BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
BPM
      06-13-2021, 05:21 PM   #309
ten3
Australia
Drives: BMW M3 E92
Originally Posted by lucid View Post
Regardless, it would interesting to know how much the rear seats weigh for instance--not that I would remove them.
Rear seat weight 20kg
      10-28-2021, 07:51 PM   #310
Accel Junky
High on Acceleration
Accel Junky's Avatar
Drives: 08 M3, 90 GTR, 21 Gladiator
Looking for a few weights if anyone has them or has a postage scale handy. I like to keep a spreadsheet to track every little weight loss or gain down to the fraction of a pound mostly because I just enjoy the process. Unfortunately my M3 came modded so I am missing these parts to weigh and I'm hoping to avoid buying stock stuff just to weigh. To pay it forward I'll also share some weights I've taken.
Need weights on:
- Stock intake elbow complete with hose clamps all the way to the filter itself (as pictured)
- Stock 08 (?) EDC coil spring 1x front
- Stock 08 (?) EDC coil spring 1x rear
- H&R Sport coil spring (red) 1x front
- H&R Sport coil spring (red) 1x rear
Some weights to share in exchange:
- OEM Engine Mount L (worn but not leaking) 1.69 Lbs
Bimmerworld Group N Mount 1.81 lbs
- OEM Engine Mount R (worn but not leaking) 1.69 Lbs
- OEM Axle Back Exhaust 55 Lbs
Megan Racing / Agency Power Axle Back Exhaust 31.8 lbs
- OEM Tires F 23.37 Lbs
Hankook Ventus V12 Evo 2 275/30/19 FR 26.4 lbs
- OEM Tires R 25.36 Lbs
Hankook Ventus V12 Evo 2 295/30/19 RR 28.02 lbs
- OEM 19" Wheels F 23.3 Lbs
Forgestar 19x10 +20 FR 24.1 lbs
- OEM 19" Wheels RR 25.5 Lbs
Forgestar 19x10 +20 RR 24.1 lbs
- OEM Con-rod Bolts x16 1.12 Lbs
ARP 2000 / BE Con-rod Bolts x16 0.96 lbs
roastbeef11591.50
      01-19-2023, 06:10 PM   #311
spxxx
Boost
spxxx's Avatar
1355
Drives: 135i M-Sport
Looking for front carpet weight (front section only).
Have a few weights to share:
TopSpeed non-res Xpipe: 19.6lbs
Front E92 Door Crash Bars (x2 per door): 6.5lbs / door
Amplifier: 4.8lbs
Rear Shelf Cover & antenna module: 7.8lbs
      03-11-2023, 02:52 PM   #312
autoart
347
Drives: 2009 335i e90 M/ 22 X3
https://www.google.com/search?client...id:vDFkatP3Se4
m3post
