BMW M3 Forum (E90 E92)
      07-08-2014, 08:40 AM   #45
Titan_br
Titan_br's Avatar
Brazil
12
Drives: M3 E92 with AA Stage 3 SC
2011 BMW M3  [0.00]
Originally Posted by StrifeM3 View Post
I am still waiting on this.
If you know something, let me know too please.
      07-08-2014, 11:02 AM   #46
slicer
slicer's Avatar
2746
Drives: 'E46 M3 Race Car, '23 X7
Originally Posted by Titan_br View Post
I did't see the info about some of it that work with EDC without emulation or delete. That keep edc original.
There aren't any coilovers with this capability. The closest thing is KW's system that has user selectable settings. It requires installation of a separate button, it doesn't interface with OEM EDC.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      09-22-2014, 12:42 PM   #47
italyix
italyix's Avatar
Drives: '08 E90 M3
Ok so I finally installed these beauties and snapped a few pics before they went in.
Nitron NTR R3 Triple Adjustable Coilovers - I will add pertinent info later, need to find the owner's manual!
Front Spring Rates: Custom but I chose 600lb linear springs
Rear Spring Rates: Custom but I chose 800lb linear spring
Triple Adjustable Settings: High and Low Speed Compression and Low Speed Rebound
Front and Rear:
Front Only:
Rear Only
Rear Top Pillowball attachment:
Camber Plates:
      09-22-2014, 01:45 PM   #48
Casey@RWE
Drives: e92 M3
MCS (Motion Control Suspension). Completely customizable, these are our "RWE"spec kits.
Top 2-way with remote, coilover rear, swift springs (F:616 R: 504), vorshlag camber plates
Bottom 1 way non remote, swift springs (F:616 R:728), vorshlag camber plates
MCS.jpg by RaceWerkz, on Flickr
      12-05-2014, 01:14 AM   #49
Status Gruppe MNF
Status Gruppe MNF's Avatar
220
Drives: 03.5 M3 / 2015 M3 Individual
Status Gruppe Manufacturing
The 2007-13 BMW E90/92/93 M3 SGT-SRS coilover features:
* Pillow-ball camber plates (Dual bearing design to reduce noise)
* Machined aluminum RSMs
* 18 way adjustable dampening (combination of rebound and compression)
* Monotube gas charge dampers
* High strength anodized aluminum alloy and powder coated steel components
* Full length height adjustment with separate settings for damper force and spring pre-tension
* Linear race springs 8kg front / 10kg rear (Cold wound from high tensile chromium silicone wire)
* SGT Adjustable Sway bar endlinks
* SWIFT Race Spring (Optional Upgrade)
Pricing $1425-1800
Kelse921133.50
      12-05-2014, 08:32 PM   #50
wrecklessfool
Drives: E92 M3
Originally Posted by JM35
Great post thanks! What options are there for good coils under the $2k mark?
Good coils? Probably none unless you can wait for a vendor to run a sale or a group buy. Maybe I'm wrong, but for under $2k MSRP, you would be hard pressed to find anything worth getting that includes springs and dampers as a complete package.
      12-10-2014, 01:19 AM   #51
TT_SM3RF
SLOOM3
TT_SM3RF's Avatar
Drives: 2011 M3 DCT, 2015 F80 M3 DCT
KW Adjustable Spring Conversion or "HAS" (Height Adjustable Springs)
Hey Titan,
If you would like to keep your EDC system/shocks but want to lower your M3, you can purchase the KW Adjustable Spring Conversion or "HAS" (Height Adjustable Springs).
This kit will lower the front and rear of the car while allowing you to keep your EDC functional. I just purchased a set and once my EDC's start to wear out, I'll purchase a full Coilover system. For now, it's the most affordable way to go and plus it's made by KW so you know it's a great product.
http://www.**********s.com/KW-Adjust...E92-E93-M3.htm
Enjoy
      11-08-2015, 09:09 PM   #52
Ultra M
Ultra M's Avatar
Drives: [09 E90]
great post! very helpful
      11-08-2015, 09:14 PM   #53
Ultra M
Ultra M's Avatar
Drives: [09 E90]
will the EDC function if purchased any lowering springs or certain brands ?
      02-05-2018, 11:50 AM   #54
spr
Drives: F80 M3; e92 ESS650+ M3
Do we know what the EDC Bilstein and KW rates are?
      07-21-2019, 10:59 AM   #55
Mr_Reeves
Drives: E90 M3
Intrax 1K2
http://en.intraxracing.nl/producten/1k2/
Not sure about technical specs but they are very customisable.
      08-16-2019, 10:20 AM   #56
tryingtobebest
87
Drives: E90
Anyone have any information about E90/92/93 stock Edc/NON Edc spring rates?
      08-28-2020, 09:50 AM   #57
ZoomieM3
Drives: OGII E46 M3/AW E90 M3
First post in this thread lists the stock spring rates. The assumption here is that the stock rates are the same for all configurations (DCT/Manual, Sunroof/Slicktop, Sedan/Coupe) The reason I bring this up is the ZCP spring rates seem to be per configuration and unknown.
My question is (and I have spent hours looking for this information) what are the spring rates for the ZCP springs? I am actually really surprised no one has listed this to date (unless it was my lack of searching skills). We know there are springs listed X6 and X5..so can we work to fill out the ZCP spring rates as a baseline for anyone looking to go with non-oem vendors both in coilovers and spring sets? Does anyone have this information.
ZCP:
Front Spring Rate: (Labeled M3/X6)
Rear Spring Rate: (Labeled M3/X5)
m3post
