Technical Sections Engine / Transmission / Exhaust / Drivetrain
      03-31-2020, 05:22 PM   #1
TPS65
TPS65's Avatar
13
Drives: E92 M3 - CF Roof / 6MT
Rod bearings - which bearings do you recommend
Hi all,
currently in the process of searching for an E46 M3 project.
I've been investigating the replacement of rod bearings
There are many different rod bearings i've seen available such as KING, WPC treated bearings, Bimmerworld's WPC treated option, standard BMW bearings etc etc
What bearings and engine oil did everyone use on their engines, and what would you recommend.
The vehicle won't be tracked, but it will see canyon/mountain roads as it will be a weekend car.
Cheers guys, appreciate any advice.
      03-31-2020, 05:41 PM   #2
kevin @ eas
kevin @ eas's Avatar
Drives: 2015 BMW M4
We have been using ACL bearings and have had good luck with them.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
Andrew424.50
      03-31-2020, 06:57 PM   #3
TPS65
TPS65's Avatar
13
Thanks Kevin, great to know.
Are there tolerance differences with ACL bearings, compared to OEM BMW bearings that require a different viscocity oil to be used?
      04-01-2020, 02:00 AM   #4
Andrew
Andrew's Avatar
425
Drives: E46 M3 / E92 M3
2003 BMW M3  [0.00]
2008 BMW M3  [0.00]
I'm using WPC treated OEM bearings with Redline 10W60 on my track-dedicated S54. I've been thinking about what bearings to go with next and it's either going to be BE or ACL.
[Track] 03 AW/CIN 6MT E46 M3
[Street] 08 AW/FR 6MT E92 M3
[Tow/Overland] 23 Toyota Tundra HV TRD Off-Road
      04-01-2020, 08:03 AM   #5
performance_outlaw
performance_outlaw's Avatar
Poland
12
Drives: 3x E46M3, F32 435i
2015 435i  [0.00]
2002 E46 M3  [0.00]
2003 E46 M3  [0.00]
2005 E46 M3 Competi ...  [0.00]
I use OEM and Millers NT10W60 on all 3 E46 M3's I own. Every 2nd oil change I take 100ml of oil from mid stream while drain oil pan and send for inspection. Lab test is giving full report, and you can see does the oil composition contain con rod or main bearing inclosions over the limit. I don't put a lot of kilometers, but as the cars stand still and are not runned very often, bearings tend to wear fast. Cold starts are the worst.
I believe in normal conditions, con rod bearings should be replaced every 50k mls, and main can do double. And it doesn't matter is it pre 2003 or latest itteration of S54.
2002 M3 Carbon/Imola
2003 M3 Black/Black
2005 M3 Competition Interlagos/Cinnamon slicktop
2015 435i MPPK, MPE and Mdiff Alpine White/Coral
      05-30-2021, 09:42 PM   #6
PaulE46M3
them3brothers
PaulE46M3's Avatar
Drives: E46 M3, F80 M3, F97 X3 M Comp
ACL Bearings With ARP Bolts
I personally went with ACL Bearings with the ARP bolts and so far so good. Truly love having the peace of mind not having to worry about them as much anymore. If you are in the Bay Area I would defiantly get them done from VT Motorworks, they did a fantastic job on my car!
Instagram- @them3brothers
      06-11-2021, 06:51 PM   #7
msdss
msdss's Avatar
Drives: Alpine White 2020 BMW M2C
the shop I went to recommended BE bearings.
