BMW 2-Series Gran Coupe
BMW 1 Series Forum Second Generation (F40) BMW 1 Series (F40) General Discussion
      08-01-2020, 08:47 AM   #67
knali8
knali8's Avatar
Australia
457
Drives: 2021 X3M Comp
Originally Posted by Gregus330i View Post
My new unicarscan scanner arrived so I've coded Sport Plus and Comfort Plus. There a coding which gives you a graphic equaliser and various sound settings but these don't seem to work with the standard sound system, unless I need to code something additional.
I'll do some more research in expert mode when I'm off work and see what other interesting goodies I can find.
Cool.. now you can enjoy the quick shifting.. let us know when you get the equaliser going
      08-15-2020, 10:06 AM   #68
dominguez255
Drives: BMW Serie 1 F40
Hello, I have a 118i, the transmission is manual, i was actived the mode sport+ but in the sport customer, we dont change the transmission to sport+, this option not found but i can change the engine to sport+,
does anyone know why? and i am interested to activate the hba, i can buy this packet in the connecte drive but i want coding this.
      08-15-2020, 08:14 PM   #69
knali8
knali8's Avatar
Australia
457
Not too sure why but I'd probably say that its because your gearbox is a manual transmission.
      08-16-2020, 04:57 PM   #70
dominguez255
And for can active the HBA ? any idea ?
      08-18-2020, 07:36 AM   #71
knali8
knali8's Avatar
Australia
457
No idea mate.. not sure where to get that info either.
      08-21-2020, 07:05 AM   #72
Gregus330i
Gregus330i's Avatar
United Kingdom
102
Drives: BMW 330i M Sport
NEW CODING FOR EXHAUST VALVE PERMANENTLY OPEN
You can have the exhaust valve permanently open, irrespective of whether you're in Sport, Comfort or Eco mode. (You need ASD disabled for the benefit of actually hearing your real exhaust, otherwise ASD drowns the exhaust sound out)
Code with Bimmercode Expert mode which will add SPORTY setting to your engine sound menu, which currently has 3 settings:
Depending on driving mode
Balanced
Reduced
The Sporty setting will keep the valve open constantly.
Switch on Expert mode under HU_MGU. Type in the word sound, you'll then see 2 options, enable both.
SOUND KONFIGURABILITY & SOUND KONFIGURATION.
Click code and wait for it to complete, then check your engine sound menu settings and you should see the additional Sporty setting👍
MrFoxy376.50
      08-21-2020, 07:28 AM   #73
knali8
knali8's Avatar
Australia
457
Excellent! I will code this first thing tomorrow morning
Did you end up coding in xtra boost?
      08-21-2020, 07:54 AM   #74
Gregus330i
Gregus330i's Avatar
United Kingdom
102
Xtra boost if for hybrid/electric cars only 😊
      08-21-2020, 10:42 PM   #75
knali8
knali8's Avatar
Australia
457
Ok coding done and worked well. The steps i took were slightly different maybe because I was using an Android phone but the process is similar.
      08-22-2020, 03:13 AM   #76
dominguez255
I have this option activated but I don't really notice any change, could it be because my car is a 118i? ASD I don't know what it is or how it is deactivated
      08-22-2020, 03:59 AM   #77
Gregus330i
Gregus330i's Avatar
United Kingdom
102
It's basically an enhanced synthetic/fake engine sound inside the car. Have a read about it. Type Active sound design BMW on Google and there's loads to read about what it does and how it works. It can only be disabled with coding. Reduced setting under Engine sound menu will reduce it significantly. You need an OBD2 adaptor, ideally one the more expensive one's which allow more coding. I have a Unicarscan from Germany, 50 Euros. Plus I paid for Bimmercode full access which was around £30 I think. Considering if you went to a BMW dealer and had one item coded, they would likely charge anything around £40 to £60, I would imagine. So with a good scanner and full Bimmercode app, you can code a lot more for a lot less expenditure. ��
MrFoxy376.50
      08-22-2020, 04:14 AM   #78
dominguez255
I already have bimmercode and enet cable and encode the sound menu option, but the thing is that I don't notice a difference so I don't know if my car carries it.
      08-22-2020, 02:26 PM   #79
MrFoxy
MrFoxy's Avatar
Scotland
377
Drives: F40 M135i. G42 M240i
Don't suppose you have a link to the adapter you have mate?
      08-22-2020, 05:48 PM   #80
Gregus330i
Gregus330i's Avatar
United Kingdom
102
https://www.obd-2.de/shop/profi-diag...iagnoseadapter
MrFoxy376.50
      08-23-2020, 02:54 PM   #81
MrFoxy
MrFoxy's Avatar
Scotland
377
Thanks mate, much appreciated
      08-24-2020, 07:46 AM   #82
Lambster
Car go brum
Lambster's Avatar
Drives: BMW M135i (F40)
Like an idiot I bought the Veepeak OBDCheck BLE OBD2 and then checked this thread afterwards. Sent it back now and ordered the ODBLink MX+ although pretty expensive so might just get an ENet cable and Ethernet to Lightning adapter or something.
Did manage to code a couple of things. Really like the M Style Dash but anyone noticed there's no change when you put it in to Eco? Presumably because M cars don't have an Eco mode.
      09-07-2020, 12:34 PM   #83
rich345
Drives: BMW M135i
Hiya,
New here and to coding! i am trying to find these settings in bimmercode, i have the full version and a unicarscanner.
Bower & Wilkins settings.
Enable Colder Air Conditioning
enable one touch front window close when when door opened
any help will be great, sorry if i am just being blind!
Thanks
      09-07-2020, 02:35 PM   #84
adam.b
189
Drives: iX3 Premier
I have asked few times for coding temp for tyres on F31 and x3 G01, the answer was, they can't do it?
      09-09-2020, 07:59 AM   #85
knali8
knali8's Avatar
Australia
457
I'd think that's the case too. I wasn't so keen on the M dash so I took it off. It would have been good if it came with the M sports display 👍
      09-09-2020, 08:02 AM   #86
knali8
knali8's Avatar
Australia
457
Originally Posted by rich345 View Post
Hiya,
Thanks
'enable one touch front window close when when' this option is available as I have coded it in.. not sure where exactly it is though
      09-10-2020, 02:19 AM   #87
Lambster
Car go brum
Lambster's Avatar
I ended up going back to standard for the displays. Loads of missing info including your gears in Sport - which I found odd.
      09-11-2020, 04:22 AM   #88
dominguez255
what is this ?
bmw
