      03-05-2012, 09:21 PM   #89
nicoz
Drives: 1M
Originally Posted by ianf View Post
I understood that the N55 mid pipes where 2.75", while MadDad's are 3". Not referring to the ends though.
See here: http://www.daddysscp.com/product_p/md135mp.htm
I'm not sure about the exact sizing though... maybe someone here knows. But I do think the last little bit of piping before connecting to the rear part is 3'' on both midpipes... am I correct? Is the beginning of the rear part 3''? If so, and if both midpipes end in a 3'' pipe, then the restriction to flow will be the rear part anyway... even if midpipes were 4 or 5''.. to say something. Am I still correct?
      03-05-2012, 09:26 PM   #90
Zuzu
Zuzu's Avatar
Australia
2827
Drives: M2C HS 6MT
If you are referring to the OEM axle back pipe, before the muffler, then yes it is about 3"..
If you are referring to the midpipes, there is NO 3" pipe on the midpipes themselves.. You sound confused what is the midpipe and what is the axle back section..
      03-05-2012, 10:16 PM   #91
nicoz
Drives: 1M
I'm not confused lol
Well, to answer all this, what is the size of the last part of the stock midpipe you took out? 2,75 or 3''? Then we'll know!
Thanks in advance!!
      03-05-2012, 10:23 PM   #92
-Z-
Drives: Black Pyrat
this...
      03-05-2012, 10:31 PM   #93
Papethova
228
Drives: '08 135/ '11 1M
I forgot the numbers now but the bottleneck would be the 3" pipe at the rear. Dual 2.5s or 2.75s will get restricted at a single 3, obviously dual 3s will too. This is strictly volume measurements.
      03-05-2012, 10:39 PM   #94
nicoz
Drives: 1M
That's what I thought!
      03-07-2012, 06:48 PM   #95
RPM90
892
Drives: 340i M-sport AT
Originally Posted by NC View Post
FYI - I was quoted the following on my order from http://getbmwparts.com/:
Items Total: $333.22
Shipping Method: Standard Ground - US Only
Shipping: $24.95
Handling Fee: $3.95
Order Total: $362.12
Now they are telling me it's $75.00 for shipping even though they provided the quote above. Be warned.
That's a great price for this setup.
I was thinking that an exhaust shop could easily cut out the secondary cats and weld in a same diameter tube in it's place.
It would probably cost less, but at about $370 it's not bad.
Since this won't throw codes, I'll ask a shop how much to cut and weld.
Can't be too pricey and no need to disconnect what's their, unless of course they can't get to it while the system is in place.
Those that have done this yourselves, does it look like there's room to cut and weld in a couple straight pieces while everything is still bolted up OEM?
      03-07-2012, 07:04 PM   #96
NC
Drives: BSM 1M
I have been emailing back and forth with them and there is a shipping policy that states mid-pipes are a flat rate $75 shipping cost regardless of what they email quoted price states. Apparently there are limitations to the software the ties shipping costs to certain parts. I agree that even with the $75 shipping cost their price is somewhat competitive. My dealer quoted something around $433.
In regards to having a shop cut out the secondary cats on the original pipe I guess you could do that but I'd rather keep the original and buy a new N55 mid-pipe. Best of luck in whichever direction you choose.
      03-08-2012, 10:58 PM   #97
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Zuzu, who has the N55 mids, and I will try do a side by side video soon
I will watch for it . . . having a hard time deciding.
      03-09-2012, 02:19 AM   #98
mm1
Drives: exE90 M3/ now1M
I just did the swap to N55 mids, happy for now, can`t say that the drone is gone completly, now it`s just in a narrower rpm range. Sounds maybe a few % louder, cold start beeing a highlight. Now waiting for a back box, my neighbours aren`t gona be happy.
      03-17-2012, 03:10 PM   #99
mojo_78613
mojo_78613's Avatar
Drives: 2011 BMW 1M Coupe
Sounds like a reasonable mod using an OEM part. I wonder why BMW did not consider using the N55 midpipe when this car was being tested and produced..... Is this an easy DIY or should one have a shop install? I saw a video posted by one of the vendors for someone who installed an N55 midpipe, Akrapovic slip on, and a wireless kit.... This set up sounds really good..... If I were to do this, I would have skipped the wireless kit... I'm also trying to find reviews for Ramus's Street Race which is slightly cheaper than Akrapovic's Slip on.... Any thoughts or pointers would be greatly appreciated... One thing that bothers me with some of the vendors, is they are trying to sell high performance exhaust systems and avoid providing facts that would help sell their item... Sorry for going off topic here... Cheers!
      03-17-2012, 04:54 PM   #100
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
if im not mistaken the N54 pollutes more than the N55 that is why secondary cats are needed in the N54 setup.
      03-18-2012, 09:09 AM   #101
mojo_78613
mojo_78613's Avatar
Thanks for the reply. I guess it's safe to keep the OEM (N54) midpipe just from an environmental standpoint... Not sure whether people who swapped their midpipes have experienced any odors due to the lack of secondary cats... Cheers!
      03-18-2012, 01:24 PM   #102
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
i put the N55 mids on my 1M and no change as far as that was concerned
i'd get gas smell on a catless downpipes setup for sure though
      03-19-2012, 10:48 AM   #103
pearlwhites
pearlwhites's Avatar
Drives: 1M, 06 CTT, 07 A8L
Anyone here running the N55 midpipes with a set of catless dp's?
      03-19-2012, 01:11 PM   #104
Pete_vB
Pete_vB's Avatar
Drives: '69 GT3, GT4, 1M, 912
The N55 was designed as a less expensive replacement for the N54. The mission was to duplicate the performance while reducing costs. Cats are expensive, so the N55 was engineered to allow the use of a single cat while still making emissions. Twin turbos and forged internals were also dropped for the N55, further reducing cost but reducing the strength and performance potential, which is why the factory chose the N54 as a base for tuning with the 1M.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
      03-24-2012, 01:08 AM   #105
Denso
Scotland
715
Drives: e46M3 Ruby, Porsche Cayman GT4
2015 BMW M4  [0.00]
Originally Posted by Aussie_in_London View Post
Just ordered mine, will fit sometime next week........
Hi Mate,
Have you fitted this now and do you notice any difference ? I am back next weekend and getting mines fitted a week on Monday. Would appreciate your thoughts
      03-24-2012, 10:51 AM   #106
Aussie_in_London
Aussie_in_London's Avatar
United Kingdom
142
Drives: 1M, i3 & track built Astra OPC
Was on back order and so will pick up next week and fit then get my car over to Hayward & Scott to sort out the rest (axle back).
      03-29-2012, 06:30 AM   #107
h-manuk
h-manuk's Avatar
United Kingdom
37
Drives: BSM 1M Coupe
See around the 2:35 min mark re M button ... Changes mapping, more power
http://www.youtube.com/watch?feature...&v=6IbiTiPO-YM
The M button changes throttle mapping only and does not give you more power. You will get more power on full throttle with overboost with or without M button depressed for 7seconds only!
Changing the throttle map makes the car feel sharper and more responsive. A lot of so called tuners change the throttle map only and then tell the customer that they now have more power.
The only M car I recall that the M button gave more power was in the E60 M5 and E63 M6
      03-29-2012, 06:40 AM   #108
h-manuk
h-manuk's Avatar
United Kingdom
37
      03-29-2012, 07:33 AM   #109
h-manuk
h-manuk's Avatar
United Kingdom
37
So M boss is speaking out his a-hole then?
Probably a miss quote perhaps?
I am having my car on the dyno this week so can find out for sure whether the M button provides more power or not!
      03-29-2012, 07:35 AM   #110
LotusBoy
Drives: BSM 1M, N55, KW's DDC
I think the M-boss means "More power in M mode than in normal mode for the same pedal input". Tuners found no significant power difference testing the 2 modes on the dyno ... It's a lot of marketing talk, IMO. Like when he speaks of different maps, he means throttle maps, not engine ECU map ...
1addicts
