03-14-2024, 06:33 AM | #2619 | |
///M driver
16387
Rep 500
Drives: 2022 M3 6-speed
If the C-17A production line -- long cold -- were hot, I suppose you could consider an AC-17.
'22 G80 M3 6-sp Portimao Blue/Tartufo
vreihen1615465.00 |
03-14-2024, 07:54 AM | #2620 |
///M driver
16387
Rep 500
The U.S. Air Force's fleet of Northrop T-38 trainers is getting old, and the successor T-7A trainer has been selected and under development for several years. 2025 plans indicate a further delay of about a year: The USAF will buy 7 T-7As in 2025 and now projects a total of 346 total aircraft when the buy is complete.
03-15-2024, 06:21 AM | #2621 |
///M driver
16387
Rep 500
U.S. Navy patrol and maritime reconnaissance aviation - an update.
For a number of years, the USN has maintained 12 patrol squadrons (VP) with 6 P-8A Poseidon patrol aircraft each: 6 VPs based at Jacksonville, Florida and 6 VPs based at Whidbey Island, Washington. The Navy Reserve has also operated two VPs with older P-3C Orion turboprop aircraft, but they have now transitioned to the P-8A as well. Apparently longer-term Navy planning is to disestablish two active-duty VPs in a few years as there are not enough P-8As to go around. In addition to the above patrol squadrons, there is a Fleet Replacement Squadron with P-8As at Jacksonville that trains aircrews and maintainers. There is also a Fleet Air Reconnaissance Squadron, VQ-1, that flies SIGINT collection missions worldwide with a few aging EP-3E Aries II aircraft. This mission is to be assumed by unmanned aircraft in the near future. The unmanned aircraft, the MQ-4C Triton, is now fully operational in the Pacific and based at Andersen Air Force Base, Guam, with 4 MQ-4Cs assigned. A second forward location at Naval Air Station Sigonella, Sicily, is soon to be operational with 4 more MQ-4Cs. A third operating location -- at a yet to be disclosed location -- is planned. All the MQ-4Cs are operated by Unmanned Patrol Squadron (VUP) 19 based in Jacksonville and its detachments. The final piece of the patrol and reconnaissance force is Special Projects Patrol Squadron (VPU) 2, also based at Jacksonville and flying the P-8A. Not much is known about this secretive unit. With the exception of the P-8A training squadron, all of these units deploy worldwide, either as whole squadrons or detachments, as required.
JJ 911SC22622.50 BMWGUYinCO4125.00 |
03-15-2024, 07:26 AM | #2622 |
///M driver
16387
Rep 500
A bit of elaboration on the last post:
Each patrol squadron (with 6 active P-8As) has 12 aircrews assigned. Each aircrew has 3 Naval Aviators (pilots), 2 Naval Flight Officers (tactical coordinators), 3 enlisted sensor operators and an inflight technician, for a total crew of 9. That's a total of 108 aircrew per squadron; with maintainers and other personnel, the squadron has a total of 270 personnel. See attached photos of the P-8A flight deck and the mission consoles. Note that there are also crew rest seats for long-duration missions. Each MQ-4C operating location has 43 personnel assigned to maintain and turnaround the assigned unmanned aircraft. That operating location also is assigned 10 aircrews, who may be elsewhere, as satellite communications are used for the aircraft. Each aircrew has one air vehicle operator (pilot), one tactical coordinator and two enlisted mission payload operators. I've been unable to find a photo of the operating console for the MQ-4C. With three operating locations, the total number of active MQ-4Cs at any one time will be 12. The Navy plans to buy 27 MQ-4Cs to allow for periodic depot-level maintenance or losses.
03-16-2024, 02:20 PM | #2623 |
///M driver
16387
Rep 500
After Hiroshima and Nagasaki and the end of World War II, there were many in the military who thought that any future wars would be fought using nuclear bombs. The Army Air Force's (and soon the U.S. Air Force's) Boeing B-29 Superfortress was the proven delivery platform. Many in the Air Force, and in the other services as well, thought that the Air Force would play an overwhelming role in any future conflict.
There was some thought in the Navy, however, that recognized the role that naval aviation could play in a future war. But existing carrier aircraft were simply too small to carry the massive early nuclear bombs. The first series-produced bomb, the Mark 4, was 60 inches in diameter and 128 inches long and weighed almost 11,000 pounds. The Mark 4 was soon succeeded by the Mark 6 which was about the same size but lighter. The first effort in the Navy came in the adaptation of the Lockheed P2V Neptune patrol plane as a nuclear bomber. 11 P2V-3s were modified as P2V-3Cs. Takeoff would be using JATO rockets and a tailhook was provided for landings. Preliminary tests showed that landing aboard would be impracticable, and the tail hooks were removed. The concept then became a carrier takeoff, dropping the bomb and a flight to a friendly country. If that was impossible, the P2V-3C would ditch near a U.S. Navy ship with the hope of recovering the crew. A more usable solution would come with a very large carrier aircraft and the North American AJ Savage was chosen. The AJ was a three-engine plane with 2 R-2800 prop engines and a jet in the tail behind the large bomb bay. Unfortunately, the AJ proved to be marginal as a carrier aircraft; it was just so large that deck handling proved a major problem. While it had folding wings and vertical tail, it did not help that ground crews using special equipment had to do the folding and unfolding. Despite the fact that the mission was considered critical, the AJ was unpopular on carrier decks. The AJs were frequently sent ashore in Morocco or Japan on alert to return to the carrier to load the bombs if needed. In the meantime, the Korean War had demonstrated that not all wars would not become inevitably nuclear, which took some of the pressure off the situation. The ultimate solution would come with the AJ's replacement, the Douglas A3D (new A-3) Skywarrior and with new larger aircraft carriers that could better handle such large aircraft. At the same time, smaller nuclear bombs were developed that eliminated the need for a very large bomb bay.
03-18-2024, 03:06 AM | #2624 |
///M driver
16387
Rep 500
This was a gas station and snack bar in Portland, Oregon, for many years (1950s? 1960s?) -- long gone now.
03-18-2024, 05:14 AM | #2625 |
///M driver
16387
Rep 500
Unmanned Aerial Vehicles (UAVs) are coming, like it or not. The U.S. Navy has purchased Northrop Grumman MQ-8C Fire Scout helicopter UAVs to operate from the Navy's littoral combat ships (LCSs). The Independence-class LCSs with their odd trimaran hull are all based in the Pacific and operate detachments with one manned MH-60S helo and one MQ-8C UAV helo per ship when deployed. The Navy hemmed and hawed a bit, but in the end decided not to arm the MQ-8C but to use it to extend the ship's sensors.
The MQ-8C is based on the Bell 407 helicopter and has good performance for the UAV mission, including excellent endurance. Of course you want to maintain contact with the UAV which minimizes the distance you want it to travel but stationing the MQ-8C several dozen miles from the ship for 10+ hours is a real advantage. The Navy has not jumped in with both feet, though: They bought 38 MQ-8Cs, all stationed on the west coast. 10 Fire Scouts are active at any given time, with the other 28 in storage and available to cover potential losses, etc. https://en.wikipedia.org/wiki/Northr...-8C_Fire_Scout
03-18-2024, 09:06 PM | #2626 |
///M driver
16387
Rep 500
In the early days of Navy helicopter use, it was difficult to find a place to land the helicopter on a surface warship. In this 1951 case, the heavy cruiser USS Albany (CA 123) offered the top of one of the gun turrets as a clear area where a helo might hover like this Sikorsky HO3S is doing.
Note that it's got to be at least 15-20 feet above a standing person's head that those rotor blades are a danger, but everybody ducks anyway.
03-20-2024, 06:12 AM | #2627 |
///M driver
16387
Rep 500
Here's a rarely-photographed aircraft -- no, not the EA-18G Growler in the foreground -- but a Japanese Maritime Self Defense Force OP-3C intelligence collection aircraft.
03-20-2024, 05:52 PM | #2629 | |
5292
Rep 1,819
Drives: 2022 M850 GC - Carbon Black
Llarry didn't they take it to a warehouse in Milwaukie? |
vreihen1615465.00 |
03-20-2024, 05:57 PM | #2630 | |
Cailín gan eagla.
71439
Rep 1,007
https://b17alliance.com/mission/ |
03-20-2024, 06:01 PM | #2631 | |
5292
Rep 1,819
Edit... duh. Didn't see your link Edit x2.....OK, they've raised enough to clean 2 of the landing gear. They are a loooooong way from completion. Gonna be awhile. |
vreihen1615465.00 |
03-21-2024, 06:07 AM | #2632 |
///M driver
16387
Rep 500
It's Tomcat Day!
Here's a Jolly Rogers F-14 posing nicely for the camera, and one playing with Mach 1 and the shock waves.
03-21-2024, 06:42 AM | #2633 |
///M driver
16387
Rep 500
The Grumman A-6A and later A-6E were the U.S. Navy and Marine Corps' standard all-weather medium attack aircraft for many years from the mid-1960s until the end of the century.
Ever-increasing demand for inflight refueling caused the Navy to undertake the conversion of earlier A-6As into KA-6D carrier-based air refueling aircraft. Much of the complex attack avionics was removed and a refueling hose reel was installed behind the wings with the outlet visible under 'NAVY' on the aircraft pictured. The fuselage-mounted hose reel occasionally gave problems and so there was a backup refueling pod often installed on the aircraft belly. And to maximize available fuel, four external fuel tanks were usually carried as well. By the time this photo was taken, the traditional gray uppers and white lowers had been replaced by the tactical paint scheme with shades of gray. However, KA-6Ds such as this one were not expected to see combat and so often retained their previous gray & white scheme. This KA-6D belongs to Attack Squadron 185, mostly assigned A-6Es but with a couple of KA-6Ds as well. VA-185 was one of two small A-6 squadrons assigned to Carrier Air Wing Five on the USS Midway (CV 41) homeported in Japan This one is landing: Note the open speed brakes on the wingtips.
03-22-2024, 03:40 AM | #2634 |
///M driver
16387
Rep 500
The Radia Windrunner is a proposal for the world's largest aircraft -- built solely to transport huge wind turbine blades to their turbine locations. As such, it would use unimproved (or perhaps barely improved) temporary runways.
The Windrunner's dimensions are amazing: 108 meters long x 80 meters span. The relatively small span probably makes sense given that the cargo (two wind turbine blades at a time) is relatively light. The underlying principle is that larger wind turbines would be more cost-effective, but transporting the turbine blades of such size is currently impossible. The Windrunner would make such transport viable. https://radia.com/windrunner
03-22-2024, 03:44 AM | #2635 |
///M driver
16387
Rep 500
A possible candidate for the world's ugliest fighter: The SAAB J29 Tunnan (barrel), which first flew in 1948 and was a pioneer of swept-wing technology.
https://en.wikipeida.org/wiki/Saab_29_Tunnan
03-22-2024, 04:38 AM | #2636 |
///M driver
16387
Rep 500
Discussing colors and markings on military aircraft is a good way to get into an argument, but I would say that my favorite of all time is the livery on VF-84 Jolly Rogers F-4 Phantoms of the 1960s-70s. This photo is an F-4N from 1975.
Here's a close runner-up, though; another F-4N but from the VF-161 Chargers based in Japan. VF-161 later got F-4Ss and ultimately was replaced by a Hornet squadron. Note that these were the days when all the aircraft were colorful; not just the two per squadron allowed these days.
03-22-2024, 06:41 AM | #2637 | |
///M driver
16387
Rep 500
So, combine an F-8 with some cool squadron markings and what do you have? A potential winner! This is an F-8H of VF-211 'Checkmates' on board the aircraft carrier USS Hancock during a 1968-69 Vietnam War cruise. VF-211 went on to fly the F-14 for a number of years and currently flies the F-18E Super Hornet. As you can see from the second and third photos, the 'Checkmates' tradition continues. The fourth photo shows a painting of a VF-211 FJ-3M from 1956 -- those markings have a long tradition.
03-23-2024, 04:06 AM | #2638 |
///M driver
16387
Rep 500
The U.S. Navy and Marine Corps adversary squadrons are all Reserve units (with some active-duty personnel attached as well). As previously reported here, the paint jobs are interesting.
The Navy & Marine F-5s came from the Swiss Air Force, where they were well-maintained low-hour aircraft. They were given some modifications and designated as F-5N (16 single-seaters) and kept their F-5F designations (6 two-seaters). They are now being given glass cockpits and as they are modified become F-5N+ and F-5F+ aircraft. I think the intent is to keep them around for quite a while. They are assigned to two Navy and two Marine adversary squadrons. Anyway, the paint schemes on the adversary aircraft are always entertaining.
03-23-2024, 06:27 PM | #2639 |
8944
Rep 2,010
Treating a B-17 like that is sacrilege. Same, same P-51's on a stick somewhere in South America. Sacrilege!
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
03-23-2024, 07:44 PM | #2640 |
Recovering Perfectionist
15465
Rep 946
Drives: 2015 BMW i3 BEV
So, tell us how you feel about gate guardians?????
Llarry16387.00 |
