05-09-2012, 01:49 PM | #1 |
Administrator
41306
Rep 21,248
F30 3 Series M Performance Brakes Installed
BIMMERPOST NEWS F30 3 Series M Performance Brakes Installed One of the more exciting items from the full BMW M Performance Parts catalog for the F30 3 series are the M Performance Brakes. These are Brembo 4-piston aluminum fixed calipers on the front axle and 2-piston aluminum fixed calipers on the rear axle. They come in red, yellow, or orange and feature the M logo on the calipers. The internally-vented lightweight sports rotors measure 370 x 30 mm (diameter x thickness) on the front axle and 345 x 24 mm on the rear axle. Unlike the M Sport brake discs, the M Performance brake discs are cross drilled for better grip and grooved to reduce water film build up. The BMW M Performance sports brake system is only approved in combination with at least 18" aluminum wheels and unfortunately do not fit the E9X generation cars (including M3). The M Performance BBK just became available to the North American market and F30POST member nexusonemeover and Turner Motorsports have fitted a pair on their 328i and 335i, respectively. Here are some photos of the rotors and calipers, installed and uninstalled. Initial impressions are good - providing both aesthetic improvements and some performance gains. They chose the yellow versions. The BMW M Performance Brakes for the F30 retail at $2,300, but we've already seen them being sold for sub-$2000. |
05-14-2012, 02:07 PM | #2 |
Rep 139
M Performance Brakes Installed - Pics
Had the brakes installed this morning... job was from 730am to 120pm.
2020 M2C 6mt ** 2019 X3 ** 2017 340i 6mt - retired ** 2016 Cayman S 6mt - retired ** 2015 Porsche Macan Turbo - retired ** 2013 X1 xDrive 28i - retired ** 2012 328i 6mt - retired
haagm58810.50 |
05-14-2012, 02:47 PM | #5 |
Rep 665
How much of a performance gain is there in numbers? I've never seen rotors where the holes weren't drilled all the way through; what's the benefit of what was done with the holes that don't go all the way through on these rotors vs. most other performance rotors?
05-14-2012, 03:18 PM | #8 |
Rep 139
To answer a few questions in one...
So far the biggest difference is how cool the car looks. I haven't used them other than regular braking. Pedal feel under normal braking is similar. I think I feel less linearity with these than stock. Less grab up front...but could just have been cold brakes too. Will post more as they get some miles. And yes, the fit is just about too tight with the 18s. ~$3500
05-14-2012, 07:02 PM | #11 |
641
Rep 1,717
hollaaaaaaaaaaaa. those are awesome. i cant wait to get a pair ... dunno what color yet but gold looks good buddy
Formerly addicted to e46fanatics
Formerly addicted to e90post |
05-14-2012, 07:16 PM | #12 |
Rep 1,285
Both dimpled and drilled rotors offer no performance advantage over plain rotors; they are there for looks alone. Dimpled have the advantage of cracking less. Drilled rotors quickly develop stress cracks with harder use.
05-15-2012, 04:24 AM | #16 |
Rep 69
thanks for the clarification yep, i'm in the EU market so i guess i'll be getting the blue calipers (although i'd rather get the yellow ones, gotta see what my dealership has to say about a color swap)... the plain disks are no problem to me - when they wear out, i'll just put the sloted/drilled ones
05-15-2012, 06:38 AM | #17 |
Rep 139
So this morning on the way to work I used them much more aggressively than normal. They're is definitely more bite grab what ever you want to call it. I think I get a bigger shit eating grin from braking now than anything else with the car.
Multiple heavy braking from triple digit speeds over 45 minutes and no fade. What do you guys want me to do to them and I will?
05-15-2012, 06:49 AM | #18 |
1312
Rep 10,185
Bed them in first
BMW if you are reading, I need a job, Please. |
05-15-2012, 09:14 PM | #20 | |
892
Rep 7,047
This is not personal at all, I just want to say something, those aren't really "cross drilled" in the traditional sense. Cross drilling is drilling all the way through. These are drilled rotors, but the way they are don doesn't give the added cooling effect of drilling all the way through. But, I like this better, as you probably won't get the same noise/sound that's inherent in traditional cross drilled rotors where the air rushing through the holes makes a distinct sound/noise. I had a Brembo set like that on one of my former cars, and that sound was kinda annoying in day to day driving. Cool at first, but became tiresome pretty quickly. |
05-15-2012, 09:24 PM | #21 | |
892
Rep 7,047
They vent gas build up during hard use allowing the pad to better maintain contact with the rotor. Also, the edges provide a "shaving" effect where pad material is removed by the slot edges and that helps keep the rotor surface cleaner to help pad to rotor surface mating for better and more consistent braking. And, those added edges provide an additional friction surface for harder bite. The negative is that pad material collects in those grooves over time, and that will lead to not looking so great later in life. But, just keep'em clean. Also, the larger rotor size helps to keep the rotors/brakes color, and that's very beneficial on hard canyon runs, and especially track use. |
05-15-2012, 09:25 PM | #22 |
892
Rep 7,047
