      10-12-2021, 01:12 PM   #1
chef423
Drives: E90
Replacing SMC require coding?
I am getting code 9CC1. 'Stepping motor controller (SMC), left, signaling fault.
The right side light SMC was totally corroded, so I replaced it with an Ebay version...code went away. But the 9CC1 was there as well, so I decided to swap the two to see if the code would go away on the left, but now I am getting codes for both the left and right (HUGE eyeroll)
9CC1 (explained above)
9CC2 (right SMC)
9CBF 'Communication with step motor controller on the left disrupted'
I am using ProTool and I have the coding module.
Google for 2 hours no help on this...
Before and after screens attached.
      10-12-2021, 01:32 PM   #2
chef423
Drives: E90
Disregard. I found the coding it was a few menus deeper....
      10-12-2021, 02:00 PM   #3
Merlin_83
Merlin
Merlin_83's Avatar
Drives: 2012 BMW M3 6MT w/ZCP
2012 BMW M3 ZCP  [0.00]
2008 BMW 335i  [0.00]
2008 BMW 335xi  [0.00]
Curious, what does the SMC 'control' ? What is it's function ?
Stepping motor is similar to a servo, yes?
2012 E92 M3 ZCP | 2008 E90 335xi | 2008 E90 335i |
      10-12-2021, 04:25 PM   #4
chef423
Drives: E90
Assuming moving the headlights moving back and forth when you turn the wheel.
      10-13-2021, 01:34 AM   #5
maron
maron's Avatar
74
Drives: E60&F06
Yes. You need to code SMC in NCS
      10-18-2021, 11:09 PM   #6
chef423
Drives: E90
Coded them with PROTOOL and my light still dont move left to right....GRRRR (no codes)
