01-28-2015, 09:42 AM | #89 |
Rep 1,188
Drives: 2008 e92 335xi
No, the Cayenne does not use VW's AWD system. They have their own system that splits 38/62 F to R under normal conditions and then can move more/less power to each wheel.
01-28-2015, 09:49 AM | #90 | |
Rep 262
2010 E92 SSII DCT, Akra Evo, ESS Tune, Performance Spolier &Splitter, Edition Side Markers, AD08R
01-28-2015, 10:15 AM | #91 |
Rep 749
Drives: 335i xDrive
Nice the video works now.
Interesting stuff. Gotta love the xdrive. |
01-28-2015, 10:39 AM | #92 |
2199
Rep 2,559
Having owned an S4 (torsion center diff not the new crown) prior to my 335 xdrive. I can say with certainty the S4 Quattro was superior.. ONLY because of the electronic limited slip REAR diff, which is an optional extra as noted in earlier posts. The diff was great in dry conditions because it would help with understeer by rotating the car and the diff was great on deeper snow and ice because in the rear it would keep power moving to the wheel with the most grip or move both in high slip conditions unlike than xdrive which can get hung up if all 4 wheels have limited traction and you need to keep the tires spinning to gain momentum...
I think the center diff is a matter of taste you dont really need a mechanical diff there unless you are off road putting alot of torque down that needs to be transferred most street driving in inclement weather drivers are trying to limit the torque going to down to the road as just enough to get the car moving I think xdrive with a rear LSD or eLSD would be an amazing improvement if they spread it throughout the line but considering BMW doesn't even put limited slips on the RWD non-M cars i don't see this happening. I believe only the MX5 and MX6 have eLSDs with xdrive. then there is the whole other issue of most of the xdrive cars being saddled with the higher ride height suspensions (only exception is the M235 xdrive) |
01-28-2015, 11:46 AM | #93 | |
1616
Rep 3,958
01-28-2015, 12:40 PM | #94 | ||
Rep 198
01-28-2015, 12:45 PM | #95 | |
284
Rep 1,961
01-28-2015, 05:38 PM | #96 |
Rep 124
Drives: s2000
There will never be a clear answer to this argument we all know driver skill and tires are what really matters in winter conditions. On snow tires I never had a problem in my b5 a4 or 335xi.
̶m̶2̶0̶ > ̶m̶2̶0̶ > ̶m̶2̶0̶ > ̶s̶1̶4̶ >F20C->1̶.̶8̶t̶-> n54
01-28-2015, 07:43 PM | #97 | ||
REBEL
783
Rep 1,281
We are in the States, where are you located? And what year and model do you have? The one thing with the North American M Sport that realy ticks me off is that it is not available with Fog Lights witch comes in real handy living by the coast. The Euro version as pictured in the BMW 3 Series brochure has them. It blows my mind why they are not the same with regards to Fog Lights. I was told it was deleted do to looks. Well I prefer the look with them and most importantly seeing where the hell I am going! |
01-28-2015, 08:31 PM | #98 |
Rep 1,465
Drives: 2009 BMW 335xi
Older xdrive (before dhp and active handling) did not have any sport suspension option.
01-28-2015, 10:01 PM | #99 |
Allen
32
Rep 129
Drives: 2013 AUDI S4 6MT
I have both an F10 with X-Drive and an S4 that has Quattro in my garage.
Both are great, but I will say that the S4 is a snowplow when there is more than 6inches of snow on the ground. To each their own, but people shouldn't doubt either system since they are both incredible.
Current Vehicle(s): 2013 Silver AUDI S4 6MT | 2015 BMW 535i xDrive M-Sport
01-28-2015, 11:38 PM | #100 |
Rep 49
Just google Quattro vs. XDrive (answer to BMW video) and you will find videos on u tube showing the other way of the story.
I believe this is all marketing and it's not easy to say which one is better...probably they are comparable. My 2 cents.. |
01-28-2015, 11:49 PM | #101 | |
284
Rep 1,961
01-29-2015, 05:08 AM | #102 |
3775
Rep 6,673
I think one factor which has been overlooked in our discussions thus far, is the amazing DSC traction control system on the BMW's. That is really the mastermind ... the wizard behind the curtains. Because in its absence (DSC, DTC off), xDrive does not appear to be as competent as one may be lead to believe. I do not have a good scientific explanation for that, but all I can say is that on my xDrive car, once the DSC has been de-activated, all bets are off. It immediately fishtails, revs climb and any sense of confidence is quickly squandered. It feels like a 4WD rear wheel drive car, if that makes sense.
I shot a couple of videos to try and illustrate that. My cars is a 335i xDrive, with base suspension. All season tires, with 28,000 miles on them. Not exactly the perfect winter setup. Video 1: Comfort mode, DSC turned off (no traction control, no stability control). You will see in this video that I am attempting to climb a decent sized, fresh snow covered hill. Traction control is completely off. As soon as I get on the gas, the car starts to loose traction, tire slippage is almost instantaneous, and revs climb pretty fast, making things even worse. It goes up the hill, but not without judicious throttle modulation and steering inputs. Video 2: Sport mode, DSC turned on (traction and stability controls both on). Here you can see the DSC system working really hard, with the engine rpm's dance around "hunting" for traction and the constant DSC relay system making sure power is rationed out appropriate to wheel traction. Once it gets going, it's almost as if there is no snow on the ground. It's incredibly clever, I must say. Very little-to-no-throttle modulation required here. Just a steady 50% throttle application gets you up the hill pretty quickly and with no drama. Video 3: Bonus: Snow drifting in Sport+ (limited traction control). It still amazes me how effortlessly the xDrive system will allow the car to behave as a RWD car, in the absence of DSC. With a quick blip of the throttle, the tail snaps out, opposite of steering input. An effortless 180, with minimal interference from the front wheels. SO in conclusion, I would really call the xDrive system an all wheel drive "capable", but not a true all wheel drive system. In the absence of any electronic nannies, I believe it maintains a heavy RWD bias. |
01-29-2015, 09:17 PM | #103 | |
360
Rep 1,797
Living in the Snowbelt? I've come to rely on and like the AWD. Wouldn't surprise me if Xdrive outsells RWD in Midwest USA right now.
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
01-29-2015, 09:21 PM | #104 |
360
Rep 1,797
That's shocking to me...
01-29-2015, 09:25 PM | #105 |
284
Rep 1,961
Not me. Mercedes is close to that also. With all the SUVs sold, and the amount of people who buy in snowy areas, I actually expected higher. The dealers up here rarely even stock rear drivers. Maybe 1 or 2 of each model and the rest are AWD.
01-29-2015, 09:34 PM | #106 | |
360
Rep 1,797
I was thinking just car platforms and worldwide...Wonder what the % of cars are xdrive worldwide? I suspect that is closer to 25-33%? In the snowbelt here is the States and Canada obviously much higher..
01-30-2015, 09:32 AM | #109 | |
REBEL
783
Rep 1,281
01-30-2015, 10:41 AM | #110 | |
Moderator
7525
Rep 19,368
I'll bet it is steadily increasing though. Just looking at the proliferation of xDrive to different models, one could reasonably make that conclusion. Even the convertibles are available with xDrive now - makes sense since Audi had previously had a lock on that. |
