04-19-2024, 09:01 PM | #89 |
Rep 1,148
Kevin_The_Clean13403.50 |
04-19-2024, 10:11 PM | #90 |
Rep 376
Drives: BMW G87 (2024),BMW E82(2009)-s
MineralGreyMetallic715.50 |
04-20-2024, 01:42 AM | #91 |
3404
Rep 4,020
That's why I recommended RG Sport instead.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
04-20-2024, 01:02 PM | #92 |
Licensed Professional Slacker
1330
Rep 812
Drives: 2024 M2 and 2023 Mazda CX-30
Mine shipped a couple days ago. Due this Tuesday
04-20-2024, 01:12 PM | #93 |
716
Rep 571
My box from Autecknik was curiously covered in RG Sport tape. *shrug*
04-20-2024, 01:47 PM | #94 |
1330
Rep 812
04-22-2024, 10:44 AM | #95 |
Rep 1,148
Update for all the isweepers,
Washed car today after 300 miles with new pads. Rinsed wheels (ceramic coated) heavily with pressure washer. Used a foam cannon to smother each wheel with soap and let stand for about 3 minutes then vigorously rinsed with pressure water. Didn’t use a brush or mitt. Wheels are sparkling clean. Hoping your experience is similar to mine. Edit: for interested parties, soap I’m using is Adam’s “Mega Foam”. YMMV |
04-29-2024, 08:49 PM | #96 |
Commander-In-Chief
2203
Rep 8,949
Drives: 2023 M2 Coupe, 2020 GLE 450
Actually worked out fine time wise.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
04-29-2024, 08:52 PM | #97 |
Commander-In-Chief
2203
Rep 8,949
ISeep pad installation
Installing the iSweep 1500s now. First corner on, second will be a breeze. Rears slightly more difficult because of the electric parking brake. Those calipers are massive compare to my F82's. VT Forged wheels go on Thursday.
04-30-2024, 12:26 AM | #98 |
Rep 935
Any tips on the pad install?
Do you need a caliper spreader? Do you need to remove the cap on the fluid reservoir? Have any torque specs? None of the bolts are single-use are they?
///M
04-30-2024, 09:13 AM | #99 | |
Commander-In-Chief
2203
Rep 8,949
Pad swap
- There are no bolts, just two M12 nuts (14mm wrench). Torque of the nuts is 95 Nm (70 ft lb) per the TIS. Technically supposed to replace the nuts, but that may be overkill. - Remove pad securing pins before taking off caliper; clean with Scotch-Brite or equivalent. - If you don’t have many miles on the car you may not need to spread the pistons, but I found it helpful in getting the caliper back on. Needed a soft face hammer to get the caliper off. - Used silicone grease (ATE Plastilube or equivalent) on backs of the pads and pad sliding contact points - Doing rears today, which are slightly harder because of the electric parking brake. Video: https://www.youtube.com/watch?v=Hva0-gY8qGA. Tightening torque for rear M12 bolts is 130 Nm (95 ft lb). Last edited by GregW / Oregon; 04-30-2024 at 12:42 PM.. |
BroDoze302.50 Newgenbimmer105.00 |
04-30-2024, 01:32 PM | #100 |
21695
Rep 8,689
Thanks for posting your experience
For some reason, I hate cleaning wheels these days. I’m not sure why it seems so daunting but it’s right up there with cleaning the inside of the cars windows! It seems like an endless task
04-30-2024, 01:36 PM | #101 | |
21695
Rep 8,689
05-01-2024, 09:46 AM | #102 |
Commander-In-Chief
2203
Rep 8,949
Rear brake pad swap
Did the rears yesterday. The electric parking brake motor needs to be removed which is kind of a PITA, but doable. After that and manually rotating the mechanism you do need to depress the piston with a tool. I also found getting the bolts to the specified 95 ft lb of torque is difficult when not using a lift to give adequate wrench clearance. Now to go bed them in.
LAGWAGN285.50 |
05-01-2024, 06:29 PM | #104 |
Commander-In-Chief
2203
Rep 8,949
Many will suggest "bedding" by doing multiple hard brakes from like 65-20 mph, which I have done before, but really don't think is necessary unless your rotors are grooved.
chris7197381.50 |
05-02-2024, 01:57 AM | #106 |
3404
Rep 4,020
Ya... But did the pads get bedded & were the rotors properly seasoned... ? Normal driving doesn't allow the pad material transfer material to get hot enough to leave that deposit of film on the surface of the rotors required for maximum stopping power.
05-02-2024, 09:54 AM | #107 | |
Rep 1,148
Thanks for your interest. |
ScottyRyan20191329.50 chris7197381.50 |
05-03-2024, 02:02 PM | #108 | |
3267
Rep 1,844
I'm really happy for all you guys getting these pads. |
05-03-2024, 07:46 PM | #109 |
Rep 65
Does anyone have a coupon code for any retailer who sells the pads? $620 is a bit steep for pads, even if they’re worth it.
DarkNight707534.50 |
05-03-2024, 08:05 PM | #110 |
Rep 1,148
