      05-20-2013, 08:39 AM   #1
Mr.Snail
Drives: bmw
Need a computer for <$350
Im looking for a simple reliable computer for under $350.
I will use it for surfing the web and basic microsoft tasks as well as logging my Procede.
Also id prefer if it had windows 7 as i do not like the look and desgin of windows 8
Any suggerstions?
      05-20-2013, 10:50 PM   #2
amanda hor$t
87
Drives: a380
netbooks will run you in the 200-250 range... more than enough power for browsing and office
if you want a full screen, you might be able to find something for ~400
      05-21-2013, 12:38 AM   #3
Zeros and ones
Zeros and ones's Avatar
Drives: 128i MT6 M Sport, Dinan 5
2011 128i  [5.66]
2000 Dinan 5  [0.00]
agreed. The only thing you would find for less than 350 is a net book.
A full on desktop... that is not possible unless you are going to be recycling parts from an old rig.
"Nobody makes me bleed my own blood. NOBODY!!!!!"
      05-21-2013, 10:24 AM   #4
es0is
Drives: 335is
cheap comp
First post, picked a topic at random. I found a SSD laptop for $500 at micro center. dont know if that helps.
      05-22-2013, 07:07 PM   #5
WreckerX5d
Warrant Officer
WreckerX5d's Avatar
Drives: Deezul
You could find a decent amount of refurbished laptops for under $350. They have some comparable specs on them.
I bought mine for $450 and it has just under the same hardware as the gaming PC I sold.
Deleted, ATM I/C and tuned by B.R.R.
      07-04-2013, 09:47 PM   #6
techietaichi
techietaichi's Avatar
Drives: 2006 325i Pre-LCI & 2010 X3
You still looking for a rig Mr. Snail? I'm in the process of building one that I think will fit the bill. It is a little older tech, but I think that goes without saying. Don't fret though, it isn't a piece of junk. Off the top of my head(I'm at work right now), here's some of the specs. You can click on some below to check out the specs or reviews:
BioStar M7NCG 400 motherboard (The latest BIOS will be installed)
AMD Athlon XP 3200+ 2.2Ghz CPU
EVGA Nvidia GeForce 6200 512MB DDR2 8X AGP Video Card I'm actually in the process of upgrading this by adding a GPU fan that should reduce the heat output by 10 degrees.
3GB(max for this board because it's 32 bit) of Crucial 333MHz PC-2700 memory w/heatspreaders
500W Ultra Xconnect Modular PSU Blue LED
SoundBlaster Live! Sound Card
LB Link 54Mbps Wireless G Adapter
Standard 5.25 CD/DVD player
Either an 80 or 160GB HDD...I can't remember.
Windows 7 Ultimate
3 80mm led fans to keep it cool
all stuffed into an unassuming Acer mini ATX case.
Everything will be updated with the latest drivers or crucial updates.
I'll post up a pic tomorrow. It's not complete yet as I'm still waiting on some bits, but it'll give you an idea and if you're interested, you can let me know at your leisure.
