      08-12-2021, 07:38 AM   #1343
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Originally Posted by hybrid_eg View Post
perfect time to add LED cabinet lighting and on the toe kick if you havent already done so
i have LED's on top but debating if i should install some under the cabinets. never thought about the toe kicks. how would i do that?
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      08-12-2021, 08:27 AM   #1344
King Rudi
King Rudi's Avatar
13154
Drives: Meat Suit
Originally Posted by lsturbointeg View Post
couldn't believe they wanted to charge me $800 to demolish the kitchen before they install the new Quartz counters. so being the handy man i did it myself. i would have been pissed if a contractor came in and did it and i was like "that's it?"
Dude, anytime you post pics of your house, I get the itch to work on mine....(and a slight case of envy). Beautiful home and garage sir.
Originally Posted by jmg View Post
We're Americans. Leave your logic and science witchcraft out of this! Jesus and guns are all we need.
Appreciate 3
      08-12-2021, 08:45 AM   #1345
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
i'd hire him to do my garage.
King Rudi13154.00
      08-12-2021, 11:22 AM   #1346
lsturbointeg
thanks Rudi! appreciate the kind comments
haha that would be sweet to do
King Rudi13154.00
      08-12-2021, 11:26 AM   #1347
lsturbointeg
so here's some install pictures going on right now!
these brackets are very expensive as it allowed us to go an additional 16" past the cabinet without using leg supports which i think get in the way with chairs. each supporting bracket was $250
we already have some subway tiles picked out so i'll be working on that some time next week. i'll post some pictures when i do
Appreciate 4
King Rudi13154.00
Buug95917424.50
Gregrobin578.00
nyalpine907433.00
      08-12-2021, 12:10 PM   #1348
lsturbointeg
okay so they just finished. they also installed the stainless steel sink which is much deeper, wider and depth compared to what we had before. this is also now a single bowl instead of a double bowl
Appreciate 9
King Rudi13154.00
MoeTE87656.00
RickFLM410981.00
Buug95917424.50
nyalpine907433.00
      08-13-2021, 12:50 PM   #1349
hybrid_eg
hybrid_eg's Avatar
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
Very easy!! Its actually a fun project and looks super clean.. as long as you have basic electrical knowledge you can do it yourself. I think Toe kick LED complements the upper cabinets very nicely and in the evening hours you can just run those lights as it gives off a very relaxing vibe. I do recommend running the same LED strip to ensure color is the same.. now that you did white quartz your undercab is going to pop a lot more
Since you already have undercab on a switch you need to get the low voltage wire from the undercab down to the toe kick.. i usually route inside cabinet in the corner and use these plastic clips to keep the wire organized so its not noticeable.. once the wire is down in the correct location, install aluminum channels, tape the strip inside channel put the cover on top.. done deal.. I also suggest getting these LV transformers as they have "soft on / soft off" for the ultimate pop when they come on..
you seem to do everything yourself so i'll just post the amazon links and i'm sure you'll know what to do
i have back lighted just about everything.. love the look.. i.e. baths i have them hooked up on vacancy switch so as soon as you open the door they are coming on.. no need to turn the light on.. and set to turn off in 3 min if no motion is present.. back light mirror and toe kicks..
LED strip: Buy as much as you need
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
LW Wire: Run from transformer to your LED strips
Misc Connectors: If you dont want to solder you can use these to attach to LED strip then just use butt connectors to connect to LV wire.
LED mounting channels with covers:
MISC connectors: If you're back-lighting a mirror these are useful so you're not bending the strip instead you will cut 4 pieces of strip and use thee to connect to your LV feed. No soldering
Solder butt connectors: The best, you just need a cig lighter.. use this to connect misc connectors to your LV feed wire for best connection
Wire cable organizer: For inside cabinets, etc for your LV wire feed
LED Transformer - Check LED strip length and calculate wattage you need
https://www.readyelectricsupply.com/...iversal-driver
Retired: '02 E46 M3, '02 E46 M3 Vert, '11 E90 335d, '15 F10 M5, '17 F85, '18 F90, '02 E46 M3, '21 F96 Comp
Appreciate 5
dtox9336.00
Kilabyte3948.00
hubbahubba8837.50
      08-13-2021, 01:01 PM   #1350
hybrid_eg
hybrid_eg's Avatar
I forgot to add.. I would also add it under your island front overhang.. (not on island toe kick as it would be too much) I see your island already has power so it should be super easy..
Then just get some Lutron Caseta Wireless dimmers and you're set.. get them all on a schedule 30 min before sunset and off whenever you like.. throw some screwless Lutron Claro wall plates for the icing on the cake..
      08-13-2021, 02:03 PM   #1351
lsturbointeg
dude thanks so much! i'm definitley gonna do this. i'm still not understanding toe kicks tho lol
      08-13-2021, 03:00 PM   #1352
hybrid_eg
hybrid_eg's Avatar
so if your undercabinet LED lighting is a "strip style" then you have a low voltage wire that feeds the strip from wherever your transformer is located. If its not strip style and you just have LED tube style bulb in those big fixtures, you can rip all that out and replace it with strip lighting which looks much cleaner..
Regarding toe kick, all you need to do is add another low voltage feed from your transformer and bring it down to toe kick area. Easiest way is cut a hole in back of cabinet so you can fish the wire from upper cabinets into lower. Once you're in lower cabinet just run the wire on inside of cabinet corners and come down to toe kick where you make a little hole and feed the wire into it. Then you install your aluminum channels and connect it to your feed. Since you have dishwasher / stove also running in toe kick all you do is daisy chain the LED strip from toe kick and you move from one cabinet to the other.. PM me with any questions.. Also here is a marked up image of one of your pics and how to route the wire and where to mount the aluminum channel. The channels come with plastic clips which hold the channel in place.. ive also included finished photos of what i did at my place to give you an idea of overall look.. put it this way i never need to turn my recessed lights where i have LED it produces that much light..
Appreciate 8
Buug95917424.50
nyalpine907433.00
jmack548.50
      08-13-2021, 08:05 PM   #1353
Turkish Pickle
Drives: '21 330i xDrive
(pics)
Do you know the brand/model of those LED strips? Those are super bright!
      08-13-2021, 08:23 PM   #1354
hybrid_eg
hybrid_eg's Avatar
Yes I provided links in the previous posts
      08-15-2021, 05:39 PM   #1355
lsturbointeg
appreciate all the info you provided. now i'm looking at how to do this
      08-15-2021, 08:12 PM   #1356
lsturbointeg
so here's a few back splash tiles we were trying to decide to go with
so we ended up going with this!
RickFLM410981.00
      08-15-2021, 08:59 PM   #1357
RickFLM4
RickFLM4's Avatar
Drives: M4
I like your pick.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      08-22-2021, 04:25 AM   #1358
sandykostin
Drives: BMW X5
I think you did a great job; you're just great. I am also watching various training videos on arranging my own house since I plan to buy my own home soon. After all, I am already 28 years old; I have a wife; why not start thinking about children? But this is possible only when there is decent housing. So far, I am only studying various services and offices that can help me buy a house, but I have not decided what service I have to contact. My friends recommended affordable house and lot to me, as they used the services of these people and were satisfied. So far, I'm still looking closely, so if you have any thoughts about this, I will be happy to hear any thoughts from you
      08-22-2021, 08:29 AM   #1359
lsturbointeg
just started laying the backsplash tiles and so far easy peasy!
Appreciate 3
shimmy232350.00
Buug95917424.50
jmack548.50
      08-22-2021, 12:22 PM   #1360
jsf721
Drives: 2019 540i X M Sport
Fixed a break in the sprinkler line
      08-24-2021, 11:25 AM   #1361
Maestro
Drives: 2007 335i Sedan, 2021 X3
Hate to critique other people's work,
First I never seen foam sprayed in around electrical outlets, most foams are not rated in that kind of applications. This could be an issue since foam can absorb water over time from the environment and I would recommend removing it. If this was done for cold air reason the foam should have been put in around the outside the plug box to prevent air going through the outlet box.
Next and this would have made your life a little easier especially when you go to put covers on the outlets. The tile on the top and bottom of the outlets should be under the metal tabs of the outlet. You want the outlets mounted flush and tight against the tile. Otherwise your outlet will be floating when you place the outlet covers on the outlets and will move around when you try to plug and unplugs thing and eventually the outs may break. Trust me on this, the previous owners of our house did it your way and I had broken cover plates and outlets over the years. We just remodel our kitchen and redid the back splash and I made sure the plug tabs sat on top of the tiles and they mounted firm to the tile surface. It does require longer screws and Lowes and Home Depot carry them.
      08-24-2021, 12:03 PM   #1362
Bongoxxx
804
Drives: 2018 340 XDrive
Would also add that the plugs pictured are installed upside down.
Current: 2023 Volvo XC60 B6 Ultimate Thunder Grey on Blonde Polestar Enhanced
Previous: 2018 340 xDrive M-Sport Mineral Grey
Previous: 2016 328 xDrive Alpine White
      08-24-2021, 03:40 PM   #1363
Maestro
Yeah I missed that too..
      08-24-2021, 03:47 PM   #1364
vreihen16
Recovering Perfectionist
vreihen16's Avatar
Drives: 2015 BMW i3 BEV
I disagree. Most North American outlets are installed upside-down, but those are not!
From an electrician that I trust, the ground pin should always be on the top. The reason he gave was that someone dropping a conductive item near the wall where a plug wasn't 100% seated will have that item hit the ground pin first, and then short to either neutral or hot as it falls. He claimed that it provided the best chance for popping the breaker, instead of shocking a person trying to catch/retrieve the item.....
Appreciate 4
Buug95917424.50
lakefront560.50
Th3Walrus340.50
jmack548.50
