      10-13-2023, 12:59 AM   #1
WESTCOASTTRADING
WESTCOASTTRADING's Avatar
Drives: 06 M3 Coupe
Selling my beloved E46 M3 coupe
Clean title but paint needs bit of work
Car is located in Las Vegas
I am moving to South Korea so car must go
Engine
Eventuri Intake $940
HPF Stage 1 Tune $550
Custom Performance Headers $950
Status Gruppe Rasp Eliminator Section 1 $600
Status Gruppe Non-Resonated Section 2 $700
Super Sprint Race Exhaust $1,450
Morosso Oil Catcher $200
Transmission
OEM Clutch Kits $900
CAE Shifter $1600
E46 new M3 Manual Transmission swap $1500
Cooling
Mishimoto Efan $550
Mishimoto Radiator $600
Mishimoto Oil Cooler $750
ECS Coolant Hose $90
Morosso Coolant Expansion Aluminum Tank $350
Suspension & Brakes
Ground Control race Camber Plates $420
MCS 2 way Coilovers set $7000
(5 inch /700lb & 5 inch/850lb )
TurnerMotorsport Camber Arms $400
H&R Rear Sway Bar $320
Eibach Front Sway Bar $200
Rouge Engineering Front Strut Brace $400
F80 M3 Retrofit brake kit $2,500
Pagid RSL 29 front and rear $800
Interior
Alcantara Steering Wheel $500
CAE Shifter $1,300
Recaro SPG $1,000 x2
Bracket $250 x 2
Auto power half roll cage $500
Custom rear seat delete - $1000
Aero & Wheels
Apr GTC 300 $1,500
Turner Motorsport Diffuser $250
Apex FL5 $1,500
18 x 10.5 square
285/35/18 & 295/30/18 CRS front and RE71R rear
Fancywide under tray diffuser $800
Maintenance & Reinforcement
Rod Bearing done at 95k at JD autowerks
Rear Subframe Reinforcement
Diff bushing and flush at EAS
Differential Cover $200
TurnerMotorSport Race RTAB $330
Valve Cover gasket
Alternator
Battery
Water temp
Clutch was replaced less than 500 miles ago
They are all replaced with brand new part
All the parts were brand new I did not use used part
Oil change was done frequently at every 5000 miles or less
Car doesn’t have any leaks
Drives very strong and track ready and street legal
Currently registered at state of Montana
Clean title on hand
Aim solo 2 recorder and timer and other goodies will be included.
Thanks for looking
40k obo
      11-01-2023, 08:21 PM   #2
WESTCOASTTRADING
Drives: 06 M3 Coupe
Mileage is 115k
      11-03-2023, 10:47 PM   #3
mrm3too
Pump that Bass
98
Drives: E36, Model 3, Cayenne S
Can you text me please on this? I'm interested. 602-290-2098.
1995 E36 AA M3
F80 M3 X Volk TE37s
