12-23-2018, 12:11 PM | #2 |
309
Rep 579
Had same problem, call ur car salesperson and ask to activate electronic sales agreement, once they do it ur app connects to ur car without having to enter a code in ur car (I couldn't even find a place to enter the code)
12-23-2018, 12:35 PM | #3 | |
Rep 978
I resent the code multiple times. It's not in iDrive 7's "Notifications" - which is the only place I can find that inbound communications might be received.. . |
12-23-2018, 07:56 PM | #4 | ||
Rep 287
12-25-2018, 01:17 AM | #9 |
Rep 3
Guys, I got this problem solved. I did the remote update within the Application menu and let the car does the software upgrade.
After few minutes, an icon called BMW Message appears, and go back to resend code within the ConnectedDrive app on the phone then the code will appear on iDrive. Here is how I solved it, for those who might need. By the way, I did that after called salesperson to ensure the ConnectedDrive is enabled at BMW side. |
12-25-2018, 03:50 AM | #10 | |
Rep 1,449
I already see BMW messages, but that made no difference when logged in by the secondary driver profile that is not recorded in my ESA.
2019 BMW X5 xDrive 50i M Sport: ZD8/ZLS/ZMP/ZP2/ZPK/ZPX/337/ZX7/2NH
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
12-25-2018, 02:56 PM | #12 | |
Rep 978
- I pressed the Apps button (Globe icon - lower button at 12:00 over the iDrive controller) - When you get to the Apps screen, you may need to move the iDrive controller to the left to see the "Installed Apps" menu item. - With the Installed Apps menu item highlighted (see first picture) - press and hold down the iDrive controller. - Doing so will give you the option to "Update Apps and Services". (see second picture). - Select Update Apps and Services Once the update completes, I received a popup note that I had new items in Data Privacy to enable/approve. So I went to (from the home screen) Car > Settings > General Settings > Data Privacy and checked "Agree and Activate All" I then went to "Configure Services" from that same screen and noticed "3D Remote View" was now available as an option. It had NOT been before. (see third image) This is as far as I've gotten. When I ask the Connected App to re-send the verification code, I get no code sent to vehicle that I can find - and I do not see an icon "BMW messages as described by denetliu Last edited by lumpydog; 12-25-2018 at 08:24 PM.. |
Minnie40.50 |
12-26-2018, 09:49 AM | #13 | ||
Rep 3
12-26-2018, 12:43 PM | #14 |
Rep 978
Helpful, thank you. I think we get different options here is the US. You appear to be located Taiwan.
Anyone in North America see the "Messages App"? My guess is we do not get it here - hence the issue with owners not being able to self-verify via a code sent to their X5. Below is what I see on my Apps... not sure how to add more (yet). I was finally able to get the Connect App on my phone to work by dialing 844-443-6487 and following the prompts to get support with Connected Drive. Person on the other end manually connected my X5 to the app. |
12-26-2018, 01:54 PM | #15 | |
Rep 1,449
My software is .43
12-26-2018, 03:06 PM | #16 |
Rep 287
Where are you located?
12-26-2018, 03:16 PM | #17 |
Rep 1,449
12-27-2018, 07:01 AM | #18 |
Rep 978
12-27-2018, 05:13 PM | #19 | |
Rep 128
Don't want to update now anyway...will wait until more of these issues get resolved with future updates. |
lumpydog693.50 |
12-27-2018, 06:00 PM | #20 | |
Rep 978
12-27-2018, 06:19 PM | #21 | |
Rep 1,449
I have tried various OTPs, but never got an indication they were successful including one such attempt today with the dealer IT guy. My primary software problem is with the ApplePay distraction when my iPX is in the charging cradle.
12-27-2018, 06:26 PM | #22 | ||
Rep 128
