      12-29-2009, 09:53 AM   #1
Zak James
Drives: Black BMW M3 E46
BMW M3 Jump start wrong way
Hi,
Can anyone tell me if they know what could be wrong with my car. I am a complete novice but jump started numerous cars including his one before. I wired up jump leads to my car the correct way but the wrong way on the other car. Trie to jump it and then noticed leads smoking so quickly took off jump leads. Then the car would not start. I called RAC and the guy tested the lead to the fuel pump which has no power. He has freaked me out a bit because he said the CPU could be fried which even I know will be a lot of money. Has anyone ever done this and what is the most likely scenario. i.e. which electrics would be out and is it likely to cost me a fortune. I have a E46 M3, 60,000 miles. Lights still seem to be working and engines turning over but just no fuel pump going.
I appreciate any advice.
      12-29-2009, 10:08 AM   #2
artifice
artifice's Avatar
Drives: 2008 E92 M3
Maybe just some blown fuses... ? Could be a bunch of small electrical problems, including a burnt up starter... Just check the fuses first. I'm not sure of how much of the "start-up" electronics are fused or not, but I'm sure you can find something in the manuals.
      12-30-2009, 09:01 AM   #3
BigGuyM3
BBM Pin# 295E3EA9
BigGuyM3's Avatar
Drives: 2010 BMW M3
Thats a good point, also check if you have voltage at the battery and if the motor is turning, you may just have a bad fuel pump, I dont think you fried your computer, i would start with the basics (Fuse, battery, wire connections, fuel pump.
