12-05-2020, 02:51 PM | #24 |
Rep 1,062
Drives: F15 xDrive50i M-sport
It's a dingleberry removal tool for woolly mammoths.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
12-06-2020, 09:00 AM | #25 | |
dances with roads
4737
Rep 4,099
Hmmm. That would explain the aroma. |
pennsiveguy3552.00 |
12-13-2020, 12:55 AM | #27 |
5356
Rep 2,806
Drives: '09 E90 M3 - IB
The most useless tool in my garage is-me.......Im also the biggest tool....
12-14-2020, 11:38 AM | #28 |
8944
Rep 2,010
CRT (Cathode Ray Tube) pin crimper:
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
12-14-2020, 01:21 PM | #30 |
2432
Rep 2,526
What in Gods name would that ever be used for? |
12-14-2020, 02:29 PM | #31 |
Recovering Perfectionist
15401
Rep 943
Drives: 2015 BMW i3 BEV
I still have an IBM 8228 Token Ring network port setup tool in my desk drawer (image from someone else's web site because WFH):
It contains a 9 volt battery, and was used in the 1980's to reset every port's relay in a Token Ring MAU (hub) any time that they were moved or disconnected. I also have a complete 10BASE5 vampire tap kit in my toolbox at work, from back in the early 1980's when ethernet ran over RG-8/U "frozen yellow garden hose" coax as a continuous bus...with no "T" connectors or branches. I may even have a few IBM Twinax solder-on connector kits laying around.....
kb2wji186.50 |
12-14-2020, 03:31 PM | #32 | |
Rep 90
Murf99314116.00 |
12-14-2020, 03:43 PM | #33 |
15401
Rep 943
Speak for yourself! I still have an HP tube-powered oscilloscope on my bench.....
Murf99314116.00 |
12-14-2020, 03:49 PM | #34 |
3540
Rep 3,052
My O2 sensor socket has been used once and sits in the tool bag collecting dust. I'm not complaining just playing the game.
erickonphoenix1734.00 |
12-14-2020, 04:09 PM | #35 | |
18075
Rep 9,380
Just in case, I have an external USB 3.5" floppy drive, and a parallel printer cable or two. |
vreihen1615401.00 |
12-14-2020, 06:53 PM | #39 |
15401
Rep 943
Gotta let a whole new generation of wannabe techs learn first-hand why they call it a flyback!!!!!
kb2wji186.50 |
12-14-2020, 08:09 PM | #40 |
Rep 45
I don`t know, and it`s 1/2 inch . I`m not sure how it ended up in my tool box. I think it was in the garage of my first house that I bought back in the 80`s. I keep it around, It`s a "rare" tool , and it doesn't take up must space. If it came with some sort of ratchet handle I don't have it. I`ve been told by an older millwright that it belonged to a 1930`s socket set. Last edited by Dino GT; 12-14-2020 at 08:29 PM.. |
vreihen1615401.00 |
12-15-2020, 01:32 AM | #41 |
Rep 265
Probably my Eaton M90 pulley remover. I haven't had a car with an M90 in almost 9 years now.
12-15-2020, 06:51 AM | #42 |
15401
Rep 943
My Ford detailing brush hasn't seen much use lately.....
12-16-2020, 10:00 AM | #43 | |
100
Rep 433
As far as the most useless tool in my garage, I've got an old modified ratchet extension that i heated up and bend like 15* to remove the lower thermostat housing bolt on a 1988 Ford Thunderbird. You you obviously only turn it 1/4 turn, and then you had to "reset it", but I was 17, and I couldn't figure out any way to remove that bolt. I ended up buying a hardened bolt to replace it, and cut a slot in it so I could use a screwdriver the next time. |
12-16-2020, 01:05 PM | #44 |
2070
Rep 4,365
Same here, I have battery versions of the same tools that have just as much power and I don't have to worry about a tank! I would sell them if they were worth anything anymore
2007 Z4 3.0si Coupe 6 MT Black Saphire Metallic PP SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide Denim Black V&H Tune 2021 BMW x30i Phytonic Blue Metallic Fully loaded |
