10-18-2013, 12:07 AM | #441 |
915
Rep 3,456
Drives: Harrop E90 M3
I see your 330 agility and raise you spec miata
10-18-2013, 10:12 PM | #443 |
Rep 338
Drives: VW TDi & BMW M3
X1>McLaren mp4-12c
2013 E92 M3 | Le Mans Blue | 6 Speed Manual | Competition Pack | Premium Pack | Cold Weather Pack |
10-18-2013, 10:31 PM | #444 |
11818
Rep 23,187
10-19-2013, 11:02 AM | #445 | |
Rep 338
10-20-2013, 06:08 AM | #446 |
11818
Rep 23,187
yeah i know, probably my first pick of exotics right now. only thing is it has a little gtr, drives itself stigma.
11-07-2013, 12:48 PM | #447 |
Rep 184
Damn, great build. I love track built cars.
I'm hoping to make my e90 into a track car someday. But I need way more track experience. A stock m3 is way more capable than I am still. I've seen an E90 race car build: http://www.m3post.com/forums/showthread.php?t=638354 I haven't seen a dedicated track build e90 yet. |
11-07-2013, 12:53 PM | #448 |
11818
Rep 23,187
sold all my interior for the e46 as well as the csl-zcp bbs wheels that came with it. also picked up a spare set of ec-7s with nt01s from wootwoot last week. working on a few things this offseason. traded my x5 3.0 for a 2011 x5d and also bought a trailer so will start towing car to the track. may not be all the time until my car isnt driveable on the street anymore. got it mostly for longer hauls to farther away tracks.
1. rod bearings 2. BW race exhaust if my eisenmann sells 3. BW cf diffuser 4. possible switch to r1 depending on fit have 2 285-30 and trying to run those square 5. pull fenders more 6. more aggressive brake pads, cobalt xr2s 7. more aggressive alignment, -4.25 front, -3 rear 8. replace studs, had one break already in half season. 9. vanos evaluation 10. more aggressive gearing, 3.91 or 4.10 Doubt all this will be done this off season, kind of a process and i still plan to drive over the winter as well.
11-07-2013, 07:50 PM | #449 |
1580
Rep 8,077
Drives: 11 E90 M3 Individual
-4.25 and -3.0? That's a TON of camber. Might want bigger sways or stiffer springs instead. You should be able to fit 285s square no problem. Depends on how pretty you want your little fenders to look. Remember...RACECAR!
Screw the diffuser. I'd do the gears first. I just scored a used BW race exhaust for less than half price! Pretty excited about it!
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
11-07-2013, 07:57 PM | #450 | |
11818
Rep 23,187
diffuser is just to go along with the exit of the bw race as you know. you will have to report back to me about that thing, my concern is it will be way too loud for me. overall goal is to remove some of the initial compromises that were made with my setup so more aggressive pads, tires, alignment, gearing, weight loss, and as a last resort power and aero.
11-07-2013, 08:11 PM | #451 | |
1580
Rep 8,077
You know you can get the BW exhaust that exits out of the OEM diffuser. It is pretty f'ing loud but I've been told the worst part is the drone.
11-07-2013, 08:37 PM | #453 |
11818
Rep 23,187
Have -3.5 and -2.75 right now. I trust the builder as he drives the primebmw car with -4.4 front I believe. Also pro driver. Still wearing outer edge more than would like at this pt on nt01s.
11-07-2013, 08:54 PM | #454 | |
1580
Rep 8,077
Its normal to roll on the outer edges. Its one of the short comings of a macpherson strut and wishbone front suspension. I do wear the outer edges of my tires but it doesn't result in the outer edge cording.
11-07-2013, 09:05 PM | #455 | |
11818
Rep 23,187
11-08-2013, 01:01 PM | #456 |
Rep 1,424
camber
I run either -4.4 or -4.6 front.....can't remember. 1000# front springs. We have never corded a front tire.....always a rear without much switching around.
We may soften up the rear springs a bit the next time out. Then soften up the front springs. Changes....always changes to the set up. Speed: Well I put down a 1:22 dead at PIR last time out with heat cycled out tires (307 rwhp and 3175lb.). The GTS4 national champ runs high 1:19 with more power, less weight and 320 wide slicks. The car is in the ball park if we all loose some weight .......now where are my cf/fiberglass doors? |
11-08-2013, 01:11 PM | #457 | |
Rep 1,424
11-08-2013, 05:44 PM | #458 | |
1580
Rep 8,077
I would think that rear suspension travel is really limited by the spring travel. In the OE design there's not a lot of travel to gain unless you go to a true rear coil over design. Then you get more travel and more dynamic camber change. So more negative camber will increase your contact patch in the corners. Am I incorrect in my thinking on this?
11-15-2013, 09:59 PM | #459 |
Rep 224
I know multiple people running about the same camber settings I mentioned on R1's. Both great drivers. One car GTS4 and former national champion and other GTS3 (Zima Motorsports car 2nd place this year). The GTS4 car was able to do 2:23 at Road America and 1:29 on autobahn south which is very fast times. The zima car was able to do 1:31's at autobahn on R6's though, his BFG time was slightly slower.
I have seen a few people with more camber but that is with true slicks non dot approved. Everyone sets up the cars differently just feel like maybe there is something else you might want to take a look at before setting up with that much camber |
11-15-2013, 10:01 PM | #460 | |
11818
Rep 23,187
11-15-2013, 10:10 PM | #461 |
Rep 224
Thats a good idea. What settings are you using for toe? Are most of the tracks tighter/technical or longer straights? Sometimes on the more technical tracks you can run a more aggressive toe set up.
11-15-2013, 10:12 PM | #462 |
11818
Rep 23,187
i have neutral front toe and slight in rear i believe. 2 tracks i run usually arent that tight and have lot of speed.
