BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Official: N54 engine with Bi-Turbo 306HP, 400Nm ...
02-17-2006, 12:19 PM | #23 |
1312
Rep 10,185
Double progress: high achievement, high efficiency. In order to bring a fascinating driving experience with values consumed up-to-date in agreement, BMW developed a row six cylinder petrol engine with Bi-turbocharger, fuel direct injection and full aluminum crank case as world-wide first a car manufacturer. The conception of the turbochargers already makes a contribution for consumption reduction. Because the turbines consist of high-temperature resistant special steel and bear temperatures of up to 1050 degrees, can be done without the refreshing effect of a increased fuel supply. Straight ones under full load result from it noticeable consumption reductions.
The key function in the concept for as economical a handling fuel as possible comes however the High Precision Injection. The new generation of gasoline direct injection fulfills also in practice expectations set into it regarding economy, without thereby reductions would be necessary with the dynamic qualities of the engine. High Precision Injection permits a more accurate mixture dosage as well as a higher compression - ideal conditions for an increase of the efficiency and a clear reduction of consumption. This becomes possible due to the central placement of the Piezo injector between the valves. In this position the new injector opening outward can distribute the fuel conically and particularly evenly in the combustion chamber. With the development of the new row six-cylinder with Bi-turbocharger and direkteinspritzung BMW opens a new chapter for already an engine principle quite old in the reason. Nevertheless could only recently the 100. "birthday" of the turbo engine to be celebrated. In November 1905 of Swiss engineer Alfred Buechi to the patent announced loader
BMW if you are reading, I need a job, Please. |
02-17-2006, 12:20 PM | #24 | |
3613
Rep 10,376
Still, for those of us in the U.S., rumor is we will end up with a 3.5 liter instead of the bi-turbo 3.0. |
02-17-2006, 12:21 PM | #25 | |
119
Rep 2,909
02-17-2006, 12:26 PM | #29 | |
Rep 996
2006 330i Monaco Blue | Grey | Walnut ...Manual | Sports | Premium | Cold | Nav | Comfort Access | PDC | Sirius | Sunshade ...M-Tec Steering Wheel | M-Tec Shifter | TLC ...Performance Center Delivery | Oct 14, 2005 |
02-17-2006, 12:26 PM | #30 |
1312
Rep 10,185
Incase you didnt read the release bit I posted
Its 2 Small Turbos, each feeding 3 cylinders
02-17-2006, 12:31 PM | #33 | |
119
Rep 2,909
02-17-2006, 12:42 PM | #36 |
24
Rep 472
Turbo cars are nice but the turbo lag kills it. I would talk a NA engine over a turbo anyday. Do you know what a bitch it will be to replace those little fvckers
2006 330xi
BMW, please get rid of the RFT's and give us a spare tire! |
02-17-2006, 12:42 PM | #37 | |
1312
Rep 10,185
02-17-2006, 12:43 PM | #38 | |
1312
Rep 10,185
02-17-2006, 12:52 PM | #40 |
Rep 92
Ha HA I called the intercooler back in December in the spy pics http://www.e90post.com/forums/showpo...8&postcount=10 !!! Another notch on my 335 predictions belt :rocks:
WOW Tine gave us the exact HP numbers weeks ago !!! |
02-17-2006, 01:01 PM | #41 | |
1312
Rep 10,185
Pistons are different shape for Direct Injection Fuel system now very high pressure for Direct Injection
02-17-2006, 01:04 PM | #43 | |
16
Rep 547
Drives: 335 I Coupe
link http://www.auto-motor-und-sport.de/n...der.104140.htm a message regarding the presentation of a new 3.0 l six-cylinder turbo engine. it will be shown at the 76. genf autosalon from 2.-12. march 2006. this engine will, in the near future, first make it's debut in a new BMW-modell for the market(E 92?). other modells may/will follow. it seams to me "Tine" was well informend. please forgive my bad english. |
02-17-2006, 01:06 PM | #44 | |
1312
Rep 10,185
