08-15-2020, 11:40 AM | #45 |
1120
Rep 1,644
At some point the larger size of these intercoolers is going to be cancelled out by the lack of airflow to the radiator. Instead of boost temps causing issues on the track it'll just be coolant instead. Civic Type R already seeing this issue.
08-16-2020, 12:56 AM | #46 | |
Rep 390
Cool to see more people give this a go. Its really not that bad of an install. |
08-16-2020, 05:06 AM | #47 |
Rep 147
08-16-2020, 08:02 AM | #48 | |
2840
Rep 3,715
Need to get her on track to confirm. |
08-17-2020, 12:59 PM | #49 |
Rep 878
Drives: ///M2
I just bought a Evo 2 comp with chargepipes but I haven't installed it yet. Should I consider returning this one and going with the Evo 3?
N54 135i 6MT (FBO, JB4 reflash, E30) sold
E90 M3 DCT (FBO, tuned) sold Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek) |
08-17-2020, 01:44 PM | #50 | |
2840
Rep 3,715
If so, I would switch. If not, Evo 2 or CSF/do88, etc, is fine. |
10-21-2020, 08:54 AM | #51 |
Rep 34
How did you guys find a front brace from the M235i? I'm looking all over the place but I can't even find this specific part...
On all the oem part websites I can't find it for the M235i. I'm only getting ones for the M2, M3, and M4. Can't find this brace from the M235i anywhere. Does anyone have a part number or know where I can get one? I can't even get a pic of the thing to pop up anywhere like I'm searching for the completely wrong thing. I would appreciate the help, thank you. |
10-21-2020, 09:02 AM | #52 |
2840
Rep 3,715
10-21-2020, 09:13 AM | #53 | |
Rep 34
I will go ahead and order this. Thank you for the crazy fast response!! I wasn't expecting that lmao This is everything I'm ordering: - M235i V-Brace - Bolts for IAT sensor - Longer bolts for new provided crash bar Is there anything else I need or you would recommend? Thanks a lot for the help! |
ZM22839.50 |
10-21-2020, 09:20 AM | #54 | |
2840
Rep 3,715
I think mine came with the IAT bolts, but I can't confirm, so I'd still grab those. Also, I found some 75mm bolts for the crash bar that worked. You should also decide how to connect the bottom two connections on the old M2 brace. As noted above we cut up my OEM brace, but some guys are fashioning up their own. |
OutoftheBlueM243.50 |
11-12-2020, 06:13 PM | #56 |
2840
Rep 3,715
Bc of all the COVID craziness this year, I didn’t get to test her out on a race track on a hot summer day. However, check out this log:
https://www.bootmod3.net/log?id=5f11...729b5ec78a69a2 This is V5 of the BM3 Stg 2+ E30 beta map a few months before the OTS was released, and the point of this log was to stress test the heat issue. You can see the ambient & IATs temps and how hard I was pushing the car with hard braking on my AP Racing kit in between pulls. Engine & oil temps got close to pulling power, but when I’ve done similar tests on maps with less power and my Evo2, IATs would get 60F above ambient and the engine would overheat. With the Evo3, the IAT/ambient delta got up to 27-29F during pulls and stayed there no matter what I threw at the car. I still need to get it on track next summer with the OTS map that has even more power to test that I’ll be stable, but this is pretty encouraging. EDIT: If you looked at this within the first 5min of me posting, I linked to the incorrect log. Now fixed. Last edited by ZM2; 11-12-2020 at 06:20 PM.. |
11-14-2020, 12:43 PM | #57 | |
2379
Rep 4,218
ZM22839.50 |
11-23-2020, 04:51 PM | #58 |
Rep 34
So my Evo3 was installed today. Only problem is now I'm getting an error '102001: Air mass too high'.
Any ideas? Is it an issue with a sensor somewhere or is it simply because there's just too much airflow now? If it's airflow then I think the tune can be adjusted right? |
11-23-2020, 05:07 PM | #59 |
2840
Rep 3,715
Sounds like a leak?
I would double check the meth bungs are tight, and the fitment of the Evo3 is so tight on our car that it’s easy to mess up the o-rings. I’m guessing that’s your culprit. Last edited by ZM2; 11-23-2020 at 06:58 PM.. |
nothingman522.00 OutoftheBlueM243.50 |
11-23-2020, 06:56 PM | #60 |
Private NumNuts
522
Rep 321
Shameless plug. I'm selling a Wagner EVO3 intercooler still brand new never used:
Wagner EVO3 Intercooler brand new never used for $1050, retails for $1390.
11-23-2020, 10:45 PM | #61 | |
1120
Rep 1,644
11-24-2020, 07:55 AM | #62 |
24516
Rep 191,518
11-27-2020, 10:41 AM | #64 | |
@lbb_kev
496
Rep 516
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
AWC-F87436.50 |
12-03-2020, 12:08 AM | #66 |
437
Rep 485
Hey GerardzM and ZM2 can you guys elaborate a little more about what it entails to modify the m2 front brace for use with the Evo3 please. I just bought a ton of parts from nothingman and I'm pretty clear on the Evo3 install aside from the brace modifications. Thank you!
