01-22-2013, 12:58 PM | #1 |
BMW Fan
147
Rep 315
e46 m3 rear-view mirror Q - fluid in auto dimming mirror??
Just noticed this on the car, it just happened suddenly. What is this and how do I fix it? If I have to replace it to fix it, about how much $ would that cost?
It's like the top 20% is not auto dimming anymore, and there is a fluid line in the middle. |
01-22-2013, 01:29 PM | #2 |
915
Rep 3,456
Drives: Harrop E90 M3
You have to replace the mirror to repair it. They an be expensive, so you may look around for an oem mirror to replace it with that's lightly used and in good condition. I think they're around $500, but check with your local dealer to verify that.
01-22-2013, 02:39 PM | #3 |
Rep 1,470
Had the same thing on an Acura but it was under warranty. It cannot be fixed. It has to be replaced. Better do it soon as well. I had that fluid drip out onto the console.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
01-25-2013, 05:49 AM | #4 |
Rep 240
Get in touch with Sybesmas Electronics. My rear view mirror leaked over my console and ate away some of the finish, nasty stuff in there. They do refurbished mirrors for about $90.00, had mine done by them and it's like brand new. Send them yours.
01-25-2013, 05:55 AM | #5 |
Rep 240
Sorry, should have added this: http://sybesmas.com/site/
02-25-2013, 02:00 PM | #6 |
Rep 915
this, i did the same
03-15-2013, 12:06 PM | #7 | |
Rep 114
05-06-2013, 06:43 AM | #8 |
Global Moderator
6381
Rep 2,309
Drives: E90 M3 6MT
Common issue on E46s, there are many OE replacement ones or other aftermarket with radar detectors and so forth. You can even replace it with the homelink mirrors from the newer BMWs.
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread |
