BMW 5-Series (G30) Forum Engine, Exhaust, Drivetrain, Tuning Modifications M550 exhaust flaps open = much better sound
      07-28-2018, 09:14 PM   #23
Who's on first
Who's on first's Avatar
Drives: A-10C
Originally Posted by forza1976 View Post
Did this on my previous F82 and while that was fun, the cold start of the F82 with the flaps open all the time was obnoxious. And this sounds better.
Ready for it.....
[COLOR="Red"]Pull fuse F203![/COLOR]
1) Turn car on, put in sport. *Ensure the flaps are open
2) Go into trunk, pull fuse F203 (while car is still on)
3) Verify flaps are still open
4) Close trunk
5) Enjoy
Exhaust Flap wiring diagram:
https://www.newtis.info/tisv2/a/en/g...use/1VnYS9CGy7
So, the flaps are fully open in Sport, and not Sport+?
      07-29-2018, 11:50 AM   #24
forza1976
forza1976's Avatar
Drives: BMW
2022 BMW M3X  [10.00]
Both
      07-29-2018, 11:57 AM   #25
ksoze
ksoze's Avatar
Drives: 2018 M550iX
forza1976's mod is highly recommended.
The unbridled sound is prefect and better represents the beast lurking in the M550. Compared to the stock piped in artificial sound and the half capped flap, it has a nice growl without being too aggressive.
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
      08-04-2018, 10:39 PM   #26
/// M sa
/// M sa's Avatar
242
Drives: F80 MG
So my flaps are half open in sports and sports plus.. what gives?
      08-05-2018, 08:37 AM   #27
ksoze
ksoze's Avatar
Drives: 2018 M550iX
No, but this keeps them open in all modes. Basically Sport exhaust in all drive settings.
      10-06-2018, 08:17 AM   #28
Mile High M Power
Drives: 2018 M550i Xdrive
Where is the F203 fuse? I've looked all around the car and can't find it. Pics?
      10-06-2018, 12:47 PM   #29
ksoze
ksoze's Avatar
Drives: 2018 M550iX
In the trunk. Right side wall, remove felt cover. Use map in post above to locate the right fuse.
      10-10-2018, 07:12 PM   #30
RASHID007
Drives: 2014 535d X-Drive
Good day all. Great sound improvement with flaps open. I have followed instructions in first post thanks.
Problem I have is every month or so it starts to rattle as the zip ties come loose. I've had to re-zip tie so many times I'm an expert at it but for some reason one or the other always comes loose and makes the most ANNOYING and embarrassing rattling noise.
I'd like to try the method of pulling the fuse but for some reason I cannot get these metal clips back into place as they were when stock. The 2 pieces/grooves that the clip connects simply don't line up for me to squeeze the clip and put it back into place. They are at 90 degree angle to each other. Impossible to put clip in unless the grooves are parallel.
Doesn't help that I don't have a picture of how it looked like stock maybe I'm putting the clip back in the wrong orientation? Anyone have a pic?
Any advice would be greatly appreciated. Would love to put clips back as stock and go with the fuse method instead. Thank you.
      10-10-2018, 07:38 PM   #31
Mach550
Mach550's Avatar
Drives: 2019 M550i
2019 BMW M550i  [8.00]
use a metal strap like a pipe clamp, plastic definitely isn't perfect for this.
      11-01-2018, 11:59 PM   #32
RASHID007
Ready for it.....
4) Close trunk
5) Enjoy
This is great advice thank you. Had dealer put clips back in then did this fuse trick way easier and the annoying rattle is GONE! THANK YOU!
forza19763399.00
      11-02-2018, 09:42 AM   #33
forza1976
forza1976's Avatar
Drives: BMW
Sweet, glad this worked out for ya.
      11-20-2018, 07:11 AM   #34
billybarr
Drives: 2015 M3 yas marina
Lol, forza Put it so simply for all of you guys. You're doing so much work for nothing. Just pull the fuse. That's it nothing else. Flaps open 100% all the time
B
forza19763399.00
      11-26-2018, 04:35 PM   #35
sitcom323
Drives: ‘23 i7 xDrive60
This is such an awesome jailbreak. I plan on trying both ways lol
Daily: 2023 i7 xDrive60
GONE: 2022 X7, 2019 750i, 2016 M4 Competition, 2014 550i, 2008 335i, 2005 MINI Cooper S, 2002 X5 3.0, 1999 328i
      12-21-2018, 08:04 PM   #36
LetsrollM550
LetsrollM550's Avatar
Drives: M550i
Ready for it.....
4) Close trunk
5) Enjoy
Does this work on a g30 M550 as well? Thanks
      12-21-2018, 09:57 PM   #37
ksoze
ksoze's Avatar
Drives: 2018 M550iX
Yes.
      12-22-2018, 10:51 PM   #38
LetsrollM550
Drives: M550i
Yes.
Thanks works great!!
      12-23-2018, 07:53 AM   #39
ksoze
ksoze's Avatar
Drives: 2018 M550iX
It is just enough growl to be heard, but not enough to attract unwanted attention or drone at cruising speed.
      12-29-2018, 07:12 PM   #40
HomeIn2
HomeIn2's Avatar
Drives: 2020 X5 M50i
Ready for it.....
Pull fuse F203!
4) Close trunk
5) Enjoy
My first full day with my new M550i in this is one of the first few mods (ok several) I completed. Thank you brother!!!
forza19763399.00
      04-27-2019, 05:10 PM   #41
BardG
213
Drives: 2019 M550xi
M550 Fuse Pull
I pulled Fuse #203, to be honest I haven't noticed a big difference, I can hear a deeper tone at idle or low revs, but in daily driving not much louder than stock at all. Is this the same for anyone else who's tried this?
      04-27-2019, 05:13 PM   #42
ksoze
ksoze's Avatar
Drives: 2018 M550iX
Unless you pulled the fuse while in Sport Mode, it won't take. If you had done it, you would notice. Make sure the car is set to Sport mode, then pull the fuse.
BardG212.50
      04-28-2019, 11:26 AM   #43
BardG
213
Drives: 2019 M550xi
Thank you. Two questions:
1. How do I know if the flaps are fully open? (Just by the sound?)
2. Should I do this on a fully cold start?
      04-28-2019, 12:29 PM   #44
ksoze
ksoze's Avatar
Drives: 2018 M550iX
1 . After the cold catalytic warm up on start up, see if the exhaust is coming from both sides. The sound will literally and figuratively be twice as loud when driving or under throttle, IN ANY DRIVING MODE.
2. The car has to be put in Sport Mode, then while still running, get out of the car and pull the fuse.
5post
