12-06-2007, 01:58 AM | #23 | |
1153
Rep 8,027
Need I say more. |
12-06-2007, 02:08 AM | #24 | |
57
Rep 590
"Try pulling away quickly with X-Drive and the rear wheels slip briefly before the fronts are brought into play, try the same with Quattro and there is no slip" That would be better for weather conditions, but not on a track were no slip = understeer I gave my opinion EVO AWD > X-DRIVE > Quattro , based on track performance not on bad weather driving
12-06-2007, 05:57 AM | #25 | |
1153
Rep 8,027
As for Quattro only having understeer on the track, sorry this is again another misunderstand of the product, if driven properly Quattro handles just the same as an EVO, you just need the skills to unlock it. As for Quattro being slower on the track even when not driven like the above video shows, it will still be quicker in the right hands though admittedly I am not capable of driving it to such abilities. I not here to knock you down only to help explain that while boring compared to rwd in non-skilled hands the car is every bit as quick if not quicker than rwd. |
12-06-2007, 06:51 AM | #26 | |
I'm just here for the turbo
Rep 327
AWD adds weight and cost,\ and has more power loss through the drivetrain. All things being equal (as in 335i vs 335xi), the 335i will be the better performer on any kind of track because it weighs less, has less drivetrain losses, and is better balanced with less understeer. Now if you take these two cars, make them weigh the same, make them equally weight balanced, and up the horsepower on the AWD model so that it puts the same power to the ground as the non-AWD model, then maybe the AWD will be the better performer. But this can only happen in fantasy-land. And, yes, your precious Audis understeer like pigs (just like my STi and most/all other AWD cars). Can you cause oversteer by mashing the gas pedal in the middle of a turn? Sure. But AWD cars are naturally setup to understeer.
Current Rides: 2007 BMW 335i Sedan 6MT Montego Blue, 2004 Subaru Impreza WRX STi (for sale), 2004 Mazda RX-8 6MT
Fondly Remember: 1988 Porsche 924S, 1992 Mitsu 3000GT SL, 2001 BMW Z3 2.5i |
12-07-2007, 03:09 AM | #27 |
57
Rep 590
"if driven properly Quattro handles just the same as an EVO"
I have to disagree, if you watched those videos carefully you'll notice that the S5 went around every corner sideways, he always lifted, makes me wonder Look at the EVO taking those corners, you will see how differently he takes the corners with both cars. And in that Topgear video you can clearly see that the S4 under steering, in the dry, when its not sideways around corners. There are plenty more videos were Jeremy talks about how Quattro tends to understeer, and a video of Tiff nedle reviewing the R8 were he mentions that unlike previous Audis the R8 doesn't understeer on the limits, it actually oversteers. Watch them.
