DIY - Removing / Replace Roundel (roundel removal)
03-30-2007, 11:05 PM | #23 |
89
Rep 3,011
the e92rear roundel has been a concern. Search for Picus' thread on "problem with e92 roundels" for details.
"Teach the ignorant. Ignore the stupid."
05-20-2007, 09:25 PM | #25 |
143
Rep 6,333
Cool! I did the sticker mod... looks the same!
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
05-20-2007, 09:57 PM | #26 |
339
Rep 7,719
05-20-2007, 10:13 PM | #27 |
89
Rep 3,011
the grommets are re-usable if the car is new. On older cars the grommets crack over time.
05-20-2007, 10:19 PM | #28 |
Rep 1,219
Are the roundels for the 335i the same as other models? I was going to buy replacements on one site, and they said it will fit e90, but not 335i or convertible.
05-21-2007, 01:11 AM | #29 |
339
Rep 7,719
If you have read the first and second page, you would see that there is a problem with the roundels fitting on the trunk of the E92s.
05-21-2007, 06:50 AM | #30 |
Rep 1,219
06-16-2007, 02:11 PM | #31 | |
Expect the Unusual
259
Rep 1,344
08-09-2007, 02:32 AM | #34 |
150
Rep 7,390
got mine on bimmerfreak.com
02-11-2009, 04:19 PM | #35 | |
Flying Mach .92/Driving E92
Rep 50
07-17-2009, 01:34 PM | #36 |
Rep 56
The nylon idea is the best way. Dental floss was hard (for me) to get underneath the roundel. It doesn't even have to be nylon, just something thin that won't break or scratch your car (no metal). I used a small piece of window blind that I found in my garage. Took me all but ten seconds.
08-06-2009, 10:57 AM | #37 |
In The Flesh
18
Rep 122
I got mine this afternoon...
The hood roundel, went out easy and the CF fitted perfectly. The Trunk Roundel was slightly harder to pull out, simply because of the double side tape used... Though the CF roundel, did fit in, but I would say 95% it is not the exact fit. but you will need to be picky to complain. Yet, remain to see when it rains if water will leak inside the badge and start dripping... The steering wheel, that was easy, I just stuck the CF on the top of the original one.. Emm.. I am not quite happy from the result; it looks a little thick, if you know what I mean... It was not just a sticker rather a CF steering wheel roundel... I am not quite sure if I will try to pull out the original one... Emm... Last edited by Bimmer /E93; 08-08-2009 at 08:53 AM.. |
08-24-2009, 12:58 PM | #38 | |
ED RN
19
Rep 423
Thanks. |
03-27-2010, 10:17 AM | #40 |
121
Rep 2,099
Does anyone know what to do if the plastic pieces happen to snap? Both of the plastic tabs broke while I was trying to loosen them and are stuck inside the hood.
Any ideas? |
03-27-2010, 10:41 AM | #41 | |
138
Rep 2,731
i went from top to bottom though when i pulled it off since the pins behind are on the left and right. someone had used a little silicone to the back of the roundel to keep it in place so a good tug was needed to pull it off. |
06-29-2010, 12:14 AM | #42 |
Rep 100
Tried Pry the hood and dental floss and screwdriver no luck the Nylon worked like a charm.
trunk was even easier. Worked Great thanks !!! |
09-18-2010, 11:46 PM | #43 |
Texan By The Grace of God
9
Rep 299
wow ... all of the credit card and nylon talk ...
pop the hood, look directly behind the release lever. see the small hole ? see the plastic nipple in there ? that is the peg from the roundel. push it with a screw driver. that will be the peg on the right side of the roundel. now just grab hold of the roundel and pull it off. takes about 15 seconds and no possible way to scratch the paint. |
09-21-2010, 07:25 PM | #44 | |
9
Rep 299
