12-26-2016, 09:40 AM | #45 | |
1425
Rep 3,395
The problem is that the engine is considerably more expensive to manufacture than the 1.8l 4 pot currently in use in the corolla which defeats the purpose of an inexpensive entry level vehicle thats reliable |
Spinnetti95.50 |
12-26-2016, 10:19 PM | #46 |
234
Rep 2,643
I don't think I would buy a Toyota with BMW engine if there is too much technology. They are supposed to be super reliable, and that is the main reason why people buy them.
12-27-2016, 12:00 AM | #47 | |
Rep 230
I would not buy toyota with bmw engine embedded, but I love to see some bmw(aka modern) tech implemented by toyota.
e36->f48->....
12-27-2016, 07:54 AM | #48 | |
7909
Rep 11,785
12-27-2016, 08:18 AM | #49 |
Rep 230
s14 and m43 are the exceptions from the rule : Bmw is all about 6 cyl engine.
e36->f48->....
12-27-2016, 08:19 AM | #50 | |
7909
Rep 11,785
BMW is about 3,4, 6, 8,10, and 12 cylinder engines... not to mention motor cycle motors ... it's BMW "fans" that are " all about the 6" |
12-27-2016, 01:19 PM | #51 |
992
Rep 3,001
I gander that the reason for this joint venture is because Toyota is going to continue its focus on hybrid & hydro powertrain development & is outsourcing the next gen ICE to BMW
re
12-27-2016, 03:50 PM | #52 |
Rep 98
I'm not sure that this is a good idea for Toyota... going with "things in general here." Suppose the BMW motor is just as reliable as a Toyota sourced motor. All motors have wear items that eventually needs to be replaced. Let's say you need a new valve cover gasket. On the current Corolla the replacement cost is running between $100 - $150 (according to repair pal). On a BMW 328i (which has a 2.0 liter turbo inline 4) the repair cost is estimated to be $649 - $959. Why the difference in cost you might ask? Well if you dig into the repair manuals replacing the valve cover on the BMW engine is much more complicated due to the way BMW designed the engine. On the Corolla you simply remove some bolts, take the valve cover off, scrape the gasket off, clean the valve cover, put a new gasket on, put the valve cover on and torque the bolts to spec. On the BMW engine you have to remove high pressure fuel rails, remove air intake hoses, remove bolts and throw away (bolts are torque to yield and cannot be reused, they are like $10 - $20 each, there are a bunch of them) etc. etc. A Corolla owner is going to be pretty surprised with the cost of a simple valve cover replacement. Maybe BMW can make slight alterations to customer engines that makes maintenance easier / cheaper but I'm not sure that they would bother.
12-27-2016, 04:57 PM | #53 |
5319
Rep 5,824
Will not affect the US market. Will continue in Europe where it already has been without complaint,conspiracy or paranoia.
In regards to FWD. BMW projected 600,000 combined BMW/MINI FWD units by 2020. As it stands combined sales so far is around half that projection. And with 2017 introducing the MINI Countryman and the BMW 1er Sedan. 2017 is expected to be closer still. But with more models coming before 2020. 600,000 units is expected to be surpassed earlier than initially projected.
The M850i is evidence that BMW have got their mojo back when it comes to dynamic sports cars...
Falafel Combo3773.00 mkoesel7517.00 |
12-28-2016, 01:04 PM | #54 |
Rep 395
It would be cool to see the GT86 with a 2-liter turbo. Or a Corolla hatchback with the same engine and AWD. Subaru got dominant in this segment after Mitsubishi quit the affordable sports car segment.
p.s.: calm down guys... it's ok to differ in opinions... Just don't judge the other person |
12-28-2016, 05:28 PM | #55 | |
Rep 86
12-28-2016, 06:09 PM | #56 |
Rep 185
So do I - how does that give you inside info?, and this makes no sense. Why give away margin on such a high volume product? And BMW is no low cost supplier... I call BS on this one. What facility do we have in Knoxville? I'm at HQ
01-02-2017, 08:26 AM | #57 | |
Rep 255
James
<GONE> 2014 BMW 335i Melbourne red M sport. 6spd. Nothing more nothing less. ISO of Manual 535/550/335 |
