01-24-2022, 12:06 PM | #24 |
Rep 783
Thanks! Yeah it was a huge huge relief for me.
Also seemed to have found a Ford Racing speedometer correction box in the engine bay - suggesting the vehicle might be rocking 3.73's. I'll have to get on the highway and see what i'm turning for speeds. That would also potentially suggest why my MPG was down a touch on the way back home. Got JUST over 20 on a 22 rating, and I'm usually pretty good at nailing or beating EPA estimates.
Mosselman-powered M4 - 698/714 | 2.9 Whipple 2004 Cobra - 690/645 | Instagram
01-25-2022, 03:10 PM | #26 |
Rep 783
Haha thanks, mustang crew checking in over here.
Just ordered a few "necessities": - Eibach pro-kit springs - Koni SA shocks - MM camber plates Should drop it 1" in the front and around 1.5" in the rear. That's about enough for me given how these things ride anyway. Also picked out some wheels since I need some rear tires anyway. I found a cheap single wheel in the right size on eBay so I snatched it up and we'll see how I feel about the color/fitment before moving forward.
01-29-2022, 06:54 PM | #27 |
Rep 783
Few "small" updates and one surprise!
First, I had to replace the cracked 3rd brake light - was driving me crazy being all broken on both ends. Also, lol, yes I AM going to get the car registered. I'm just waiting for emissions testing to 'officially' end in my county on Feb 5th. I'm not sure that i'd pass even with the high-flow cats and readiness codes. Surprise! Not a build for the domestic purists over here. 18x9.5 +15 fronts and 18x10.5 +15 rears. Going to run some MPSS 295/35 rears and maybe some 275/40 up front. 18's are quickly going out of style with manufacturers lol but 19's look like hot garbage on this platform IMO.
AlpineBoost3927.50 |
01-30-2022, 06:15 PM | #28 |
Rep 783
Well, I think thinks turned out pretty well. VERY happy with the drop and how it rides/handles so far. Desperately needs an alignment but otherwise I think we're moving along.
Got all the wheels in - waiting on tires and then i'll do the alignment, tire swap, mount/balance and all that.
01-30-2022, 09:54 PM | #30 | |
Rep 783
Ohhh yes we are going to detail, you can tell how dirty that thing is in the pics lol. We've been having some pretty rough weather but as soon as the M4 is back from the shop i'm putting this car into the garage for some paint correction and actual detail work.
P111590.00 AlpineBoost3927.50 |
01-31-2022, 11:08 AM | #31 |
2598
Rep 2,434
Drives: 2021 M2C
I had a 2004 SVT Cobra. Loved that car until I wrecked the shit out of it lol
02-03-2022, 11:48 AM | #37 |
Rep 783
haha yeah same, there's really no way around *not* lowering them, and then when you do you run into a lot of clearance issues. Nose is pretty long and bumper is low, plus all the room you need for the exhaust, etc.
JP102466.50 |
02-06-2022, 08:37 PM | #38 |
Rep 783
Quick wash and minor detail. This thing needs a FULL paint restoration and cleaning. It's going to be a lot of work tbh.
Looks good in the shots but it's rough around the edges. Have at least one oil leak pinned down, but looks like maybe the front timing case cover is seeping a bit. I have some pretty major work to do here and there.
02-07-2022, 04:22 PM | #40 | |
Rep 783
Once we're not leaking vital engine fluids lol, i'll turn back to making sure the motor has been tuned appropriately with the given mods.
0-60Motorsports793.50 |
02-07-2022, 04:31 PM | #41 |
Rep 783
Current attack plan:
At some point i'll need to do a clutch since the TOB is making some noise, but i'm going to ride that one out a while since when I do that i'll need to do a 26 spline input shaft, etc etc and that gets expensive quickly - just like doing the fuel system.
02-07-2022, 09:39 PM | #43 |
Rep 783
Definitely planning on it, I ordered a new overhead LED light stand so I could work better and get some good pictures. My garage ceiling is so tall that the overhead lights just aren't enough
02-09-2022, 11:59 PM | #44 |
Rep 783
Few little updates here and there. Definitely having some driveline issues that look/feel like they're clutch related. Not surprising at all given how problematic the systems are, but I don't really feel like pulling the trans off and spending where I need to spend there.
Here's a quick video of the ticking noise that i'm hearing. You can hear it change pitch and almost go quiet when the clutch is being depressed and engaging. I've started to worry about the tune a little more so I went ahead and ordered a SCT X4 and a custom base tune from JDM Engineering. That should at least get me started until I get my A/F logging and gauge set up since that's a whole thing in itself. Once that's done, oil cooler leak is stopped and I pinpoint other leaks I may have to pull the trans and do all the major work there. If that IS the case there then the work will entail: - Spec twin-disc w/ flywheel 26-spline - 26 spline input shaft (which i'll have to learn how to do lol) - lethal performance TOB retaining sleeve - FRPP TOB - FRPP shift fork - new pilot bearing, rear main seal, etc All a bunch of money in parts for sure but that'll set it up for whatever else might come down the road. Even a ported eaton may end up breaking the 10-spline input
cobra2814112.00 |
