11-06-2021, 11:47 AM | #67 | |
17440
Rep 18,808
Other's may laugh, but the best steering feel out of a BMW I've ever experienced is in the E21.
S_Mazza0.00 |
11-06-2021, 12:58 PM | #68 | |
9742
Rep 6,095
Former
-2008 E90 328 black/brown -2012 Lexus IS250 black/black |
S_Mazza0.00 |
11-06-2021, 04:16 PM | #69 | |
17440
Rep 18,808
11-06-2021, 04:47 PM | #70 | |
6663
Rep 15,858
Not understanding how your F15 really drives. Surely tightening up is more in the tuning of the suspension bushing. Appears too soft? Then your comments indicate the sensitivity is put back in the higher assistance level, so that small/light inputs give the movements. Easy to oversteer. Why is the steering requiring corrections when driving straight? Where's the precision in the alignment? |
11-06-2021, 05:20 PM | #71 |
3360
Rep 1,823
BMW need to study what Chevrolet has done in recent years with Camaro SS 1LE, CTS-V and now the Black Wing series. Great feedback from all those cars. Good weight, and no dead spot on center either.
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" |
11-07-2021, 07:33 AM | #72 |
6684
Rep 2,342
Drives: 9Y0 Cayenne S
Steering feel starts with suspension geometry. Caster trail and angle, scrub radius and kingpin inclination create the forces felt in the steering wheel, which the assist system then reduces and shapes. Tire-wheel combination is also part of the picture.
It's multivariate calculus seeking balance between safety/stability (by far the highest priority), comfort, tire wear and handling. Suspension geometry that doesn't give much for the assist system to work with is combined with carmakers' assist calibrations and at the result is the experience posters have shared on this thread. It's possible to have different assist calibrations in different markets, similar to engine or transmission shift calibrations. It would be interesting, although difficult, to back-to-back compare equivalent models from different markets to experience the calibration differences. |
wtwo318091.00 HighlandPete6663.00 |
11-07-2021, 09:38 PM | #73 | |
6593
Rep 3,102
Drives: 21 Vantage, 18 Vantage, 00 WRX
I went from an M2C to an M2CS and the difference in steering feel is immense. It demands a lot more concentration and gives a lot of information. I actually think that some people would find this annoying and probably prefer the M2C steering. So I'd say the tuning is aimed at the intended audience. I really like the CS steering but probably wouldn't want it in a daily commuter car. But I'm not a commuter and every drive in this car is an event. So I'm happy. |
11-07-2021, 11:40 PM | #74 | |
7609
Rep 3,608
Current: F80
Prior: F82, F32 |
11-07-2021, 11:48 PM | #75 | |
Rep 612
My E90 almost felt like it had no power assisted steering. It was heavy. It took effort to turn it. You weren't going to back it out the garage or navigate the driveway with your finger because it would hurt your finger (just an example, don't drive with just your finger). It also tracked extremely straight and needed very little corrective input. It was tight meaning the slightest movement in the steering wheel resulted in the car reacting. There was no dead zone in that steering. The F15 has very light steering. Its over-assisted or like you stated, higher assistance level. It takes no effort at all to turn the steering wheel and because of this you don't feel the road as much. While it does react well to steering input, feeling so light makes it feel sloppy and floaty. My alignment is fine, my bushings are fine, it's just an over-assisted steering system to appeal to those looking for comfort over performance and feel. It is a bigger SUV so it's not going to handle or track like a sedan, but with a tighter or heavier, or "more resistance" steering it would help not feel so floaty. And yes, its an X5, and even being an M Sport it's still not meant to be a performance or track oriented vehicle, but it's also not just the X5 that people complain about this new over-assisted steering feel. The only saving grace I have with mine is it has both Adaptive M and Dynamic Handling packages, so my X5 stays surprisingly flat and balanced with hard cornering. But, with an M Sport you can run in Sport mode and feel the steering get heavier and tighten up, so there has to be something that can electronically change how the steering feels. |
HighlandPete6663.00 Germanauto9741.50 |
11-08-2021, 06:03 AM | #76 | |
18091
Rep 5,498
Drives: 23 X7 40i; 23 M3; 24 cooper s
2023 BMW X7 xDrive40i
2023 BMW M3 6MT 2024 Mini Cooper S Convertible '20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima |
11-08-2021, 06:30 AM | #77 | |
6663
Rep 15,858
In my particular case, it wasn't just wheel size and/or suspension options which changed the steering. Something like the SAT option (Sport Automatic Transmission) of the time, appeared to also change the steering software. Steering was far superior with SAT models. I'm sure this still applies, even if the basic EPS rack is the same, software is calibrated to other specifications and options. |
chassis6684.00 |
11-08-2021, 06:53 AM | #78 | |
6663
Rep 15,858
I do believe where some of us have issue, is wanting a more solid steering feel, which we can 'man handle', rather than be willing to adapt to more sensitive and lighter inputs. I believe that anyone who adapts to a more sensitive steering 'awareness', like applying lighter movements, even a lighter grip of the wheel, will find there is much more precision and greater road feel coming back through the wheel, than they first think is there. Yes, it may go against the grain, but when guys like Chris Harris prefers the 'comfort steering' in something like the F80 M3, compared to the sport setting, gives us a clue that heavy steering is not always the desired option. The steering could be calibrated to be heavier and tighten up more than we have now. We know that, as some models in a range do have tighter steering, even running the same wheel sizes. Last edited by HighlandPete; 11-08-2021 at 09:22 AM.. Reason: Sentence edit, F80 not G80 |
11-08-2021, 09:30 AM | #79 | ||
Rep 612
My Diesel Information Thread | My Wheels, Tires, and Fitment Thread | My Teardrop Camper Build | My F15 Suspension Lift Thread |
11-08-2021, 11:23 AM | #80 | |
6663
Rep 15,858
My thinking, BMW could do so at the design and software stage. By reason of how they tune the steering for different model ranges. How they have purposely made lighter steering, through the years of using EPS. |
11-09-2021, 10:46 AM | #81 |
drives cars
245
Rep 322
Drives: '23 IS 500, '23 X3
Regarding the whole IS 500 steering feel topic...
As someone who has both an IS 350 and a G20 330i M Sport in the garage, yes, the Lexus has my favorite steering between the two. However, I do wish the steering rack was just a little quicker. Unlike the BMW, it has a fixed-ratio steering rack. This means it feels a lot more natural, but it also takes more steering input to make my way through the twisty bits. Having said that, I actually can feel the wheel responding to imperfections in the road from time to time, which is more than I can say for the BMW. The 330i actually has better steering than I remember in a couple of BMWs I've driven previously - an F30 335i and an F22 M235i. Both of those cars had numb steering that somehow felt overboosted - I am probably not describing it well, but it was nothing special. My 2016 Mk7 GTI had much better steering. The G20 actually has decent weight on center and isn't overly darty while still being quick to respond. Sure, it took some getting used to, but I rather like it. I agree with past comments on the Macan, too, that car has some nice steering! I rented a Macan Turbo on Turo a few years ago and had a blast with it.
2023 BMW X3 | Phytonic Blue | Black Vernasca Leather | Dark Wood Trim 2023 Lexus IS 500 F Sport Performance | Infrared | Black NuLuxe |
wtwo318091.00 |
