01-30-2014, 02:21 PM | #45 |
Emperor
1614
Rep 2,753
Yesterday I converted my fan setup from the stock aux/clutched fan to a Z4M inspired SPAL electronic puller fan setup (16" medium depth). Because fan capability is reduced, I retained the stock fan shroud to make the most of my SPAL fan. Side note, fans are only really used when sitting in traffic or for the AC compressor, so cooling capacity at speed should not be changed by the project.
I'm using the factory aux fan controller to control the SPAL speed. Because it's now the only fan (instead of an aux fan), I'm changing the ecu fan control values to that of the Z4M (which also only has an electronic puller fan). Project goals, from most important to least: longer water pump service life (as no fan/clutch wearing the bearing) no more fan/fan clutch replacements decreased weight remaining weight moved inboard decreased parasitic loss on the engine Some pics... Front bumper and ducting removed so I could pull the factory aux fan: Factory aux fan controller, which I added a plug to to connect to the SPAL fan: SPAL fan mounted on the factory shroud. I wanted it easy to remove and to not damage the radiator. This way it removed with the shroud, and just adds one plug. I reused the hardware from my trunk decontenting project (added loctite and the silver bits aren't visible once installed: And installed. These two black bolts are all you can see once it's in, and they get further hidden by the air duct that goes on top: From the other side: Saw my dealer taking this down and snagged it. A friend of mine just made this video from my bachelor party. Pretty awesome, IMO! CNF GoKart 082413 - YouTube
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
01-31-2014, 12:43 PM | #46 |
M3/Raptor
48
Rep 302
Even though I knew about much of the stuff you have done to the car (there was also much I didn't really know), reading through this makes it even more impressive. And some of the photos are just awesome.
02-23-2014, 07:09 PM | #50 |
1580
Rep 8,077
Drives: 11 E90 M3 Individual
More info on the SPAL fan...how did you wire it in?
For the lightweight stereo...I've got a car audio setup with 5 speakers. Maybe stick with a set of front comps with a neo magnet on the mid (Alpine, MBQ and JL make some) and 5 channel class D amp. Then get a decent single din and remove the OEM wiring harness. That will save you another 10-15 lbs total easily. The OEM stereo harness is pretty damned heavy for just wires.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
02-24-2014, 06:49 AM | #51 | |
Emperor
1614
Rep 2,753
I wired the spal to the factory aux fan controller (deleted the aux and clutched fan when I installed the SPAL), and had Evolve change the aux fan controller to the Z4M fan controller temp values (the Z4M has an S54 but only has an electronic puller fan, which is my current setup with the SPAL).
02-27-2014, 09:28 AM | #52 |
Emperor
1614
Rep 2,753
Two small updates:
A) I have a bimmerworld/C&R oil cooler on its way to me. Exciting! B) I'm working on devising a steering feel upgrade for the M3. My plan of attack is two fold... 1) replace the steering guibo with the joint from the e28 M5 2) replaced the 60mm centered FCABs from the e46 with 66mm eccentric FCABs from the Z4M (much like 96-99 e36 M3 will often retrofit the eccentric FCABs form the 95 M3. Guibo portion should be easy, goes from (part 2) to (part 11) or, from to For context, the Z4M shaft, bushing free (this is what really sold me on doing this and not regretting it)... FCABs are a little more interesting. The e46 M3 housing is 60mm, so the bushing isn't plug and play. The e46 non M has a 66mm bearing hole, but it doesn't have the third hold for our thrust plate (which I don't want to give up). It appears (I need to verify) that the outer diameter of the e46 non M FCAB lollipop is the same diameter as ours. If that's the case, I'm going to throw a set of e46 M3 FCAB lollipops on the lathe and mill 3mm of radius. Presto, 66mm e46 M3 fitment FCAB lollipops Z4M stock lollipop with eccentric bushing: e46 M3 lollipop with centerer bushing: e46 non M FCAB bracket (thinner walls, so... hopefully okay for us to be that thickness): |
03-10-2014, 09:29 AM | #53 | |
193
Rep 3,633
I have a set of stock old FCAB if you need; PM me |
03-10-2014, 03:17 PM | #54 |
424
Rep 5,329
incredible thread tbh..... really enjoyed slowly reading this tonight.
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
03-13-2014, 05:23 AM | #57 |
Emperor
1614
Rep 2,753
Thanks guys.
Should have an exciting update, soon.
03-28-2014, 05:45 AM | #59 |
Emperor
1614
Rep 2,753
Not directly related, but since this is an e9X forum, probably makes sense to post anyway...
Picked this up yesterday morning, going to be the wife's new DD. Rear wheel drive NA Manual Hydraulic power steering No DI no iDrive The last of the purchasable BMW's, imo, as all of the above were minimum requirements for me. Currently it is a 328i, but soon it'll be a Supersprint header/evolve tune 330i, which will put it at (a reliable, NA) ~300 crank HP. After this summer these wheels will become winter wheels, and we'll get something light/strong for the summer with real tires. Needs M3/1M subframe bushing asap, and have to figure out what I'm going with suspension on it. Likely it'll be stock sport springs with Koni yellows or Bilsteins. Roof rack will also be removed. But, first order of business will be swapping all the fluids! May dye the vinyl parts of the interior black for a two tone effect, undecided on that... 50,000 miles on the clock, currently. This should be a fun and reliable car for a long time, given how it's optioned. I really love the non iDrive radio/sirius/bluetooth/ipod interface. Looks old school, but with new school functionality.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport Last edited by Obioban; 03-28-2014 at 04:33 PM.. |
03-29-2014, 03:24 PM | #62 |
795
Rep 3,153
One of the best E46 M3s out there.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
03-30-2014, 04:27 AM | #63 |
130i Treiber
119
Rep 1,432
Drives: BMW 130i
I your M3!!! Very very nice
Red BMW´s are a blast
# BMW 130i /// + SPARCO Assetto Gara 8x18 bronze + KW + PP SteeringWheel II +PP Exhaust +PP Kidneys + PP AirFilter + PP Style Flaps + PP SS Kit + AC-Schnitzer Gear Knob + MorVision Diffusor + LCI Blacklines high + GroundZero-Audio #
04-05-2014, 08:08 AM | #64 |
Emperor
1614
Rep 2,753
Happy new wheel day! Every car got wheels they've never run before.
e46 got a set of anthracite RG-63's that I traded my hyperblack RG-63's for over the winter. Much better match for IR, imo! e91 got a set of 17" BBS SR's. They look AWESOME now (way better than in this pic), but are going to look even better next week when we take it off the non sport suspension: e39 got a set of 18" BBS RG-Rs in silver. Never seen silver RG-Rs before, the color goes quite nicely with Le Mans blue, I think! ... all cars need washes. It's been winter, what can I say :clueless: Could have also used a non phone camera and non rainy day, but.. reh. arrot:
05-21-2014, 10:24 AM | #65 |
Emperor
1614
Rep 2,753
Over the winter I traded RG63's with another member for anthracite. I'm so very pleased with how it goes with the IR-- very much more what I imagined when I ordered the hyper black than I ended up getting!
05-21-2014, 01:04 PM | #66 |
Master Baiter
4173
Rep 631
Drives: 18 M2
Wow I haven't been on here in years. Glad to see you are still modding and posting. I'll be up in PA next Friday to pick up my new to me M3.
Back in a BMW again. Anyway keep up the good work man! The wheels look good on all of them! |
