      12-17-2024, 07:09 AM   #23
FrankMstein
FrankMstein's Avatar
Drives: F80 M3, R56 Camden, F56
I had a Ryobi for about 5 years and it died then went to the Active 2.0 when it came out and so far, great!
2015 Sakhir/Sonoma (first one totalled) 2nd one MHD and BM3, Eventuri, Mosselman, NICECNC, MAD FAT BOY DP, "Valvetronic Designs" single mid, PAGID RSC1, Hotchkis/GTMore, Vorschlag, Bilstein B16/10.
Soon Powerflex diff brace, Akropovic axle back for sale.
      12-21-2024, 02:41 PM   #24
jwmFcreek
Drives: Xm
Have to say really like the Big Boi pro with the 3/8 pressure hose at 60 feet .
Getting 1300 psi in rinse with 2 gallons a minute . Had to take the handle off the pump to allow the hose to fit .
The hose lays perfect on the floor doesn’t twist and or get stuck on the tires .
Very quiet like the purchase a lot
      12-22-2024, 09:22 AM   #25
powerplaymike
Drives: 2021 M2C 6MT
Used a prosumer ex-Home Depot rental 2.7gpm gas for many years (with a properly sized tip).
Wanted to try an electric, moreso cause of noise and also cause it’s not good to idle gas PWs unloaded (even with unloader valve) so i always felt rushed when I was doing contact washes and/or would inconveniently keep turning it on and off.
Was in a massive rabbit hole of research
Tried a Ryobi electric that I could max at 1.2gpm … wasn’t enough rinsing power for me.
Tried a greenworks electric with the variable brushless motor that I could max around 1.8gpm, but hated the ramp up it required. Also took up a lot of space
Ended up getting an Active 2.0, cause Active’s patented 5 valve pump is basically the only way to get high gpm in a consumer / non-professional electric PW.
While longetivity may be questionable (there’s enough negative reviews / feedback / etc), the unit itself otherwise basically checks all the boxes (good gpm which is what you want for car washing, small and portable, splits the difference between $150 big-box store electric and a $750+ professional electric)
Side note 1: most big box electric PW are all the same. At any given price point, ryobi at HD is basically the same as greenworks at Lowe’s which is basically the same as whatever Tractor Supply sells. Moreover, most of the time for electric PW, the gpm and psi are a function of the nozzle, not the pump. Their claims of 3000 psi and/or 2gpm come with massive asterisks, cause all they sometimes do is change out nozzles and market it slightly differently.
Ultimately, you’re gonna pretty much max out at a range of 800-1100 psi with 1.1-1.5gpm from any non-brushless non-“ramped up” motor from a big box store.
Side note 2: no matter what people say, there’s no way electric is replacing a gas for house work, unless you have very minimal needs. I still have my gas PW, cause no way an electric PW is gonna run all afternoon non-stop when needed to wash a large driveway and then fence and siding. Small deck or patio, yeah electric is fine … but a 4-6 car driveway and then moving on to a fence and then a shed or side of house … gonna need a gas PW for that
So, depending on your home needs, if you can only pick one, I’d definitely pick gas and just run a larger orifice for your car needs.
      12-22-2024, 09:32 AM   #26
Tobster3
Tobster3's Avatar
713
Drives: 2024 M3 6MT
Originally Posted by NYG View Post
I got one of those SunJoes from amazon for car wash duties a few years ago. It has been abused and neglected in every way but keeps working well. Highly recommended for the price.
Ive got the same. I’ve used it for power washing the drive, sidewalk, fence, patio and weekly car washes. It’s been dropped, almost run over by the wife and still works like a charm. Newer models are slightly quieter from what I’ve heard which I’m looking at considering I like to wash the cars early on a Sunday.
Appreciate 3
jwmFcreek101.50
ipilcher632.00
nyalpine907688.50
      12-26-2024, 11:15 AM   #27
argb
Drives: BMW X1 xDrive25d
I think you can't go wrong with a Nilfisk. Mine works flawlessly for 5 years now and without any maintenance or special care from my side
      12-26-2024, 11:16 AM   #28
powerplaymike
Just fyi for those in the US: I don’t think Nilfisk is available in the US market.
argb7.00
      12-27-2024, 09:24 AM   #29
argb
It's a Danish company and I see they have a US website and online store but I guess distribution is very limited in the states
https://www.nilfisk.com/en-us/
      12-29-2024, 11:50 AM   #30
EvasiveF87
EvasiveF87's Avatar
Drives: 17' BMW M2 (DCT)
Active 2.0 and Kranzle are great but if it was me I'd rather spend that money on getting yourself a functional $100-$150 pressure washer (example ryobi) and put the rest of that towards getting a DI / Spotless set up. That in addition to a quality pressure washer hose, gun, tips and attachments, etc.
Just making the assumption OP doesn't have that already, there's no rhyme or reason for him to go splash $1,000+ on a pressure washer. Makes no sense lol
      12-29-2024, 04:06 PM   #31
powerplaymike
An active 2.0 is only about $325-350.
The 2.3 is what’s $600 and approaching higher end Kranzle territory.
Agreed a kranzle isn’t appropriate for most weekend warriors. A Kranzle PW is like a Snap On tool…worth the money, but to the right person. Same way I wouldn’t recommend a Snap On Torque Wrench to someone that just wants something to rotate their tires once a year, I wouldn’t recommend a Kranzle to most either.
Agreed a DI system is super nice depending on your water quality and washing environment. While my PPM is pretty low, my driveway is in the sun from sunrise to sunset, so I recently picked up a DI system to try and it’s been super helpful.
      12-29-2024, 06:01 PM   #32
MaineSport
Drives: 2025 BMWX40i
2.3 isn't even close to Kranzle territory price wise. They are both great but in different leagues. Get the Kranzle and never look back. Buy once, cry once. Second choice, AR Blue 630TSS.
      12-29-2024, 07:28 PM   #33
Jambo1
Drives: 2022 M5C /// 2025 iX xDrive50
  [10.00]
Active 2.0 here. Agreed, noisy, but cheap.
Reventon Splitter /// Reventon Diffuser /// Addlights M Door LEDs /// Dinan Inlets /// Gentleman's Switch /// Paddleshifterz With Piano Black Steering Wheel Trim /// Charcoal Filter Delete /// Piano Black Side Skirts /// Funk Motorsports Turbo Blankets
      12-29-2024, 08:00 PM   #34
MaineSport
That's a nice setup. Wheel wash station on the right?
      12-29-2024, 08:43 PM   #35
powerplaymike
Agreed in the $800-ish range, the 630tss is a great option if trying to avoid going into $1000+ kranzle territory.
unfortunately the AR isnt typically mentioned cause needs a proper 20amp circuit and receptacle. Not a dealbreaker, but also not “plug and play” for many people
For certain items I agree a buy once cry once may be appropriate, but you can literally buy three active 2.0 for the price of one kranzle, and they’ll have pretty comparable real world performance.
So even if you get 2 years out of an active and it burns up just after warranty, you could buy it twice again.
And kranzle I believe still needs maintenance, so there’s still some costs of consumables / etc to consider if looking at costs over let’s say 5-10 years.
Not saying the kranzle isn’t worth it, just repeating what I’ve said before that the active and their 5 piston pump offers a ton of bang for the buck.
And no I’m not an active fanboy by any means…in fact I basically tried every other option around the price range in order to avoid Active, but ended up getting the 2.0
jwmFcreek101.50
      12-31-2024, 10:01 AM   #36
MaineSport
Agree with everything. Both those Active choices get great reviews.
      01-02-2025, 12:15 PM   #37
nyalpine90
nyalpine90's Avatar
7689
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.25]
how much psi is safe to use?
      01-02-2025, 01:13 PM   #38
powerplaymike
Most recommend 850-1100 range. More important even at that range is degree of nozzle (white tip 40 for the body, can use green tip 25 on wheels and also body if careful)
nyalpine907688.50
      01-02-2025, 01:51 PM   #39
nyalpine90
nyalpine90's Avatar
7689
2016 BMW X4  [9.25]
im looking for replacement, i had greenworks pro 2000psi
after 2yrs it failed.
      01-02-2025, 01:59 PM   #40
louielouie
Drives: '18 F80
There's 3 year warranty on Greenworks. I never have claimed but heard it's pretty easy.
      01-02-2025, 02:06 PM   #41
nyalpine90
nyalpine90's Avatar
7689
2016 BMW X4  [9.25]
well
its long gone now.
      01-02-2025, 02:38 PM   #42
powerplaymike
Holding other variables constant, psi is determined by the tip orifice size.
As such, pretty much any pressure washer you see is going to have a “marketed” psi and/or gpm to attract your attention, but in reality the variable is the tip they supply because they’re basically all using the same or similar OEM mfr’d pump, either across brands or within their own brand.
The smaller the tip hole, the more PSI but at less GPM.
The larger the hole, the less the PSI but with more GPM.
(To a degree, as there’s limitations to the pump and also electrical circuit limitations)
So, whether it be a supposed 1800 psi Craftsman or a supposed 2000 psi Greenworks or a supposed 2600 psi Greenworks, I can almost guarantee the difference is the tip orifice size and you can put the appropriate tip on any one of them to achieve equal nominal 1000psi and 1.2-1.4gpm performance from any of them. (NOTE: this is applicable to standard style pumps…some units from the likes of Greenworks are brushless and use a special smart sensing variable brushless motor that can vary the output…..but they have a terrible lag like a turbo lag in a car, which some people don’t like)
Matt from Obsessed Garage did a huge test of all the different PW’s, and has a good chart that shows all of them with the performance.
At the end of the day, the big box stores are all selling what are more or less identical pieces but with different housings or colors and “marketed” psi or gpm that appeal to the happy home owner.
Main reason being the style of motors/pumps that all those big box stores are buying from the supplier are all the same lower end ones and also have to be compatable with only a 15amp circuit in the US market.
Euro market has pressure washers with better performance cause they have different household electrical system than the US does.
nyalpine907688.50
      01-02-2025, 02:52 PM   #43
nyalpine90
nyalpine90's Avatar
7689
2016 BMW X4  [9.25]
this is very helpful.
i guess upgrading the nozzle tips and water gun would be good idea?
      01-02-2025, 03:12 PM   #44
powerplaymike
For the tips: You definitely don’t need anything fancy at all. Just need the right size, cause tips are considered disposable anyway.
Cheap tips work just as well as expensive ones. Only reason to get an expensive one is if you want the ones that have a rubber boot.
Spray gun: yes, Get a stubby spray gun
And get quick connects as they make your life a ton easier.
My personal setup is pretty upper-tier.
I have an MTM spray gun, a MJJC foam cannon, an Adams hose (cause Active pressure washers don’t do well with Uberflex hoses), a DI system, quick connects on everything, a Leaf Blower and stubby nozzle…the whole 9
I say that cause for anyone reading, don’t feel you have to go with the most expensive high end stuff….whether it be the spray gun or the foam cannon, while a $30-40 piece vs $80-100 piece will have some compromises … if you’re a weekend warrior spending one day a month washing your car, the cheaper priced stuff will work just as well.
Knowing what I know, and trying cheaper stuff that I’ve then recommended to family/friends, unless you want / have a need for top tier, you can definitely save some money and use it for better things. $50 here or there on a few items, and all of a sudden that’s an extra $150 that you could’ve kept either for less out of pocket cost or for upgrading something more beneficial like going let’s say from a $200 Greenworks to a $350 Active pressure washer, or buying a DI water system.
nyalpine907688.50
jwmFcreek101.50
