. Most people call this a manual transmission swap, but really its just a shift linkage swap. SMG shifter comes out and manual shifter and pedal goes in, so the transmission is completely original. Clutch was like new so I did not change it, better to keep the unit that’s broken in the flywheel. Recent Maintenance(last 100 miles): -Full VANOS bulletproof using Biesan parts -Valve adjustment -Valve cover gasket(BMW) -Engine air filter (Mahle) -Cabin Air Filter (Activated Charcoal version) -Spark plugs(NGK) -Coil packs (all using Bosch) -ICV cleaned -Brake fluid flush(BMW fluid) -Oil change (Castrol) -Transmission fluid change(BMW Fluid) -Rear differential fluid change(BMW Fluid) -Front Control arm Bushes (Lemforder) -Accessory and AC belts (Gates) -Both headlight bulbs -Sway bar bushings lubricated -GM5 Module repaired with new relays(Door lock controller) Modifications: -Autosolutions 0% Short Shift Kit (same height as oem) -Coby wrapped steering wheel Look for the car on BaT in the coming weeks Videos: https://youtu.be/2a8pis9yJ_M https://youtu.be/fwLRZfv9Vxo https://youtu.be/PQ8SOkQCem8 https://youtu.be/EeE0UtscEn8 Last edited by HenryChinaski; 01-15-2021 at 03:56 PM.. |
11-08-2020, 08:52 PM | #2 |
Rep 56
AlpineBoost3927.50 |
11-09-2020, 10:09 PM | #4 |
1101
Rep 2,114
Bump for a fellow Minnesotan!
IG: SirLanzelotte
Individual Atlantis Metallic G80 M3 Competition xDrive 2015 Audi Allroad P+ Brilliant Black/Black Past: F80 M3/Z4MR/E46 M3/Z4MC/Z3MR/335Xi |
11-17-2020, 07:36 AM | #6 |
731
Rep 1,732
This would decimate all on BaT...Crazy to think there are still examples like this floating around even 15+ years later
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
11-19-2020, 12:16 PM | #7 |
Rep 56
Thanks all for the comments!
Quick note - I found out BMW sent me the wrong clutch switch causing the cruise control to not function(the car thinks it works so no codes came up). This was an error on their part as they erroneously superseded the correct part. New switch on the way |
11-25-2020, 03:36 PM | #9 |
Rep 56
01-08-2021, 11:46 AM | #13 |
Rep 56
Updated, not sure what happened but after the new year started receiving a lot of offers.
Car is only available through the coming auction on Bring a Trailer |
