01-12-2012, 09:09 PM | #1 |
Rep 173
Finally put the ///M3 on a Dyno
Finally got the M3 on a dyno today. Been needing to get a basline reading before I start putting on my engine mods. Unfortunately I couldn't get it into dyno mode. I tried all the button holds and ignition turns to no avail. Oh well, I'm still putting down some good power for 6200rpm. The third run I had let the car cool down a bit so that's why it's lower. How about that torque curve! Mods so far are RE El Diablo rear section and Dinan 3.91 diff. I will update with new dyno runs after each mod just to see what it actually does. Now where's that dyno limiter off switch!
02-07-2012, 07:22 PM | #3 |
Rep 1,113
Nice. Do you have SAE numbers too?
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
02-08-2012, 05:07 PM | #4 |
Rep 173
Finally got back to the dyno and this time got it to redline. Thanks to all those who told me how to disable the "dyno limiter". Since the last run I've had the vanos completely replaced (both sides), new fuel filter installed and valves adjusted. Only performance upgrades so far are a Dinan 3.91 diff and RE El Diablo rear section.
Next run will have AP headers, Euro200r section 1 and aFe intake installed |
02-11-2012, 09:08 AM | #5 |
Rep 31
I have a set of Evosport headers and wondered if I can install them with the car on ramps or jack stands vice having it on a lift. Thoughts?
Thanks, Jeff |
02-11-2012, 10:28 AM | #6 |
Rep 173
Im sure it would be tricky getting them up to the motor on stands but probably not impossible. However i dont have any personal experience at trying so i cant say for sure
02-22-2012, 11:48 PM | #7 |
Rep 126
That second dyno is more like it! Solid looking graph.
My baseline, stock, dyno run was exactly what your first dyno looked like: 268 WHP/ 238 WTQ. I have yet to dyno since putting the pulleys on and flashing the Evolve "stage 1" tune. Next dyno will be with a 4.10 gear set and bored/ported ITBs.
E46 M3 SMG; VAC Ultra light pulley set; Evolve-R Stage 1 tune; 3000 lbs.
Entrepreneur (Click the about me ): AdamRod.MySiselPro.com Fitness Challenge: AdamRod.MyLeanLine.com |
02-23-2012, 05:52 AM | #8 | |
Rep 173
02-23-2012, 09:50 AM | #9 |
Rep 126
I was wondering about that, since 3.91 is supposed to 8% more tq to the ground. But you know the 3.91 is a legit piece and you know it feels and is faster, so I'm sure it's not that big of a deal not showing up.
Although... it would be really cool is the dyno could read that "extra" tq being put to the ground!
02-23-2012, 10:52 AM | #10 |
Rep 173
The problem has to do with the ignition lead to the dyno and the way the gears are input. For some r
eason it doesnt let it read the extra torque made by gearing but you are right, I would love to see the actual wheel torque im getting now. |
03-03-2012, 12:14 AM | #11 |
Moderator
431
Rep 465
Drives: E46 M3 / E92 M3
looking forward to the ap header results
04-07-2012, 06:29 PM | #13 |
1770
Rep 6,696
Drives: F30 340i
any update? how do you like the exhaust
04-07-2012, 11:38 PM | #14 |
Rep 173
Well I just got the car back 3 days ago! It was in the shop for 6 weeks. Now I have a new crank and bearing among other things so I have to break the bearings in for 1200 miles. After that I'll get back on the dyno. And I absolutely love the exhaust. The headers make all the difference!
