BMW 2-Series Gran Coupe
BMW 2 Series Gran Coupe Forum (F44) BMW 2 Series Gran Coupe (F44) General Discussion
      07-01-2022, 09:02 PM   #23
Derik_472685
Drives: BMW M235i
M235 Wireless Charger Mod
During disassembly, it takes a fair amount of force and required a rag and 2x vice grips to remove.
Just be careful to pull from the top section of tabs, or it will damage the part.
      08-15-2022, 08:27 AM   #24
JGRonin1869
Drives: BMW Z4 X1 2 Series Gran Coupe
Hey y'all any feedback if the part referenced still keeps NFC?
      08-15-2022, 11:18 AM   #25
Runner626
Drives: Bimmer
Good question..
      08-22-2022, 03:10 PM   #26
JGRonin1869
IT WORKS!
Ok, so here is what I can tell you.
I have a 2022 F44 that came with NFC but no wireless charging.
I ordered BMW part. 9442419
To remove it I popped off the plastic phone holder and grabbed the old part with needle nose locking pliers and pulled back as each side popped out the the clips. NOTE: I covered them and the sides of the enclosure with blue painters tape to protect the surfaces as well as the nose of the pliers.
Once installed I had wireless charging and NFC control still.
Simple easy I have not bother coding left behind phone yet.
--Josh
      08-24-2022, 01:52 PM   #27
Notleks24
Notleks24's Avatar
United Kingdom
Drives: BMW 128ti
--Josh
Hi all, I ordered a new 128ti in February arriving October 👍, it's meant to be coming with the Comfort Pack II, this includes comfort access.
It's also meant to have the Digital Key. However I couldn't get wireless charging. Without the wireless charging does that mean it won't have the digital key?
      08-25-2022, 02:32 PM   #28
Bugs Meany
Bugs Meany's Avatar
30
Drives: 2022 BMW 228i GC xDrive
You can have digital key without wireless charging. (Mine does.) The charging pad is there; it just doesn’t charge.
      08-25-2022, 02:34 PM   #29
Notleks24
Notleks24's Avatar
United Kingdom
Drives: BMW 128ti
You can have digital key without wireless charging. (Mine does.) The charging pad is there; it just doesn't charge.
Thanks
      08-31-2022, 01:40 PM   #30
Runner626
Drives: Bimmer
Ok
      10-08-2022, 03:52 PM   #31
MugatuJag
Drives: 2022 BMW 228I XDrive GC
So you have NFC and the wireless charging pad but you have been unable to get the digital key code right?
      10-13-2022, 03:25 PM   #32
Bugs Meany
Bugs Meany's Avatar
30
Is this question for the OP or me?
      10-29-2022, 05:14 PM   #33
hgalanos
Drives: BMW M235i xDrive
Can anyone tell me where this plugs in to? Where do you get power from?
Also, how to code it?
      11-26-2022, 10:50 PM   #34
Gregory
Gregory's Avatar
Drives: BMW X1
Originally Posted by sansagara View Post
Good question. I'm also interested, as my lease F44 did not come with the charger. It's a must for wireless car play! I wonder how easily it is to install, though... and if i must take it to the dealership for them to do it.
You can get it done yourself but would be advisable to get it done through a dealer. You could contact the one that got mine done for me through WhatsApp ‪+1 (401) 206‑0558‬ He can do it within your own convenience
Greggreg
      11-26-2022, 10:51 PM   #35
Gregory
Gregory's Avatar
Drives: BMW X1
A car dealer would be better, cos explaining it to you, something could go wrong. You can contact the guy that helped me with mine through WhatsApp ‪+1 (401) 206‑0558‬ He can do it within your own convenience.
Greggreg
      11-27-2022, 08:18 AM   #36
Bdszz084
Drives: M3
Originally Posted by mikeyb74 View Post
Has anyone retrofitted the genuine wireless charging in their F44? I see everyone with G20 3 series are retrofitting from the NFC module to the wireless charging module. The only coding is for the don't forget phone. They are saying it is plug and play were the NFC will still work.
I'm interested I need to get one of that
      12-14-2022, 06:46 PM   #37
Panfrag
Drives: BMW F40 118i
Can anyone tell me where this plugs in to,
? I took it apart but there is no cable ready to be connected to the charging pad except the one for the usb
Do I need a special cable to connect it or from where you get the power from.
Thank you in advance
Newfy here…
      02-14-2023, 03:43 AM   #38
gutschig
Austria
Drives: F30 318D
I have rebuild the wireless charging unit but the phone will not be charged. Is there any solution (maybe coding in the new versions)? My Car is build 06/22 with the software 07/2022.58.
Thanks!
      04-26-2023, 01:51 PM   #39
aealcail
Drives: F44 218
hi . i have the wireless unit and the wired arenas but not work, any idea? my car build in 7/22 regards
      04-27-2023, 02:19 AM   #40
GGu
Austria
Drives: BMW F44 218D
I have the same problem, all installed and coded but it doesnt work. Mayby there was a change in 2022...
      05-04-2023, 03:02 AM   #41
GGu
Austria
Have anyone found a solution for 2022 cars?
      08-06-2023, 03:06 PM   #42
Tombrunskill
Tombrunskill's Avatar
Drives: BMW M235i Gran Coupe
Can anyone send me a link for the component required if you already have the nfc phone tray but it doesn’t actually charge, I have the comfort pack but not the full tech pack so although I have the nfc tray it doesn’t charge my phone
      08-08-2023, 12:39 AM   #43
GGu
Austria
What link to you mean? You need a tray with nfc and wca. Then you must code the wca and thats it.
But I think you will have the same problem that it not will work.
bmw
