      03-05-2011, 01:13 PM   #23
Nachos23
HotBimmer
Nachos23's Avatar
36
Drives: 2016 335GT & 2000 Z3M Roadster
2016 BMW 335GT  [0.00]
2000 BMW Z3M  [0.00]
Time for an update.... Parts are ready for wet sanding.... The intake has already been sanded to 220 wet; next 400 and 800 and then clear coat...... Finally 100, 1500 and 2000 wet, buff and polish and they're ready to go!!
After I finish this post, I'm picking up a new expansion tank and EGR/Oil separator assembly and associated hoses, heading over to my mechanic buddies garage and replacing those items. Expansion tank has small pin hole leaks (4 tiny pinholes spraying water) and have loi leaking from separator valve. Not bad, considering the car had 260,000km and those a re factory original parts being swapped out!! Going to be busy tonight I guess......
      03-18-2011, 04:33 PM   #24
termigni
termigni's Avatar
Drives: S2000, MacanS, M4CS
2018 BMW M2  [0.00]
Originally Posted by Nachos23 View Post
In it's strictest, purest use I would agree. Having said that, the parts aftermarket is comprised of "visual enhancements"; plus the weight savings of buyting a molded CF interior set for instance isn't worth the $$$ when that type of enhancement is purely visual. You'll notice, that I don't wrap hoods and other big exterior parts because those should only be molded pieces, but for the majority of other parts, the gain from going with a pure CF molded part is not worth the cost or fitment issues often associated with such parts..... That's why the wrapping has the same net effect for 99% of CF parts on cars today.....
You are forgiven, since you already have HPF kit to make up for the extra CF weight.
I've made some CF pieces myself and it is not easy to make them as clean as your parts. big kudos, keep up the good work!
2020 ///M4 CS, Alpine White, DCT
2018 ///M2 LCI, Metallic Orange, 6MT, Exec Pkg, Apple.. Sold
Instagram: Tommys911
      03-20-2011, 06:48 AM   #25
Nachos23
HotBimmer
Nachos23's Avatar
36
2000 BMW Z3M  [0.00]
Thanks! So having done some CF wrapping yourself, you know the work that goes into producing the parts...
      03-22-2011, 08:09 PM   #26
Nachos23
HotBimmer
Nachos23's Avatar
36
2000 BMW Z3M  [0.00]
The parts have been finished and shipped today!! Here are the finished parts pictures:
On to the next project!!!
      04-15-2011, 10:14 AM   #27
SonicM3
Drives: Laguna seca blue
Looks really untity, why didnt you just have it wrapped?
Or, have it re-created from carbon fibre in china, I can supply a good contact and it is not expensive.
      04-16-2011, 12:28 AM   #28
lflaco
Drives: 04 M3
Look son!!! that is awesome!!!!! GREAT work!!!
      04-16-2011, 02:06 PM   #29
correcaminos
Drives: 2006 m3
I like it and you can be proud of your work.
Anybody can write a cheque or swipe a card but not many can do what you did.
      04-19-2011, 07:47 PM   #30
Nachos23
HotBimmer
Nachos23's Avatar
36
2000 BMW Z3M  [0.00]
That defeats the entire purpose I got into this. When you mass produce something, you need to decide which product(s) you intend to produce and then build the moulds and then subsequently produce enough to justify the cost of all of the initial steps. I want to wrap parts you can't commonly get, or wrap with cloths you don't normally see used in mass production and lastly, the quaility of of the weave and part fitment is often an issue with Chinese parts. No disrespect, the Chinese make some great products, just not a fan of their CF workmanship. I've recently been approached by a supplier of CF parts for other brands for the same reason, but did ask me to wrap some pieces for his car that he couldn't get from China. Additionally, he admitted that the parts he gets often break when removed as they are too thin!!!
Plus, no need to saturate the market with Chinese mass produced parts; already enough guys selling those on eBay....
and lot of parts that got tossed along the way learning the craft and still constantly experimenting with new processes and materials....
      05-11-2011, 08:42 PM   #31
jeskaM3
jeskaM3's Avatar
Drives: E46 M3 Coupe ('01)
2001 M3  [10.00]
wow... looks great. that takes skill! and I'm sure you appreciate it way more when you do it yourself than just buying something off the shelf.
amazing
      05-14-2011, 06:47 AM   #32
Nachos23
HotBimmer
Nachos23's Avatar
36
2000 BMW Z3M  [0.00]
amazing
Thanks! Take alot of pride in what I produce.
Tags
carbon, diy, engine, hpf, wrapping
Search this Thread:
Advanced Search
