07-30-2024, 12:37 PM | #45 |
3812
Rep 7,095
ML-10RT now available for Pre-Order The ML-10RT forged wheel started life as an engineering passion project. You brought it to life. It’s the moment you’ve all been waiting for. The green flag has dropped and the Forged ML-10RT pre-sale is officially underway! Reserve your set now to ensure you receive wheels from the first production batch, and save 15% off + free shipping in the continental U.S. Due to extremely high demand, we expect a number of popular fitments and finishes to sell out, so act fast. Pre-order discounts are based on product availability, and are subject to change at any time. Please note we fulfill orders in chronological order, so the sooner you place your pre-order, the faster you will get your wheels. Features AN EVOLUTION OF PERFORMANCE - The ML-10RT honors the motorsport designs so many of us fell in love with during the golden era of Touring Car and Sports Car racing. However, its ancestry ends there. Our in-house engineering team pulled out all the stops to create a monoblock forged wheel that's lighter, stronger and stiffer than multi-piece wheels of the past. Utilizing the latest forging technology to offer an impeccable design, backed by Real Performance, at an obtainable price point. SIDE-MILLED SPOKES - The ML-10RT incorporates Apex’s extra-deep, side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Often deemed cost-prohibitive by others, this aggressive side-milling shaves critical weight, and adds a sharp contrast in the design of the center spoke area. SPRINT INNER LIP - The ML-10RT borrows the race-proven Sprint Spec inner lip from our Sprint Line wheels, providing critical strength to the unsupported inner lip of the wheel. Adding 32% more material where it matters most. Don’t settle for under-engineered wheels, attack both the track and your cities potholes with confidence 10K TONS OF PRESSURE - To make our forged wheels the strongest we can, we applied as much pressure as possible using a 10,000 ton forge. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure. TRUE MOTORSPORT BLANKS - Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch to give us total control over the final product. INDEPENDENTLY TESTED - We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. Our Touring Line wheels are independently tested by ITS at their Michigan facility following JWL standards but pushed to much higher loads and much longer durations. MACHINED LIP - The ML-10RT is our first forged wheel to feature a machined lip, which really makes it a standout design within the Apex catalog. The lip in combination with the mesh center pays homage to the glory days of motorsport, and is sure to dramatically transform the look of any car. The best part - the machined lip has a gloss clear coat and doesn't require polishing. VEHICLE SPECIFIC SPOKE PROFILES - The lipped design of the ML-10RT inherently limits brake clearance. Rather than making every fitment as conservative as possible, we utilized our extensive 3D vehicle scanning library to shrink wrap each fitment's spoke design around respective OEM and popular aftermarket brake kits. Leveraging our vehicle research and engineering team, we find a perfect balance of concavity and brake clearance. BUILT FOR IMPACT SOCKETS - Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All Apex wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast. OEM CENTER CAP COMPATIBILITY - Love that OEM+ look? Us too. Our engineers went the extra mile and incorporated a flush mounted OEM center cap support into the ML-10RT. Whether you want to show off your included Apex center caps or stick with your OEM caps, the ML-10RT will seamlessly accept both. LASER-ENGRAVED SPECS - As car enthusiasts ourselves, we know how frustrating it is to locate and decipher wheel specs that have been hastily marked on a wheel or become unreadable over time. Our Touring Line wheels have laser-engraved specs on the barrel, in plain sight, making them easy to find and read. Pre-Order your set of ML-10RT today Buy with confidence. With only a 25% deposit initially required for these wheels, you can Pre-Order today and lock in the deep discount and ensure you get your preferred fitment and finish early. Don’t miss your chance to be the among the first to run this all-new Apex design. Check out your vehicles wheel configurator or Fitment Guide for availabile wheel sizes and fitment information such as tire options and brake clearance.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey |
08-21-2024, 04:10 PM | #46 |
3812
Rep 7,095
Centercap Support: A Community Requested feature When the ML-10 was initially designed by our Engineer Josh, it was created without support for a centercap. This is a logical approach for his intended use case: a widebody E46 track car driven at speeds where the caps just get in the way. After we launched our ML-10 design survey, it became clear that the majority of the community preferred to have the ability to run a center cap, whether it be ours or an OEM BMW cap. Adding the material in to allow the caps to seat into the wheel changes the look of the ML-10RT design, but we love the clean cap integration. Check out the photos below to see an 18x9 ET30 5x120 BMW wheel with the center cap support Beyond just the cap, This is our first showcase of a profile 2 wheel. This size (18x9 ET30) is one of our most popular sizes for non-M 3 series and some M cars as well. Even with a lower profile like this profile 2, the lip depth of the ML-10RT remains the same which is a unique aspect of the monoblock construction that separates this design from similar 3-piece wheels.
09-30-2024, 11:58 AM | #47 |
3812
Rep 7,095
On Car photography of the ML-10RT is now available While the initial look at the ML-10RT wheels has create huge interest within the BMW community, we know that seeing true on-car shots of these wheels plays a huge role in your decision on whether or not to run them in the future. We’ve already shot a number of key chassis on our ML-10RT wheels and will continue to bring in more cars to give you all a good idea of what these wheels look like on car and off. Click the images below to see galleries of these cars with multiple sets of wheels featured: Upcoming shoots include an F87 M2, F31 3 series, and a G80 M3. Stay tuned!
10-02-2024, 01:18 PM | #48 |
3812
Rep 7,095
Time is running out! Be one of the first to pick up the all-new Forged ML-10RT for your BMW at a discounted price. The discounted pre-order period ends on October 24th at 11:59 PM PST. Prices will then increase to MSRP. The first production batch is limited, so submit your pre-order today to get 15% off + FREE shipping* with just a 25% deposit.
