      03-19-2023, 08:50 PM   #1
jeanpxrk
Drives: bmw z4
1997 740il single misfire common causes?
1997 740il with 142k miles on it. The guy replaced spark plugs on there but get a check engine for misfire intermittently. No oil in the spark plug wells with “hesitation” at high rpm in 2nd gear.
Could it just be coils or injectors?
      03-24-2023, 04:02 PM   #2
Chihuahua
Chihuahua's Avatar
4082
Drives: E30 329iS, E65 Alpina B7
Do you keep getting misfire on the same cylinder?
      03-24-2023, 04:55 PM   #3
jeanpxrk
Drives: bmw z4
yes i do
      03-26-2023, 03:07 PM   #4
Chihuahua
Chihuahua's Avatar
4082
yes i do
Did you try moving a known good ignition coil over to the cylinder that's misfiring?
