04-30-2024, 08:26 AM | #89 | |
Rep 867
04-30-2024, 07:35 PM | #91 |
Rep 376
05-01-2024, 08:27 AM | #92 | ||
1615
Rep 3,958
This would be a future track car and the running costs to include maintenance, repair, and catastrophic repair costs are important. I've been doing research into some wear and tear consumables on the C8: Genuine front Z51 rotors - ~$190 - https://www.gmpartsdirect.com/oem-pa...bC12OC1nYXM%3D Catastrophic power train replacement costs: Genuine LT2 long block - ~$2,000 - https://www.gmpartsdirect.com/oem-pa...Y4LWdhcw%3D%3D This is probably the most expensive powertrain component on the C8 Corvette, but it's still less expensive than a replacement ZF 8HP76: New 8 speed DCT - ~$9,700 - https://www.gmpartsdirect.com/oem-pa...YtMmwtdjgtZ2Fz I think the C8 is going to be a pretty popular and plentiful track car in a few years. |
Ronin76861.50 two_three_two629.00 |
05-01-2024, 08:36 AM | #93 | |
Rep 867
05-01-2024, 09:00 AM | #94 | |
Rep 63
05-01-2024, 09:07 AM | #95 |
Rep 63
Where are you guys buying parts for this car ? I don't think you can get rotors, brakes, etc for M cars at autozone or your local parts store. I would definitely go OEM if I ever had yo repalce the equipment. When I google M2 rotors Im being shown rotors that are very expensive.
05-01-2024, 10:07 AM | #96 | |
Car Geek
3718
Rep 3,626
laughMan82.50 |
05-01-2024, 10:24 AM | #97 | |
Professor
2366
Rep 1,879
Drives: '23 M2 & '22 X3 M Competition
Good luck trying to get a new DCT if yours fails also. Cars have been out of commission for months waiting on a new DCT. If you're looking for a dedicated track Corvette a C5 Z06 or C6 is going to be a much better choice than a C8. |
05-01-2024, 10:27 AM | #98 | |
Professor
2366
Rep 1,879
05-01-2024, 11:54 AM | #99 | |
2901
Rep 1,814
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is |
05-01-2024, 11:58 AM | #100 |
2901
Rep 1,814
That's because the amount of people who walk into shops with the original rotors at 90,000 miles and just want $200 Autozone pads installed is comically high. We have to remember that we're talking about BMW M cars here folks, not a Ford F-150 or a Corolla. These cars use high performance, speciality made parts, and rotors are very much so one of them. The braking system is part of what makes an M car, perform like an M car. If that's something you're not willing to live with, there are plenty of 30i/40i models.
05-02-2024, 08:06 AM | #102 | |
Rep 1,207
Maybe BMW specs are the same? Maybe tighter? Maybe less tight? I don't know. To do the job *right* if pads are going to be replaced the rotors need to be checked to ensure they conform to whatever BMW calls for. Sorry to be such a stickler but in a previous career as a journeyman machinist, in some cases working on aircraft and a few times space flight hardware, then in a more recent career working on the software for safety critical rail road train and track controllers adhering to what was called for to ensure proper/safe manufacturing of the hardware and the proper/safe operation of train/track controllers I can't recommend not following what BMW calls for. But if one can get his hands on the BMW M2 rotor specs and confirm the rotors are in spec even after X miles of service with the factory installed pads that's fine. Or if the rotors are *not* in spec arranging to have them brought into spec -- with surfacing -- that's fine too. |
Ronin76861.50 |
05-02-2024, 08:18 AM | #103 | |
Rep 1,207
Fortunately both tires were deemed repairable and repaired and now with over 7500 miles the repaired rear tires are still fine. Thank goodness. A new rear M2 tires (Michelin...) costs nearly $600 mounted and balanced. And -- short version -- is it is possible that both tires -- the punctured/unrepairable tire and the other perfectly fine tire -- will have to be replaced if the tread depth difference between the new tire and old tire is too great. |
05-02-2024, 02:10 PM | #104 | |
Professor
2366
Rep 1,879
xtougher605.50 |
05-02-2024, 03:41 PM | #105 | ||
1615
Rep 3,958
Are you sure there is still a delay on a new DCT? |
05-02-2024, 04:41 PM | #106 | |
Professor
2366
Rep 1,879
The DCT is still having issues. A new owner just posted about his brand new Stingray back at the dealer with 250 mi with multiple transmission fault codes. There's no reason they should be having these issues going into the 6th model year. Also consider the horrible GM dealership & service experience. I've never let a Chevy dealer work on my Z06, and I wouldn't touch a C8 even if you gave it to me. |
05-02-2024, 04:57 PM | #107 | |
1615
Rep 3,958
I won't do it again though. My N55 self ventilated and took out the steering rack in the process at VIR. It has had a ZF 8HP45 replacement under the extended warranty. When you track cars, engines, transmissions, etc. are all consumables. You need to factor in the cost to replace these major end items out of warranty. Regular maintenance costs are nothing compared to catastrophic repair/replacement costs. |
05-02-2024, 05:16 PM | #108 | |
Professor
2366
Rep 1,879
Her's: '22 X3 M Competition, Marina Bay Blue, Tartufo interior, 21" 892M wheels, executive pkg, carbon fiber trim.
His: '23 M2, Toronto Red Metallic, M highlight interior, carbon fiber interior trim, shadowline, lighting pkg, auto cruise, live cockpit pro. |
05-02-2024, 06:27 PM | #109 | |
1615
Rep 3,958
$20k seems to be on the high end but it is not nearly as bad as a S58 replacement which would likely cost anywhere from $30-40k: https://g87.bimmerpost.com/forums/sh....php?t=2069318 The interesting thing is that the C7 LT2 replacement cost ($8,146) is significantly higher than a C8 LT2 replacement (~$2,000): https://www.gmpartsdirect.com/oem-pa...Y4LWdhcw%3D%3D If you look at the last few pages, you'll see that a G8X vehicle is worth almost nothing with a catastrophic powertrain failure. Vehicles that have such a high powertrain replacement cost concern me. |
05-03-2024, 12:07 AM | #110 | |
606
Rep 486
Even called some random shops around me and even they said they would change rotors with the pads...couldn't tell if that was just an upsell tactic, or a general rule these days. |
