03-04-2024, 10:17 PM | #1 |
Rep 20
Should I spend more than $35? Anyone with an opinion on torque wrenches?
Hi, i'm Looking for an inexpensive torque wrench up 100ft lbs kinda thing. And there is a million of them on Amazon.
I'm wondering if anyone has a recommendation? I'm definitely not pro enough to need a high end one, but I also don't want to buy one that is grossly inaccurate (if there are such things) the less expensive ones seem to be around $35 for a 1/2 drive 10-120ft lb on amazon. A few brands I found Nebicals Lexivon EPAuto Anyone have insight? Thanks in advance |
03-04-2024, 10:49 PM | #2 |
Rep 685
Harbor Freight has them cheaper ($22) and with a lifetime warranty. They are fairly accurate and I've never had an issue with that aspect. I have had to return two wrenches (used quite a bit) and they take them back no questions asked, in and out in a couple minutes. Wouldn't buy one from Amazon unless it was name brand.
03-04-2024, 11:03 PM | #3 |
Rep 198
Drives: BMW Z4C 3.0si 3 pedal
Have both of these, work great, easy to adjust, not in the "Buy once, cry once" range but still nice for occasional use and accurate. Have a Snap On beam type that is only buy once.
https://www.amazon.com/gp/aw/d/B0081...b_b_asin_title https://www.amazon.com/dp/B004VYURT0?ref=emc_b_5_mob_i Last edited by cbpip; 03-04-2024 at 11:10 PM.. |
jbucky11.00 |
03-04-2024, 11:04 PM | #4 |
Rep 172
Here's mine, 6 years old and still going strong. Lugs need 110lbs if I recall.
https://www.amazon.com/TEKTON-Torque.../dp/B00C5ZL0RU |
00SH4WN84.50 |
03-04-2024, 11:58 PM | #5 |
5234
Rep 10,616
The question is what will you be doing with it? Torquing lug nuts that have a wide range of acceptable torque of doing rod bearings that are more precise? The 2-4% accuracy rate typically provided is in the heart of the range rather than at the ends.
03-05-2024, 11:34 AM | #7 |
Rep 25
I have several of the HFT ones, plus my old (45 years old) Craftsman beam model. I did purchase the Tekton model mentioned above. It seems to be much higher quality in the hand than HFT, and came with a promise of 100% calibration before shipping.
Where torque is really critical, professionals get theirs checked and calibrated routinely. I have no idea where to get that done, and suspect it would cost more than some of these. On some of these lower torque fasteners, like the drain plugs, the oil filter cover and base gasket etc. I feel much more comfortable tightening them by hand with no torque wrench. Just from years of experience I'm not going to overdo it, or underdo it. I can feel it tightening that way and I'm not slavishly waiting for a "click." The feeling of a bolt going into plastic deformation is a memory you won't forget. |
03-05-2024, 04:40 PM | #8 |
Rep 1,098
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
03-05-2024, 05:06 PM | #9 |
5234
Rep 10,616
I have clickers I bought 15-20 years ago for $10-$20 that informally test comparably to my CDI and Precision. Farm Test tried a bunch of wrenches and found Iconn was accurate.
03-06-2024, 12:21 PM | #10 |
292
Rep 404
Project Farm does a great review on YouTube.
I have a Snap-on from my days in racing. Worth every penny for that level of work. I have a Craftsman digital I got on sale for about $60. I use it for most tasks and based on really loose testing, it is accurate. |
03-06-2024, 12:40 PM | #11 |
6566
Rep 2,310
Drives: 9Y0 Cayenne S
Tacklife and Tekton
03-06-2024, 09:47 PM | #12 |
699
Rep 598
I use husky from Home Depot. I have 3 of them. Keep in mind that in general cheap torque wrenches are most accurate in median range. Lowest and highest settings will be the least accurate. Like someone mentioned here. Depending on what you will be doing with them. I am wrenching quite a bit and I thing you will need at least two. Small and medium one. Because small ranges like 8-15nm are crucial when doing work. This is usually torque of valve cover gasket transmission pan oil pan etc. Good luck.
CornerGorillaPit238.50 Dan B291.50 |
03-07-2024, 06:01 AM | #13 |
1Addict
3234
Rep 7,895
Depends on what you need to torque down.
Have a harbor freight 1/2" that's served me well. Carlyle 1/4". The Carlyle is probably 10x the price of the HF.
03-07-2024, 02:18 PM | #14 | |
100
Rep 433
That being said, this biggest decision would be do you need a wrench from 0-100, 0-250, etc? What's your critcal range? The cheaper wrenches are going struggle to maintain accuracy on one end of the other of a 0-250lb range. |
tracer bullet2419.00 Dan B291.50 |
03-07-2024, 05:18 PM | #16 |
Rep 1,479
When I was working for Lear Sigler, I bought 1/2 and 3/8 drive Snap On. Company gave us a great discount on tools. They calibrated them every 6 months but this was 25 years ago now. Hated my drive to Luxembourg from Bitburg daily it got old.
The Texton's are a better home use. If you question it have a shop calibrate it. |
jbucky11.00 |
03-13-2024, 10:55 PM | #17 |
Rep 32
Every torque wrench I own tells you what torque to set it at for storage. My big Tekton stores at 10 ft pounds and its lasered on the side so you don’t forget. Read the directions people.
03-15-2024, 12:23 PM | #18 |
Petrolhead
440
Rep 808
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
I have both a Husky and Hazet ($100 price difference). I'd say they are equally built and accurate, but being a Hazet I trust it more.
https://www.amazon.com/dp/B001C9XJKG...lig_dp_it&th=1
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
03-15-2024, 02:41 PM | #19 |
17320
Rep 18,742
If you want accuracy and low price, buy a beam style torque wrench. There is no mechanism to go out of calibration. Click-type wrenches are cool, but easily get out of calibration. Other than engine internals, setting precise torque values on fasteners is just not that critical.
