02-05-2018, 09:10 PM | #177 | |
11585
Rep 5,510
02-05-2018, 09:22 PM | #178 |
Rep 1,149
Agreed, I think those numbers are a bit high for someone of his age and size. It would take awhile to get there with a lot of time and proper programming for numbers like that in Dead Squat Bench. And he does CF and they don’t emphasize those lifts. You would have to put in extra time on your own to make it happen. Especially since so much time is put towards the Oly lifts which are very technical and require proper mechanics. I will say CF has been slowly moving away from them, mainly because of the injury rate for the normal Crossfitter. But they are fun to do and watch when done correctly! Most importantly don’t get caught up chasing numbers....it can do more harm then good.
02-05-2018, 10:09 PM | #183 |
11585
Rep 5,510
02-05-2018, 10:13 PM | #184 |
11818
Rep 23,187
What's the advantage over just doing a seated press , takes legs out. I've done both standing just tends to create more back arch and can cheat as failing for more reps.
02-05-2018, 10:26 PM | #185 | |
11585
Rep 5,510
Plus in CrossFit it’s all about doing exercises that will translate to others. Standing pressing strength leads to better push pressing, push-jerks, split jerks, hand stand push ups, etc. |
smoosh2211.50 |
02-06-2018, 01:47 AM | #186 | |
Rep 1,149
The only down side is CF uses ALOT of shoulder pressing type movements and other shoulder exercises in consecutive workouts which can wear down shoulder joints quicker then normal. It is very easy to develop shoulder and elbow type injuries if you are not careful. |
02-06-2018, 05:46 AM | #187 | |
fight me bro
2212
Rep 531
It seems to be one of the weaker lifts for most people. I hit 205# strict for 2 raw a few days ago...still cutting though, so I'm sure I could hit 225#+ raw if I had enough calories in my system Personally, strict OHP is all about technique / how explosive you can be. What's helped me tremendously is keeping tight (closer grip, narrow stance, activating your core, and pushing through your balls : )...deep breath in, engage your core, activate your posterior chain, barbell to your chest, and explode up Will try to get vid next time to show what my technique is like... Edit: also, Mark Rippetoe's the GOAT. I think he's said Strict OHP is more important than bench, and I couldn't agree more... |
The Chaddening11585.00 |
02-06-2018, 08:05 AM | #188 | |
11818
Rep 23,187
02-06-2018, 09:58 AM | #189 |
11818
Rep 23,187
Did a strict press just for shits with 135, pretty easy. Guessing 175-185 probably doable.
smoosh2211.50 Mr Carrots766.50 |
02-06-2018, 10:04 AM | #190 |
fight me bro
2212
Rep 531
02-06-2018, 12:45 PM | #192 |
Rep 623
One tip that worked surprisingly well was Paul Carter's suggestion of using a thumbless grip. Not something you should ever do on a bench but it really did help my OHP
Not that I can do them at all after 2 shoulder repairs |
02-06-2018, 01:31 PM | #193 | |
11585
Rep 5,510
I read Mark Rippetoes full starting strength book, really good read. The only part I thought was odd was the importance he placed on lying tricep extensions. Dude was all about some tricep extensions. Another great read was Kelly Starretts "Becoming a supple leopard". You can basically use it as a go to anytime you have muscle pain. Simply flip through the chapter that covers that muscle group, identify the tissue being affected through a few tests, and go to corrective movements to resolve said issue. A good reminder on how I need to spend more time mobilizing... as I sit at my work desk. |
02-06-2018, 04:00 PM | #194 | |
Rep 1,149
02-08-2018, 10:00 AM | #195 |
11818
Rep 23,187
Did that strict press for 1 rep again today after deads. 175 was easy enough and think if routinely did direct shoulder work could approach my body weight. Don't see the big deal never done it before and can do 85 percent of body weight.
smoosh2211.50 |
02-08-2018, 10:10 AM | #196 | |
fight me bro
2212
Rep 531
Strict standing OHP is, IMO, the single best mass / strength builder for the upper body (shoulders, upper pecs, upper back, core, posterior chain; lats and quads as stabilizers). So I do it very often. Never do any other shoulder work, just strict OHP and strict behind neck standing OHP. Shoulders are one of my strong points, so clearly it's working. It also teaches explosiveness, which is such an important "concept" to train... |
02-08-2018, 10:23 AM | #197 |
11818
Rep 23,187
Yeah only do direct shoulder work 1 or 2 times a month, they get enough front from chest, mid from trap work and rear from lat work. I will try adding in some ohp and see how it goes.
02-08-2018, 01:12 PM | #198 |
11585
Rep 5,510
Nice work! Be sure to completely lock your arms out when overhead. Also keep the bar directly over your head, not in front of you when pressing. Your elbows should be right next to your ears.
