07-19-2019, 01:06 PM | #111 |
///M Powered for Life
11517
Rep 10,345
My two cents:
I dislike the mid engine thing. American cars suffer from too much spreadsheet-itis, that is, the desire to 'check the box' on things. Examples: -Flat plane engine like the GT350. Then it drinks oil like there's no tomorrow and is unreliable given the complaints on the Mustang forums. But hey, they were able to check the damn box -Dry sump oil system. Cuz if expensive cars have it we need it too! Nevermind that later on it'll still suffer oil starvation. Meanwhile, the E9X M3 and F8X generations don't suffer oil starvation without any fancy check the box exercises. -Auto gearboxes that are worthless piles of manure. Like the 8 speed in the Z06. But they still spoke about it being faster than PDK/DCT... perhaps when the DCT is disconnected from the car the 8/10 speed is faster -Lots of cooling stuff. Diff cooler, tranny cooler, oil cooler, whatever. Then it overheats with stock PSS tires in 80F weather. -etc etc So, I feel the mid engine thing is a massive distraction. There is no handling issue with being front engine rear wheel drive. I wish they had concentrated on building a better driver's car. That said, I do like a few things: -Moved away from leaf/composite whatever springs and now have double wishbones. Given that a pro driver says they feel this is responsible for handling that is trickier than it should be, this is a big win -Still evolving big, NA power engines. I like the base engine has 495hp, that's cool. -Finally a friggin DCT! Built by Tremec so we'll see if it's comparable to DCT, but still a good step As always I'm a sucker for hoping they build proper american cars for track use that function properly. Hope springs eternal. Perhaps the C8 is something I can buy and that's exciting! BEFORE anyone gets all argumentative, I am trying to be constructive. I have no problem with Vettes (unlike Porsches) and I want them to succeed. The enemy of my enemy is my friend, so Vettes/Mustangs/whatever are all partners in the crusade against 4 cylinder $100k cars
NYG11051.50 Boostin FD382.00 |
07-19-2019, 01:07 PM | #112 | |
11517
Rep 10,345
Rest assured the equivalent C8 versions will be more expensive. Personally I don't mind them being more expensive as long as they function properly. People pay obscene amounts of money for Porsches with tiny itty bitty engines that cost 100k (Cayman S I'm looking at you) so no reason why the Vette's performance editions have to be cheap. But if it's a performance edition it had better work at the track |
07-19-2019, 01:20 PM | #113 | |
5605
Rep 5,394
This is an entirely new platform for GM, both mechanical and electronically. The motor is a pretty tried and true part but everything else, and I mean everything, is new. This car will not be without it's teething issues once it's in the hands of owners. Don't get me wrong here, I like the car a lot. I just pray GM has really beat the hell out of thing to reduce the potential of major issues after introduction. There's something about putting cars in the real world where the big issues are revealed. Look at the Mustang GT350 for example. That motor is junk. GM, without a doubt, is building some of best performing and handling cars at any pricing point. A light, mid-engine, 2 seat, V8 Vette for $60-70K will be an amazing performer and should be easier on expendables unlike their heavy performance cars using wonder tires to generate bonkers performance numbers. Thank God they made it look pretty dang good too, inside and out. It's high on my list. I also think 500hp is plenty and should be more than usable. Hell, the thing should easily do low 11s stock. That's silly.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
SYT_Shadow11517.00 |
07-19-2019, 01:27 PM | #115 |
Rep 1,087
Corvette never had any problem with speed but it always has been the finer things that irritate you. I haven't driven the car so I don't know mechanically how it will feel but visually, a couple things I am not sure I can live with.
The side air intake still looks really odd. When you open the door, that thing just sticks out from the door that is just weird. Also the rear end looks sort of flabby and too wide visually and the surface design looks a bit bland. Also because they have to add the trunk in the back, the length might be a few inches too long. The positives are it seems like they finally got rid of the leaf springs. Will see how the Tremec DCT perform. As for the manual, since the transmission is now located way at the rear, I think it would be a challenge to design a shift linkage from way up from the driver, past the engine, then to the gear box at the rear. |
Boostin FD382.00 |
07-19-2019, 01:31 PM | #116 | |
5605
Rep 5,394
All really good points. A mid-engine Vette was inevitable though. They've been trying to push one through since the 1970s. The powertrain tech is here and they are making gobs of power and the car was due for a redesign. They could have easily gone with a front mid-ship design, but mid-engine is the preferred way to go for most performance marques so that's the direction GM went. The Camaro will take care of the front engine and RWD performance duty. You do bring up a good point about cooling. Let's hope GM used mid and rear engine Porsche's as their benchmark for cooling design. There is definitely more effort in keeping this design cooled off reliably.
SYT_Shadow11517.00 clee1982799.00 |
07-19-2019, 01:55 PM | #119 | ||
2006 TIME Person Of The Year
9720
Rep 6,445
Grumpy Old Man6483.50 King Rudi13164.00 |
07-19-2019, 02:02 PM | #121 |
Rep 1,087
I found a possible issue. There does not seem to be anything that protects the radiator below. Most mid engine cars have the radiators upfront and probably run some types of piping back to the engine in the back. GM seems to place the radiator in the back probably for cost saving. From the picture, I don't see anything that will protect the radiator in case of a bird strike lols. That may also explain the heavier rear weight bias vs. other mid engine car.
07-19-2019, 02:04 PM | #122 |
9720
Rep 6,445
I really love how there is no talk of batteries/hybrid, and all-wheel drive snowflake BS. It's just a modern all-American sports car that a common man could aspire to actually own.
07-19-2019, 02:05 PM | #123 | |
BMW Fan
449
Rep 725
They also had another about the frame twisting from too much torque. One of the engineers was interviewed yesterday and had a good laugh about that. |
07-19-2019, 02:07 PM | #124 | |
9720
Rep 6,445
Grumpy Old Man6483.50 |
07-19-2019, 02:08 PM | #125 | ||
BMW Fan
449
Rep 725
What you’re looking at are probably driveline heat exchangers. Quote:
07-19-2019, 02:13 PM | #126 | |
Rep 1,363
Drives: 981CS/428/is250/JLU Rubicon
This is a game changer |
07-19-2019, 02:13 PM | #127 |
799
Rep 1,736
Drives: 2019 BMW 540i xDrive
so how likely is that someone can actually buy at msrp?
07-19-2019, 02:14 PM | #128 |
4465
Rep 9,160
Lots of cars have random scoops appended to the door.
[IMG]https://photos7.motorcar.com/used-20...054-1-1024.jpg[/IMG] [IMG]https://wallpaperstock.net/wallpaper...s1/46328hd.jpg[/IMG] [IMG]https://st.automobilemag.com/uploads...around%7C0%3A0[/IMG] |
07-19-2019, 02:15 PM | #129 | |
Rep 1,363
07-19-2019, 02:15 PM | #130 | |
Rep 1,087
07-19-2019, 02:18 PM | #131 |
17683
Rep 10,737
Drives: M4 CS. Former G82, x2 F82, F80
After a year or two steep discounts will likely be available just like every other Vette model.
Due to the radical design change of this platform, there's also no way in hell I'd buy the first model year. I could definitely see this being my next car in 3-4 years however. This looks like an absolute hit, and who else is going to give you this package for this kind of money? Sure as hell not BMW. |
07-19-2019, 02:27 PM | #132 | |
4465
Rep 9,160
[IMG]https://www.cstatic-images.com/super...825b28ccba.jpg[/IMG] https://www.cars.com/vehicledetail/d...5600/overview/ |
