11-25-2022, 11:37 AM | #1 |
Rep 28
2005 Mystic blue/Black nappa, low miles
Wanting to sell my 05 Mystic blue, SMG, coupe with 74,600 miles. Have owned it since August 2021 and has been my daily driver since then. That being said, I have enjoyed driving it daily as it has been maintained properly and has taken me everywhere with no hiccups along the way. Reason for selling is I now have another daily Photos located here: https://photos.app.goo.gl/hSsj4qBx1cDYgAst6 Asking price: SOLD Located in Cumming, GA Clean GA title in hand, have Carfax on file and can send if interested 2005 Mystic blue on black Nappa leather SMG transmission ~74,600 miles Production date: 2005-01-27 Vin: WBSBL93475PN61743 If you have any questions, don’t hesitate to pm me, motivated to sell so pm me with offers. Main bullet point items: Vanos fully rebuilt using Besian parts, Cam bolts were also replaced with updated part numbers Subframe partially reinforced with a Mason X-brace, will include PSM reinforcement plates with sale. Rod bearings not done Maintenance: Oil changes every 3000 miles with LiquiMoly 10w60 with Mos2 additive every change (65,977… 68,145… 71,333… 74,425 ) Differential oil change with the proper OE BMW fluid (63,420) Parking brake components refreshed (64,500): - brake shoes, - parking cables, - adjustment screws, - backing plates, plus more Vanos bulletproofed with Besian parts (65,944): - upper chain guide, - Vanos solenoid, - oil pump disk, - plate seals kit, - seals repair kit, - valve cover gasket and other seals, plus more Cooling system and supporting parts refreshed (68,145): - new thermostat, - aux fan switch, - oil filter housing gasket, - hi-temp o-ring kit, plus more Transmission components refreshed (69,534): - new clutch, - new flywheel, - replaced all compression springs, - new clutch pilot bearing, - new steel pivot pin and slutch fork, - new guibo, - transmission input and output seals, - transmission mounts, - fluid, plus more Fuel system components refreshed (70,436): - fuel filter, - tank cap, plus more Power steering fluid flushed (70,436) Cabin air filter replaced (70,436) New brake rotors and pads all around with brake fluid flush (70,953) Sway bar links replaced (72,837) Fan clutch replaced (74,425) Spark plugs replaced (74,420) Side finisher rubber trim and window rubber trim replaced (74,430) Plus more maintenance items serviced/refreshed Upgrades Active auto headers HTE tune (passes emissions) SAP deleted AFE intake filter and intake boot Bimmerworld solid rear RTABs Bimmerworld stainless brake lines S2R Carbon fiber sunroof delete Euro wing mirror glass OE alarm retrofit Eonon apple carplay headunit with dynavin relocation bracket Plus more parts upgraded/refreshed Cons: Passenger side door has a little dent from a door ding, however, is a soft dent (not a sharp crease) and can easily be pulled out by PDR Front end has endured rock chips from daily driving, have filled them in as best as possible with mystic blue paint pen Previous owner installed the carbon fiber sunroof panel and went a little too far with the screws at the rear but didn’t penetrate the roof. As a result, there are two small dimples. Was planning on doing a carbon fiber roof so purchased a US-style slicktop headliner in advance. Can include it for extra Last edited by HDM3; 12-20-2022 at 10:37 AM.. |
12-15-2022, 01:37 PM | #3 |
3981
Rep 2,660
Drives: 2019 BMW 540
That's actually a pretty decent price. Now if I was still looking for one, I'd be all over this. GLWs!
Current: 2019 BMW 540 (AWD)
Sold: 2009 BMW 328 (AWD) |
